Forza Motorsport (8)
Discussion in 'Other Racing Games' started by Pascal75, Oct 5, 2023.
  1. Syrian
    Syrian New Member
    0Coins
    SCN5
    Where can we download this plugin please?
    152,213Coins
    +11,065 / 56 / -2
  3. izhangt
    izhangt Member Gold Contributor
    - 91Coins
    2DOF, Motion platform
    It's not new
  4. D.C. Moore
    D.C. Moore New Member
    NC USA
    162Coins
    AC motor, 4DOF
    Will any of this work with Simtools version 2? I have an older simulator that uses version 2 only as far as I know.
    152,213Coins
    +11,065 / 56 / -2
  6. D.C. Moore
    NC USA
    162Coins
    AC motor, 4DOF
    I have a FM7 plugin that I downloaded last year so I think its the most recent one. Thank you in advance for your patience with me. I have to use Simtools ver 2, usually when a game connects to Simtools the bar across the top in the game manager goes from green to blue and shows "Game Running" That is what happens when I start FM7. That does not happen when I run the new FM. I have done the port forwarding and Simtools works for FM7 and FH5. I do not have a PLAY button in Ver 2. I have read through the forum posts several times and I am still clearly missing something. It appears that I need a patch that is specific to the new FM in order for the game manager to see that the new game is running instead of FM7.
    152,213Coins
    +11,065 / 56 / -2
    I
    I don't use the plugin so others are better placed to assist, as it does have additional and network specific configuration requirements.
  8. Trent Robinson
    Trent Robinson Member
    Systems Engineer
    354Coins
    I have found that the Forza Motorsports 8 Console plugin doesn't appear to work. It causes random vibration and motion out of my rig. Switching to using the Horizon 5 plugin allows for proper control of the rig even with FM8. Would be happy to help in any way I can to troubleshoot.
