Lesson SimTools v3 - 3D Wind Dash Example (with Arduino Sketch)
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Jun 19, 2023.
  1. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    111Coins
    S<sf1><sf1> was the solution, thanks again
  2. Jonasmb2
    Jonasmb2 New Member
    31Coins
    I'm trying to use my sim wind in simtools3, but without success, I use a shild L293D engine, just a cooler connected to the M1, any idea how I can get a script that works?
  3. yobuddy
    51,521Coins
    What script did you used to use buddy?
    We can probably find how to drive it in v3 is all.
  4. Jonasmb2
    Jonasmb2 New Member
    31Coins
    I tried to use the one posted in the discussion, but I saw that the motor shield is different, I would like to know if there is any script for my motor shield for just one cooler connected to M1
  5. Howard Yang
    Howard Yang New Member Gold Contributor
    West Covina, CA
    - 138Coins
    What size diode do I need to installed in between the motors if running the 12V 6A 270CFM inline Fan? I circled that in Orange
  6. yobuddy
    51,521Coins
    Probably depends on the size of fans you want to use, but I can't see a fan outputting that much reverse power when the power goes off.
    Here is a link to the article the pic came from.
    http://adam-meyer.com/arduino/rfp30n06le-arduino
    "We will need a diode fast enough to react to the kickback, and strong enough to take the load. A rectifier diode like the 1N4001 or SB560 should do the job."
    Take care!
  7. Howard Yang
    West Covina, CA
    - 138Coins
    thank you. And if I use a bigger fan then 2A, say the 6A fan bilge inline fan that you’re using in the video, which motor control board would you recommend and do you happen to have a wiring diagram?
  8. yobuddy
    51,521Coins
    You would simply make this circuit two times, one for each fan buddy.
  9. Howard Yang
    West Covina, CA
    - 138Coins
    Would the fan connect direct to the Arduino board without a motor control board?
  10. yobuddy
    51,521Coins
    The circuit is your 'motor control board' if you will.
  11. Stahlwolle
    Stahlwolle Member
    268Coins
    The example video shows that in a right turn the wind from the left fan decreases. Shouldn't it actually be the other way around?I mean, if my car were to turn completely to the right, the wind would only come from the left, as an extreme example...
    153,710Coins
    Your example would be the case if the wind was external and from a fixed direction, rather than generated by a body moving through air.
    But think an aircraft wing, which produces lift via the air on the longer curved upper section creating a low pressure, and the shorter flatter side creating the higher pressure.
  13. Stahlwolle
    Stahlwolle Member
    268Coins
    I Always hope to feel no wind when using an aircraft Better keep windows shut.
  14. josiclei souza sausen
    josiclei souza sausen New Member
    2Coins
    This 30n06L driver can I use another model here in my city I'm not finding?
  15. Josemanuelrm
    Josemanuelrm New Member
    valencia
    65Coins
    Hello, forgive my ignorance, I have connected it as shown in the diagram... I understand that the 12V goes directly to the fan and with the diagram... I have configured the Arduino and on pin 9 but the fan is always on when I supply it with 12V... shouldn't it be stopped?
  16. yobuddy
    51,521Coins
    What does your output settings look like?
  17. Josemanuelrm
    valencia
    65Coins
    I don't understand what you're referring to?
    Should the system be stopped when I plug in the power supply, or should the fans turn on?
    Does the green connector have to go to pin 3? Or to the pin we specify in the code?
    thanks
  18. Josemanuelrm
    valencia
    65Coins
    I already have it working, but the connection diagram was incorrect.
    Now let's see how the settings change to improve the fan speeds.
  19. squirrel_captain
    squirrel_captain New Member
    12Coins
    DC motor, Arduino, 4DOF
    Hello everyone,
    For awhile now ive been trying to get the Speed fans running, ive used various sketches and serial debugging tools, but i can't seem to get Serial based fans working at all. Running via UDP I got it running with a R4 Wifi, but via serial with an R3 no luck what so ever.
    It's not Fan wiring side of the house (that's all grand) i can't seem to get any output from SimTools V3 for the speed fans, where as my Motion Simulator platform is perfect from hardware side (using R3's for them aswell)
    Ive quadruple checked my Dash Interface settings (Port, Baud etc), and tested an entire bunch of output interface settings with corresponding sketches (most from here, but also debugging ones ive created).
    Regardless if i use `S<Sf1><Sf2>` or `S<Sp1><Sp1>` or `S<Sp1>` or even `S255` i don't seem to get any communication with the R3 whatsoever.
    I was debugging with Serial Port monitor initially, however the time period expired, so now switching to new tools to attempt to see the data output.
    I'm sure there's a potential chance I've missed something, or the R3 is broken (also plausible) so im checking in here to see if anyone has any ideas or checklists to follow to rule anything else out.
  20. squirrel_captain
    12Coins
    Reinstalled SimTools, cleared all the previous settings, debugged with com0com to a virtual pair, then also used the virtual interface, and like magic it worked the first go. Not sure if it was a Windows port issue or a weird lock on the serial port, but it works!
