SimTools v3 Public Beta
  1. yobuddy
    51,545Coins
    Plugin Updated - Dash Issues should now be fixed in F1 2023, please let me know how it goes.
    (wind sim's should work fine now with this title) :thumbs
  2. ivan jack
    ivan jack Member
    412Coins
    everything works amazing In RaceRoom, but motion doesn't stop at the end of the race and right when you cross the finish line rig goes violently on one side, get back, then continue simulate moves outside the race.
  3. martin budd
    martin budd New Member
    36Coins
    Sorry for the newbie question but I am new to simtools and have just installed and got the v3 beta up and running with motion etc working for ams2. I am having trouble working out how to tune/auto tune limits as per the documentation for v2. Can anyone assist in explaining how to tune the motion, I have been using trial an error so far!
    Its not bad now but the gearshift is way too strong!
    Again sorry if this has been asked before but I have not used v2 before either so its all new to me
    153,944Coins
    +11,159 / 57 / -2
    Generally speaking, you set reasonable Axis Assignments, that is around 100% total, then capture Max/Min values in the Tuning Center. You can then adjust and fine tune settings from there.
    While the interface, and some underlying SimTools 3 settings responses have changed, in general the basic motion tuning principles remain the same: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  5. yobuddy
    51,545Coins
    I will take a look at it today, I believe we can fix this problem.
    Take care!
  6. martin budd
    36Coins
    Perfect, will take a look at info, thanks
  7. yobuddy
    51,545Coins
    Plugin updated, let me know how it goes buddy.
  8. Nestor Giraldo
    Nestor Giraldo New Member
    Electronics Eng
    Colombia
    147Coins
    Hello!
    It was a while and came back to the sim this week and tried v3. So far is an excellent upgrade to v2: excellent job! I was reading the thread and seems nobody play pCars1 so, I found last night that Sway and Surge signals are crossed. No big deal, just had to configure the motor directions accordingly and back in business but thought to report if there is an issue with the plugin...
    Thank you all!
    Nestor G.
  9. yobuddy
    51,545Coins
    Do you mean each one is backwards, or they are swapped with each other?
    Thanks for the report buddy!
  10. Nestor Giraldo
    Electronics Eng
    Colombia
    147Coins
    Swapped is the right word. Thx
  11. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Does this plugin work with Simtools3? I have tried installed it but give me error.
    153,944Coins
    +11,159 / 57 / -2
    SimTools v2 plugins are incompatible with v3. Plugins are being re-written and added to v3 as quickly as possible, but it does take time to cover them all.
    You can have v2 and v3 installed on the same PC, so if a plugin has not yet been ported use v2.
  13. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    WAIT!!, I actually post the wrong thread, sorry..lol
    I actually asking that RCRider plugin will run in Simtools3?
    EDIT: hmm..my post is moved to here though. So if I download V2 can I use the sam SN from V3?
    153,944Coins
    +11,159 / 57 / -2
    Yes you can.
  15. offman
    offman New Member
    11Coins
    the new update of the f1 23 plugin, works perfectly...Movement nj motion works...Vibrations works, windsim works.Thank you buddy
  16. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    What setting in Simtools (or SMC, maybe) to be able to feel when hitting wall?
    153,944Coins
    +11,159 / 57 / -2
    SMC3 is just used to help do your hardware configuration.
    The rest is all about refining your motion profile, hitting a wall is pretty simple, as it is basically going to trigger most axis towards the max of whatever is set, but the motion profile should really be crafted around first setting up each axis independently, then enabling them all and refining from there: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  18. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    But could I double the effect just for hitting wall? When I crash the wall, my rig just steady still. Before hitting wall, on gravel it moves great and accurate.
  19. yobuddy
    51,545Coins
    Do you have crash detection on maybe?
    What does your max/min setting for surge and sway look like?
  20. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    This is what Min/Max I got. Crash detection is Disabled.
