  1. sci666
    1,210Coins
    Not only in v3! In v2 also you can run 6 channels with 6 arduinos
  2. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Awesome!! Going to upgrade into 4 axis.
  3. Peter_the _machinist
    Peter_the _machinist Member
    Mechanical Engineer (CAD,CAE)
    Poland, Gdańsk
    359Coins
    How you will achieve 4 axis with 4 motors? Coukd you provide some schematics?
  4. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Sorry, I meant that 4 motors like using actuator does (on 4 corners). Could I?
  5. Peter_the _machinist
    Poland, Gdańsk
    359Coins
    So thos eill be 3 axis from 4 motors.
  6. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Ahhh...yes that's it, 3 axis. I missleading the 4DOF means lol
  7. Muneer Ahmed
    Muneer Ahmed New Member
    - 44Coins
    i have not arduino uno. can i use arduino nano ?
  8. sci666
    1,210Coins
    nope, it must be the bigger one with ATmega328P Chip, as I know.
  9. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    If I use 2 Arduinos, what is the Output Interface code?
    Should be, [A<Axis1a>][B<Axis2a>][C<Axis1b>][D<Axis2b>]??
  10. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,035Coins
    3DOF, DC motor, Arduino, 6DOF
    Here were my connections with Mover.
    Pierre.
  11. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Appreciated, Thanks.
    So A axis assignment can be from any ports?
    BTW, what is the 'A' capital letter on the command refer to?
  12. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,035Coins
    Don't know. The channel I guess.
  13. Rico Mortis
    Rico Mortis New Member Gold Contributor
    84Coins
    Guys what should the smc3 ino file be called arduino IDE keeps asking me to change its name..
    thanks in advance
  14. yobuddy
    51,524Coins
    The axis assignments you get your values from, axis A, B or C assignments.
    For separate settings per Arduino, you could use.
    Arduino #1) [A<Axis1a>][B<Axis2a>][C<Axis3a>]
    Arduino #2) [A<Axis1b>][B<Axis2b>][C<Axis3b>]
    smc3.ino should be fine, but the ide will probably want to put the file into a folder.
    I have not see it ask me to rename anything personally.
    Hope this helps,
  15. Rico Mortis
    84Coins
    awesome thanks guys
  16. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Thanks Yobuddy for the reply. I have successfully using 2 UNO's now.
    BTW, I want to use 10-turn potentiometer. What is the reliable wire wound potentiometer? Or better using something else type?
    Edit: Also, can I add limit switch to SMC3?
  17. Rico Mortis
    84Coins
    hi guys
    please help
    when i'm trying to upload sketch file to Arduino it flags up error in red "void setup ()" then stops
    cant figure it out .
    Thanks in advance
    Rico
  18. noorbeast
    153,758Coins
  19. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    I don't know if this help you out but did you install all related libraries with the sketch?
    deeph
  20. Edusfilms
    Edusfilms New Member Gold Contributor
    - 114Coins
    Hello, I have done all the steps in the tutorial and SMC utils works well for me but in SimTools it does nothing for me. Anybody knows what could be the problem?
