Icy7CE
  1. Rubido-Watson
    Rubido-Watson New Member Gold Contributor
    4Coins
    Is there a way to start the MSFS 2020 plugin with SimConnect_UDP.exe console being minimized e.g. by placing a certain parameter into SimConnect_UDP_config.txt?
  2. yobuddy
    51,524Coins
    @Rubido-Watson,
    I'm guessing your using SimTools v2?
    Know that the SimTools v3 version of this plugin does not use the console at all, so that's one way to get aroudn the "SimConnect_UDP.exe console" thing.
    (SimTools v3 is a free update for all v2 users, and will work with your v2 license.)
    Take care,
  3. Rubido-Watson
    4Coins
    Hi @yobuddy,
    Thanks a lot for your response. Is it versions 1.1.3.0 of the MSFS 2020 plugin that I can also use with SimTools v3? Or is there a specific version of this plugin that needs to be used with SimTools 3? If so, where would I get it from?
    Thank you in advance
    Ralph
    153,734Coins
    SimTools v3 introduces the new plugin repository system, so you can install the plugin using SimTools v3 itself.
  5. aparecido
    aparecido diy 2dof for flight simulator 2020
    MECHATRONIC TECHNICIAN
    BRAZIL
    - 51Coins
    I'm using flight simulator in dof2, I can only move pitch and roll, on the runway the aircraft doesn't make any movement, if there's anyone in the group who can help me, I'd be grateful.
  6. aparecido
    BRAZIL
    - 51Coins
    I have simtools v3
    153,734Coins
  8. aparecido
    BRAZIL
    - 51Coins
  9. aparecido
    BRAZIL
    - 51Coins
  10. aparecido
    BRAZIL
    - 51Coins
    153,734Coins
    You have no Axis Assignment values configured.
  12. aparecido
    BRAZIL
    - 51Coins
    only assigns to axis (a)
  13. aparecido
    BRAZIL
    - 51Coins
    Actually I don't know how to configure it in a and b
  14. aparecido
    BRAZIL
    - 51Coins
    In flight it works well, but on the runway it doesn't make any movement.
    153,734Coins
    B should not be necessary if you are using 6 or less axis, bit please post your configuration for A.
  16. aparecido
    BRAZIL
    - 51Coins
    153,734Coins
    Try adding a little heave for runway effects.
  18. Richard Eaton
    Richard Eaton Member
    241Coins
  19. Brett
    Brett Member
    Engineer
    Carrum Downs Victoria Australia
    156Coins
    2DOF, 3DOF, JRK
    Is there a reason the SimTools v2 plugin is not currently available for download? I have plenty of coins.
    153,734Coins
    Use 250 of your coins here for a week access to all v2 plugins: https://www.xsimulator.net/community/shop/
