SimTools v3 Public Beta
  1. deeph46
    deeph46 Member
    623Coins
    2DOF, 3DOF
    Will try to mix them, Nice!!
    I have used only Pitch last time.
  2. early_m
    early_m Active Member
    Chelmsford
    857Coins
    Since the last update simtools stops sending data after about 10mins. No motion, dash, vibe. It hasn't crashed and the plugin is still running, but nothing. Stopping and starting the plugin is required to get it to work again. Anyone else have a similar issue?
  3. yobuddy
    50,757Coins
    What game plugin are you using buddy?
  4. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    109Coins
    I am trying v3 with the f1 2022 plugin. But it is not working. V2 works. I tried another game that did work. The motors wont move with f1 2022. The only thing i can think of that i use ea play for f1 2022. Because when i start f1 2022 via simtools it will open steam and says no license. Is this an issue? When trying v2 again it does work. I also tried different udp settings like 2022, 2018 legacy. Please help.
  5. Blame73
    Blame73 Well-Known Member
    8,303Coins
    Try this:
  6. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    109Coins
    Thanks, the game launches but when I am driving the car the motors are not moving. When I switchback to Gamemanager 2.6 everything works fine and the motors are moving and responding to the F1 2022 race game.
    I used the 2022 and the 2018 plugin, changes the settings in telemetery setup, patched the plugin, raced 5 laps to get the My games directory, did the patch etc. start the F1 2022 game but the motors are not responding. Switch back to gamemanager 2.6 everything works fine. Installed Race Room, setup Simtools 3 with the RaceRoom plugin and yes the game is working and the motors are responding.
    Ran the axis test and the movement test both work fine in Simtools 3
    see link to the video
    https://drive.google.com/file/d/1J9mFXrefvGZ6wJsAteDFp6XOwFO6mT0_/view?usp=sharing
  7. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    109Coins
    Draging the desktop shorcut will cause the simtools to crash when i try to start it by double clicking the play button.
  8. yobuddy
    50,757Coins
    My guess is you have 2018 output on for f12022 (this is what the SimTools v2 plugin used for output)
    SimTools v3 thou, the f12022 game plugin uses the proper 2022 output for the game, so please make sure the game has it's output set to 2022 for SimTools v3.
    It just creates a 1:1 shortcut, so if it works on the desktop, it should be able to launch the game.
    Does the shortcut work from the desktop?
  9. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    109Coins
    See screemshots. The error says path not found. Not sure why it wont start. Maybe has to do that i have the ea play version with game pass? When using settings from game with 2018 udp it works with simtools v2.
  10. yobuddy
    50,757Coins
    Drag-Drop the games exe on the banner and see if that works.
    Yep, 2018 output for f12022 in v2 and 2022 output for f12022 in v3.
  11. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    109Coins
    I think I cannot start it from shortcut only via ea play. Saw the screenshot? It is on 2022
  12. yobuddy
    50,757Coins
    EA play is available for PC via Steam.
    The port should be 4123.
    (These are not the settings that get set when you patch the game with v3 is all)
  13. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    109Coins
    THanks a lot that worked! really weird why the patch wont change the settings. Is send rate 60 oke? Or should this also be different value?
  14. yobuddy
    50,757Coins
    60 is fine buddy, take care!
  15. Jubila76
    Jubila76 New Member
    - 134Coins
    1 - In motion settings / profile selection, (auto profile mode). If there is too much profiles (easy with Auto mode), the menu go beyond the screen and we can't scroll it.
    2 - The program crashs if you copy a profile to one with the same name (silly but.... still).
    (the Auto profile option is a very good idea by the way ! :))
  16. yobuddy
    50,757Coins
    1) yes its a known issue, It's a custom control that needs more work when I can find some time.
    2) I will fix the same name problem.
    Thanks for the report!
    Take care,
  17. ResidentRob
    ResidentRob New Member Gold Contributor
    - 12Coins
    3DOF, Arduino, 4DOF, 6DOF
    Hi Guys
    New to the sim world and hoping someone can help me. I've started with NoLimits2 before I venture into more sims. I've had this working no problem using simtools version 2 Pro, now I have V3 Beta and can get all motors working great in testing. I changed the target exe name in properties to "C:\Program Files\NoLimits 2\64bit\nolimits2app.exe" --telemetry --telemetryport=15151 and dragged it over the game banner, but when I double click to start up this is the error I receive. I have spent hours trying to find a solution. Here's hoping someone has solved this before. Please ignore the blue error light as this refers to one of the motors disconnected
    Cheers
    System.ComponentModel.Win32Exception (0x80004005): The system cannot find the path specified
    at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
    at System.Diagnostics.Process.Start()
    at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
    at SimTools.Frm_SimTools._StartGame_IfNotRunning(String OnlineID, List`1 ProcessesNames)
    at SimTools.Frm_SimTools._StartEngine_Step1(Int32 PluginIndex)
    at SimTools.Frm_SimTools.PicMenu_ClickedButton(Int32 ButtonID, ButtonClicked ButtonClicked)
    at MyPicMenu.MyPicMenu.MyPicMenu_MouseDown(Object sender, MouseEventArgs e)
    at System.Windows.Forms.Control.OnMouseDown(MouseEventArgs e)
    at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.9181.0 built by: NET481REL1LAST_C
    SimTools
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/SimTools.exe
    ZSAdwIHCIcopVggkSmaBayAFsGujB
    Assembly Version: 0.0.0.0
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    Win32 Version: 4.8.9172.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    Win32 Version: 4.8.9032.0 built by: NET481REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Game_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Game_PluginAPI_v3.DLL
    Axis_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Axis_PluginAPI_v3.DLL
    Interface_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Interface_PluginAPI_v3.DLL
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.9032.0 built by: NET481REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    MyVibeButtons
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyVibeButtons.DLL
    MyTuningButtons
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTuningButtons.DLL
    MyCrashButtons
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyCrashButtons.DLL
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    Tool_AddonAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Tool_AddonAPI_v3.DLL
    Default_AxisPlugin
    CodeBase: file:///C:/Users/User/AppData/Local/SimTools3/AxisPlugins/Default_AxisPlugin.dll
    Default_InterfacePlugin
    CodeBase: file:///C:/Users/User/AppData/Local/SimTools3/InterfacePlugins/Default_InterfacePlugin.dll
    Serial_InterfacePlugin
    CodeBase: file:///C:/Users/User/AppData/Local/SimTools3/InterfacePlugins/junk1.remove
    VirtualOutputAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/VirtualOutputAPI_v3.DLL
    Default_VirtualPlugin
    CodeBase: file:///C:/Users/User/AppData/Local/SimTools3/VirtualPlugins/Default_VirtualPlugin.dll
    GameDash_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/GameDash_PluginAPI_v3.DLL
    Default_GameDashPlugin
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/User/AppData/Local/SimTools3/Dash/Plugins/Default_GameDashPlugin.dll
    CSCore
    Assembly Version: 1.2.1.2
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/CSCore.DLL
    MyButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyButton.DLL
    MyTuningScrollBar
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTuningScrollBar.DLL
    MyBannerStopButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyBannerStopButton.DLL
    MyTextBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextBox.DLL
    MyScrollBar
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyScrollBar.DLL
    MyDropBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDropBox.DLL
    MyCheckBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyCheckBox.DLL
    MyExport
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyExport.DLL
    MyDashControl
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDashControl.DLL
    MyTextBox_MinMax
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextBox_MinMax.DLL
    MyRepoInstall
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRepoInstall.DLL
    MyNewName
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyNewName.DLL
    MyProfileComboBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyProfileComboBox.DLL
    MyNotifyMarker
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyNotifyMarker.DLL
    MyPicMenu
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyPicMenu.DLL
    MyRadioButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRadioButton.DLL
    MyOneClick
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyOneClick.DLL
    MyLoadButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyLoadButton.DLL
    MyUpDown
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyUpDown.DLL
    MyParkingLocation
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyParkingLocation.DLL
    MyAxisLimiting
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyAxisLimiting.DLL
    MyRepoButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRepoButton.DLL
    MyPatchingNotes
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyPatchingNotes.DLL
    MyTopMenu
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTopMenu.DLL
    MySaveButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MySaveButton.DLL
    MyOnOffSlider
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyOnOffSlider.DLL
    MyFolderBrowser
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyFolderBrowser.DLL
    MyMainMenu
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyMainMenu.DLL
    MyDatePicker
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDatePicker.DLL
    MyRegBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRegBox.DLL
    MyMessageBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyMessageBox.DLL
    MyTextPrompt
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextPrompt.DLL
    System.Management
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    Generic2DAdvanced_AxisPlugin
    CodeBase: file:///C:/Users/User/AppData/Local/SimTools3/AxisPlugins/junk1.remove
    MyFilterButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyFilterButton.DLL
    System.Web
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
    Network_GameDashPlugin
    CodeBase: file:///C:/Users/User/AppData/Local/SimTools3/Dash/Plugins/Network_GameDashPlugin.dll
    Serial_GameDashPlugin
    CodeBase: file:///C:/Users/User/AppData/Local/SimTools3/Dash/Plugins/Serial_GameDashPlugin.dll
    Virtual_GameDashPlugin
    CodeBase: file:///C:/Users/User/AppData/Local/SimTools3/Dash/Plugins/Virtual_GameDashPlugin.dll
    NoLimits2_GamePlugin
    CodeBase: file:///C:/Users/User/AppData/Local/SimTools3/GamePlugins/junk1.remove
    enabled.
    For example:
    <configuration>
    </configuration>
  18. flipflop
    flipflop Member Gold Contributor
    Swansea
    382Coins
    3DOF, Arduino
    Sorry for such a basic answer to what looks incredibly complicated problem, but I notice you have an update to windows pending and is the blue dot in the lower right hand corner of the screen a notification message?
    I found problems could occur with these left unopened or not updated under simtools v2. It may be a very simplistic answer but it has worked for me in the past.
  19. ResidentRob
    - 12Coins
    Hi FlipFlop
    Thank you for the reply. Windows has been updated but still didn't work. I've now installed and got the sim working with F1 2021 with the Xbox series X so at least that's a bonus
    Cheers
    Rob
  20. yobuddy
    50,757Coins
    @ResidentRob,
    The game plugin actually make a launch shortcut, was the game not launching?
    Uninstalling the game plugin and restarting simtools, then re-installing the game plugin should fix the launch issue.
    Please let me know how it goes buddy.
    Take care!
