F1 2022 v1.0
F1 2022 GamePlugin for SimTools
  1. noorbeast
    152,201Coins
    +11,065 / 56 / -2
    The FAQs may be of use: https://xsimulator.net/community/faq/codemasters-use-simdash-and-simtools-simultaneously.143/
  2. yobuddy
    51,066Coins
    Just a note, the SimTools v3 version of F1 2022 game plugin does use the 2022 format, and also has udp relay built in should that help.
    Take care!
  3. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    110Coins
    Thanks, the game launches but when I am driving the car the motors are not moving. When I switchback to Gamemanager 2.6 everything works fine and the motors are moving and responding to the F1 2022 race game.
    I used the 2022 and the 2018 plugin, changes the settings in telemetery setup, patched the plugin, raced 5 laps to get the My games directory, did the patch etc. start the F1 2022 game but the motors are not responding. Switch back to gamemanager 2.6 everything works fine. Installed Race Room, setup Simtools 3 with the RaceRoom plugin and yes the game is working and the motors are responding.
    Ran the axis test and the movement test both work fine in Simtools 3
    see link to the video
    https://drive.google.com/file/d/1J9mFXrefvGZ6wJsAteDFp6XOwFO6mT0_/view?usp=sharing
  4. yobuddy
    51,066Coins
    It will work for whatever version of SimTools you last patched the game with.
    (as v3 and v2 use different ways to get the data.)
  5. Rodrigomarcos1978
    Rodrigomarcos1978 New Member
    Brasil
    97Coins
    Can someone help me ?
    I formatted and reinstalled everything on my computer. Now I can no longer install the plugin for this game.
    I already played for hours, doing several complete laps.
    I am selecting the correct game SAVE folder, but it does not accept it. C:\Users\Computer\Documents\My Games\F1 22
    I tried both Simtools version 2.6 and version 3.0.
    Can anyone help?
  6. yobuddy
    51,066Coins
    What is the error logging message you have in v3?
    I can see a little blue pen in the pic is all.
    Also, what's in the hardware settings folder I see in the pic buddy?
  7. Rodrigomarcos1978
    Brasil
    97Coins
    Hello..
    The only error message is the one in the attached image.
    Inside My Games there is the F1 22 folder and inside there is another folder: hardwaresettings \
    where there are two files:
    hardware_settings_config_VR.xml
    hardware_settings_info.xml
  8. yobuddy
    51,066Coins
    Do you only have VR or something, no monitor hooked up?
    Usually there is a 'hardware_settings_config.xml' file in that folder also is why I ask.
    I should be able to push an update to the plugin to make it work thou.
  9. yobuddy
    51,066Coins
    @Rodrigomarcos1978,
    The F1 2022 plugin has been updated, and should work for you now.
    Let me know if you have problems buddy.
    Take care,
  10. Rodrigomarcos1978
    Brasil
    97Coins
    Hello.. Yesterday, after your tip I was able to use it. Thank you very much !!! What I did was just play a game using the monitor. I usually play using VR only, so I hadn't done any monitor-only racing. It worked perfect!! thanks
  11. sci666
    1,220Coins
    is there a plugin for F1 2023 ??? because it has a 60% discount on steam yet
    152,201Coins
    +11,065 / 56 / -2
  13. sci666
    1,220Coins
    152,201Coins
    +11,065 / 56 / -2
    Yes both v2 and v3 can be installed on the same machine, and use the same license key.
