Forza Motorsport (8)
Discussion in 'Other Racing Games' started by Pascal75, Oct 5, 2023.
  1. izhangt
    izhangt Member Gold Contributor
    - 91Coins
    2DOF, Motion platform
    U forgot to mention that I have to double click in play button in simtools!!! Xd
  2. izhangt
    - 91Coins
    Now is moving, thank God, but got a problem, axis are inverted, when I accelerate it moves forward and viceversa, know how to change in game engine?
  3. p00ky
    p00ky Active Member
    Self Employed Laser Cutter
    Wales
    392Coins
    You have to change your axis settings in Simtools, there's no way of doing that in game. Just invert the ones that need it, click save and you should be good.
    And yes, I find clicking "Play" is always better than not :D
  4. izhangt
    - 91Coins
    u know where can i make the axis inverted for aceleration /brake?
    153,734Coins
    The Dir box in Axis Assignments being checked orange or not determines which way each axis moves, it sounds like whatever you have set for surge is reversed to what it should be.
  6. Alessandro TheDarkness
    Alessandro TheDarkness New Member
    - 55Coins
    here isn't work. The Data is sent and received, but the motion system shakes randomly and so strong
  7. p00ky
    p00ky Active Member
    Wales
    392Coins
    I got that when I first tried it but it was because I had entered a port number into simtools..... dont.
    it should look like this.....
    Only put ip and port number into the game, not into simtools. Hopefully that helps.
  8. izhangt
    - 91Coins
    Great, now works, and yes is very good motion and Unoptimiced game, thx all for the help
  9. Garry Samson
    Garry Samson New Member Gold Contributor
    - 55Coins
    Question, will there be a dedicated plugin for this new game or we will just use the Forza Motorsport 7 plugin for it? Thanks !!!
  10. Antonio Martin
    Antonio Martin New Member
    16Coins
    Motion platform
    I can't reverse acceleration/braking in the assignment axis, can someone explain it please?
    153,734Coins
    Please see my earlier comment:
  12. Yinger
    Yinger New Member
    54Coins
    Wanted to follow back up on this topic. I was able to get it working. What I had to do-
    Uninstall forza 7
    Setup the udp data as instructed
    Set simtools v3 to auto detect game
    Launch Forza Motorsport
    Hit play on the forza 7 sim tools plugin after FM was running.
    And enjoy game.
  13. Syrian
    Syrian New Member Gold Contributor
    - 10Coins
    SCN5
    Which "play" button are you talking about please?
    I'm using Simtools V3 beta and I can't find this button.
  14. Yinger
    Yinger New Member
    54Coins
    In simtools V3 there is a play Icon |> on the game tile. After you load FM go back to simtools and double click forza 7 like you were going to launch it through simtools. Because you have uninstalled it there is nothing to launch but Simtools will then start reading the UDP output for FM.
    I cant post screens shots yet (too new of an account) so hopefully that helps.
  15. Yinger
    Yinger New Member
    54Coins
    As a follow up - If you do port forwarding to Simhub for dash or other accessories this works as well.
  16. Brikivann
    Brikivann New Member Gold Contributor
    - 44Coins
    Hello, I can't give movement to my 2dof simulator for FM8. I don't have FM7, but I have tried to follow the steps indicated in their plugin and then configure the hud as indicated here for FM8. The Tuning center does not receive data. Can someone tell me the steps to follow to configure it. I have tried many combinations but I can never get data to the Tuning center. I'm using Sintools 2. I hope someone can help me, playing without movement seems very unreal to me.
  17. izhangt
    - 91Coins
    Only works with simtools v3 u must press play Doble click
  18. Brikivann
    - 44Coins
    Thank you so much. In the morning I install simtools v3 and try again
  19. Pascal75
    Pascal75 New Member
    germany
    16Coins
    HI,
    thanks for the new Forza Motorsport 2023 Plugin, works great, with wind sim!
    BR
    Pascal.
  20. Garry Samson
    - 55Coins
    I second! Thank you so much for the new plugin !!!
