SimTools v3 Public Beta
  1. ROBERT E SMITH
    ROBERT E SMITH New Member Gold Contributor
    136Coins
    JRK
    I'm trying to figure out why this doesn't work. I know this is where the IL-2.exe is. But it won't patch.
    What am I doing wrong? I tried running the game but that didn't doing anything. Screenshot (3).png Screenshot (4).png Screenshot (5).png Screenshot (8).png
  2. yobuddy
    51,523Coins
    Please select the "IL-2 Sturmovik Battle of Stalingrad" folder.
  3. ROBERT E SMITH
    136Coins
    JRK
    I only have " IL-2 Sturmovik great battles" it's the latest update of IL-2
  4. ResidentRob
    ResidentRob New Member Gold Contributor
    - 12Coins
    3DOF, Arduino, 4DOF, 6DOF
    Hi YoBuddy
    I've tried this and still doesn't launch, I've even tried removing the plugin then restarting the pc and then adding again. The image i posted earlier is the same response when trying to launch the game from simtools. I can click directly on the game from the desktop and it will launch fine just not with simtools and then no movement. I went back to V2 and it works fine so I'll just have to do that when I want to use it
  5. yobuddy
    51,523Coins
    I'm guessing you mean a shortcut for the game?
    If so, please drag-drop the shortcut over the game in SimTools v3 (like in the pic below)
    (Then when you launch the game in v3, it will use the new shortcut)
  6. yobuddy
    51,523Coins
    The "IL-2 Sturmovik great battles" folder should work too.
    (The plugin is looking for: The path you give it and \data\startup.cfg)
  7. ROBERT E SMITH
    136Coins
    JRK
    I tried that and it still didn't patch. I could only go down the path to data. I couldn't select startup.cfg, it is there though.
  8. ROBERT E SMITH
    136Coins
    JRK
    You know when I tried to patch it said it didn't patch, but when I shut v3 down and then restarted, on the home page it shows the banner for IL-2. So i guess it did work. Thank you for the help!
  9. ROBERT E SMITH
    136Coins
    JRK
    I meant to say the banner was on the v3 home page. When I put the mouse over it, it was working!
    When I clicked on the wavy lines it went right to motion settings.
  10. ivan jack
    ivan jack Member
    412Coins
    EA sports WRC Rally is out now and would be awesome to try it with motion. :D
  11. yobuddy
    51,523Coins
    Unfortunately it seems they have removed motion output for anything but dbox at release.
    (Although they did send out a how-to for telemetry, it seems it's simply not there yet, and can't be turned on.)
    Here is a note from them...
    "D-BOX motion will be supported at launch. Additional UDP will be supported in an upcoming patch. When we have more info to share we will do so."
  12. ivan jack
    ivan jack Member
    412Coins
    Thank you! hope this will be resolved by EA soon.
  13. zhai1987
    zhai1987 Member
    320Coins
    2DOF, 3DOF, AC motor
    Brother, recently SIMTOOLS V3 doesn't seem to open and reinstall!
    153,722Coins
    Any error messages or unrelated system changes?
  15. zhai1987
    zhai1987 Member
    320Coins
    Do you need to connect to the network to install SIMTOOLS V3? It takes a long time each time, or it is stuck!
  16. yobuddy
    51,523Coins
    Yes, you need online access, as the installer pulls the newest version from the server for the installation.
  17. yobuddy
    51,523Coins
    EA WRC game plugin posted
    This plugin uses the telemetry patch found at racedepartment.com, as the native telemetry is not enabled yet in the game. When EA turns on native telemetry for the game, we will update the plugin to use it.
    The Data Page for the game can be found here:
    https://simtools.us/plugin/?varname=872&color=0e97dd
    • Winner Winner x 6
  18. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    wow, many thanks Yobuddy!
  19. scottlolo77
    scottlolo77 New Member
    632Coins
    2DOF, AC motor
    Hello.the plugin motogp18 is not included in simtools v3?i haven t found it.best regard.
  20. tazerface
    tazerface Member
    Cologne, Germany
    173Coins
    I am using simtools v3 mainly for GT7 on PS5, so my PC is just running in background, not even attached to any monitor, thus inconvinient to access out of the simrig.
    Therefore I'd love to see an option to set additional hotkeys, like:
    1. to start the game / run simtools
    2. to adjust in-game "profile intensity"
    Implementing this the same way "turn off" hotkey can be activated in the settings would be sufficient.
    Could we please get this feature for an upcoming v3 release?
    Many thanks!
    David
