SimTools v3 Public Beta
  1. ivan jack
    ivan jack Member
    412Coins
    After updating WRC23 in steam motion stopped working. I uninstalled plugin , restarted Simtools, Installed the plugin again - no motion. motion only works now in testing mode.
  2. Carl
    Carl New Member
    Paris 75018
    79Coins
    Hello everyone, I'm trying to drag and drop the content manager for Assetto Corsa but it's not working:confused:
    Anyone have a solution?
  3. levers
    965Coins
    Hi @yobuddy ,
    It seems that if the parking feature is being used and you test the axes, the actuators still jump to the centre position at full speed but then return to the park position at the controlled speed, thanks.
  4. yobuddy
    50,750Coins
    Can you tell me what is says in the error logging section of v3?
    I can see that you have an error, as the little blue pen is visible in the pic.
    (You could also try dragging the exe for content manager over the banner, I bet that works.)
  5. yobuddy
    50,750Coins
    Seems the update took out the temporary telemetry solution.
    We will work on update for the plugin (with official telemetry output) today, hang tight.
    • Optimistic Optimistic x 1
  6. Carl
    Carl New Member
    Paris 75018
    79Coins
    Hi Yobuddy,
    the error message comes from the ardwino uno card which is not connected.
    but for content management it doesn't work
  7. deeph46
    deeph46 Member
    623Coins
    2DOF, 3DOF
    I believe you don't need to drag n drop CM app to banner. All you need to do is install the Simtools AC plugin and done.
    I just did that and it works as it should.
    EDIT: If you double clicks the CM you should get the rig moves.
    EDIT2: Sorry but have you enable "Auto detect launched games"?
  8. Carl
    Carl New Member
    Paris 75018
    79Coins
    Hi Deeph46,
    if I understood correctly I can launch CM and the platform will move once in the race?
    however on my PC the automatic detection of launched games is not activated in SimTools, should I activate it?
    I will do my test tomorrow and follow your advice:thumbs
  9. deeph46
    deeph46 Member
    623Coins
    2DOF, 3DOF
    Hi Carl,
    When you (just) open CM app your rig should be moved if you enable auto detect launched games.
    You should activate it, it makes ease the process:cheers
  10. yobuddy
    50,750Coins
    @Carl,
    Are you running SimTools as admin?
    (As it will not work if you run SimTools as admin is all)
  11. MatteKarla
    MatteKarla Member Gold Contributor
    20Coins
    Simulator
    1. Commercial or DIY: DIY
    2. DOF (Number of axles ): 2dof
    3. Actuators (DIY, SCN5 etc.):
    4. Interface (Arduino, SCN, Mega, DIY etc. ): Arduino UNO
    SimTools
    1. Version: 3 beta
    2. Game Plugin: Dirt Rally 2.0
    3. Settings (Relevant ones)
    4. SimTools Licence type: (should be Pro) Pro
    Assetto Corsa, EA WRC 23 etc. works, but DR2.0 does not work in SimTools V3 (however it works in SimTools2).
    When the game starts left actuator goes down so I'm tilted back and to the left. And it stays in that position.
  12. Roberto Guzman
    Roberto Guzman New Member
    10Coins
    2DOF, Motion platform
    Hello, I have Njmotion 2dof, EA Sports WRC was updated yesterday and my system stopped working, when will there be an update in Simtoll3 for said game? Thank you.
  13. Peln
    Peln New Member Gold Contributor
    55Coins
    First of all, thank you very much for your effort with this plugin. Now that the UDP update is out, I'm wondering whether it still works or has it even been updated? Greetings ✌️
  14. richdelta9
    8,860Coins
    We pushed an update to WRC 2023 and added roll, pitch, yaw, roll rate, pitch rate and yaw rate.
    Let us know if you find any bugs.
    • Winner Winner x 3
  15. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    438Coins
    thank you! you guys rocks!!
  16. ivan jack
    ivan jack Member
    412Coins
    just woke up to this! Sweet! I'll drink my coffee and start to test! Cheers!
  17. richdelta9
    8,860Coins
    Bug found in WRC 2023 and fixed for sway surge and traction loss. Changed direction for a few of the values too.
  18. ivan jack
    ivan jack Member
    412Coins
    I found a problem on surge . in game braking and accelerating swap around after driving a little. sim starts to brake when it needs to accelerate, then, after driving for a little they swap back again and works normal and so on.
  19. p00ky
    p00ky Active Member
    Self Employed Laser Cutter
    Wales
    392Coins
    Sadly I dont appear to be getting values through to simtools at all. Any suggestions?
    **Edit
    Heh, I post this.... think lets restart simtools.....& voila, Im a fool :D getting values now.
  20. p00ky
    p00ky Active Member
    Wales
    392Coins
    I was over on the EA Answers site mentioning simtools updated plugin & I was asked a question which I offered to pass on.
    the statement, as asked......
    "I took a look, the plugin is overwriting the whole config file with his own instead of appending its own config. This defeats all the progresses about multiple UDP feeds which are now available in WRC. Missed occasion of a smoother "third party application cohabitation"."
    Is this the case? & if so is it possible to make a change to the plugin to append the config changes rather than overwriting?
