Forza Motorsport (8)
Discussion in 'Other Racing Games' started by Pascal75, Oct 5, 2023.
  1. Syrian
    Syrian New Member Gold Contributor
    - 10Coins
    SCN5
    Where can we download this plugin please?
    154,735Coins
    +11,213 / 57 / -2
  3. izhangt
    izhangt Member Gold Contributor
    - 91Coins
    2DOF, Motion platform
    It's not new
  4. D.C. Moore
    D.C. Moore New Member
    NC USA
    180Coins
    AC motor, 4DOF
    Will any of this work with Simtools version 2? I have an older simulator that uses version 2 only as far as I know.
    154,735Coins
    +11,213 / 57 / -2
  6. D.C. Moore
    NC USA
    180Coins
    AC motor, 4DOF
    I have a FM7 plugin that I downloaded last year so I think its the most recent one. Thank you in advance for your patience with me. I have to use Simtools ver 2, usually when a game connects to Simtools the bar across the top in the game manager goes from green to blue and shows "Game Running" That is what happens when I start FM7. That does not happen when I run the new FM. I have done the port forwarding and Simtools works for FM7 and FH5. I do not have a PLAY button in Ver 2. I have read through the forum posts several times and I am still clearly missing something. It appears that I need a patch that is specific to the new FM in order for the game manager to see that the new game is running instead of FM7.
    154,735Coins
    +11,213 / 57 / -2
    I
    I don't use the plugin so others are better placed to assist, as it does have additional and network specific configuration requirements.
  8. Trent Robinson
    Trent Robinson Member
    Systems Engineer
    360Coins
    3DOF, AC motor, Motion platform
    I have found that the Forza Motorsports 8 Console plugin doesn't appear to work. It causes random vibration and motion out of my rig. Switching to using the Horizon 5 plugin allows for proper control of the rig even with FM8. Would be happy to help in any way I can to troubleshoot.
  9. D.C. Moore
    NC USA
    180Coins
    AC motor, 4DOF
    I know this is a long time coming but I just saw this, I was away for a while. I have a new computer running the sim but I still cant get the FM7 plugin to work. Im still using Simtools 2 and it appears that Simtools does not see the plugin because its coded to another game that being FM7 is there a way for me to trick simtools into using the same plugin for two separate games
  10. long16652
    long16652 New Member
    - 220Coins
    You need to first set the in-game output to port 4123 on 127.0.0.1, and then select the corresponding plugin for simtools v2 in the game manager, and press the play button behind the plugin to receive game data properly.
  11. D.C. Moore
    NC USA
    180Coins
    AC motor, 4DOF
    Yeah, My sim is working fine with FM7, mine uses a different IP address but does use the 4123 port for all of the Forza games. I'm trying to get it to work with FM8 because as far as I know there is no FM8 plugin for the ver2.6.1 of Simtools. I'm trying to trick Simtools into using the FM7 plugin to run FM8.
  12. long16652
    - 220Coins
    This seems unlikely, good luck to you.
    My simtools v2 no longer works after the major update of Raceroom, and running Raceroom will also cause simtools to automatically exit.
