Reasonably Priced 100A Motor Controllers
Discussion in 'Motor actuators and drivers' started by Richard Ortengren, Jan 29, 2023.
Tags:
  1. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    Hi
    sorry i cant help you with that but can explaine somthing else going ,down with load and without load
    The load is holded mechanical this load komes upon contactpoint where the gearbox slides.
    When there is a current difference going down with and without load its comming from there gr. Ad
  2. Gadget999
    11,904Coins
    Do you have electromagnetic brakes on your motors ?
    I suggest you reduce the lever arm length
    Also reduce the P number and witness the effect of current
  3. Josh_Possa
    Josh_Possa Active Member
    Catalunya
    555Coins
    2DOF, 3DOF, DC motor, Motion platform
    No, that motors does not have EM brakes. The worm gear box is big enough to hold me when the motor is disconnected from the current so it does not need EM brakes.
    This afternoon I'll drill another hole in one of the levers to check if it will make substancial difference with the current consumption.
    Yesterday I tweaked all the parameters, also the P number from 0 to 70-80 when the motor start moving (still away from the blue line) and the current was the same as when the P value raise to 300, exactly the same.
  4. Gadget999
    11,904Coins
    it appears you have a LOT of friction in your gearboxes
    I would expect them to move with a much smaller P number
    I have a 6dof with similar gear ratios and it falls back down even with no passenger on board
    i suggest you open the gearboxes flush out the grease and refill with oil or a thinner grease
    where the motors brand new when you got them ?
    this one drops down under its own weight -
  5. Josh_Possa
    Catalunya
    555Coins
    I was suspecting that too. There is a lot of friction and also I think to increase the lube quantity/quality. I push with 125 -135 Kg of force and the gearboxes don¡t move even a millimeter. I've write to the seller to ask him about it.
    Yes, the motors are brand new, manufactured in november in fact.
    What do you think about getting more than five times current between the boards and motor compared to the current between PS and board? Is it possible there are reactive power due the PWM?
    Thanks!
  6. Gadget999
    11,904Coins
    a clamp meter is not an accurate way to measure current - it is possible the polarity is changing fast messing up the reading
    i use a 'shunt' that meter that has a gauge - the current moves through the shunt directly
  7. Josh_Possa
    Catalunya
    555Coins
    If you see in the video the clamp is reading the current positive or negative depending on the motor direction (due the sine wave). That changes of polarity aren't fast at all. This is getting me a little bit frustrated.
    Do you think create a new tread exposing the problem will be appropriate?
  8. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    4,964Coins
    for info, my motors eats +- 30A when im on it.
    Also the current higher between the board and the motor is possibly he back emf (regenerative current) that cant go anywhere because you have no batteries.
    Problem doesn't seem to be your board but the current way too high in them. (the itching sound is also an indication of that.)
    Possible that the motor are maybe not efficient at all.
  9. Gadget999
    11,904Coins
    Good advice, fit a battery to remove the regeneration
  10. Josh_Possa
    Catalunya
    555Coins
    Thanks so much for help me. Tomorrow I'll buy a couple of bateries to sum 24V or test it only with 12V. I returned the boards today but I still have a couple of IBT-2 to test without too much load and see.
    If it works the most likely is I'll buy two sabertooth 60A that I see are very configurable. If not.....well...we will see
    Thanks again guys
  11. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    I Dont think there is regeneration with a selflocking gearbox
  12. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    If a wormgearbox can by backdriven or not isnt the greace its the tooth angle
    Every ratio got different efficienty tis does the tooth angle at some point the tooth angle becomes under 3 degree and they become selflocking regards Ad
  13. Josh_Possa
    Catalunya
    555Coins
    Yes I have had read that. A wormgearbox can be moved in one direction (meaning from the motor to the axis) but not in the other direction (trying turning the motor from the axis) so It does not be a problem. BTW The gearboxes are filled with oil, not grease. Also, some mechanical friends told me that the gearboxes efficiency shouldn't be less than 90%, otherwise the gearbox will got very very hot ant it is not the case
  14. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    I am 60my schooltime it was greace and abouth 60% i looked at some wormgearboxes for 750 watt motors with ratio 50 and found 2 wth complete specs 1 efficienty dynamic 68% static efficienty 35% and 2 efficienty dynamic 65% no static efficienty price from the first 500 euro
    fore a 90% efficienty you come at hich efficient planetary gearboxes gr Ad
  15. Josh_Possa
    Catalunya
    555Coins
    Thanks Ad, well the question now is know if the 95Nm output anounced is taking into account the efficiency or not. The seller told me yesterday that they calcule the output torque as follows:
    Torque=9550xpower(KW)/shaft rated speed
    But he does not have the combined motor+GB efficiency at the moment
  16. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    The point is he can thell you what he want. A lott of thenical things have internation standards motor specs isnt one of them.
    A machine fabric got engineers and they know if some one in not thelling the treud he goes on a blacklist
    gr.Ad
  17. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    I made a small mistake motor specs must be motor with gearbox specs isnt one of them
    To by precice one watt is one joule and 1 joule is 1 newton with a speed from 1 meter a second andyou can make NM from N 60 rpm gives a speed from arroud 6.3 meter second devided by 750 youre some where arround 120NM he uses a verry high efficienty
  18. Josh_Possa
    Catalunya
    555Coins
    Hello, today I tested the current consumption with a 85mm lever and a 12V lead car battery and.....nothing changes :(. To be fair this test was with a IBT-2 because I already does not have the 100A boards but the problem stills. LOT of current between IBT and motor and 3 to 5 times less current between the battery and the IBT.
    Theoretically that motor should be able to lift 120Kg at that lever distance but it can't lift more than 25 Kg without shoot up the current exponentially. I already contact with the seller but I suspect this looks bad to me :( That motors are not cheap
  19. Gadget999
    11,904Coins
    If you unbolt the gearbox, how easy is it to turn by hand ?
  20. Josh_Possa
    Catalunya
    555Coins
    You mean separate the motor and gearbox? I haven't done that but I can try. Today I bought two sabertooth 2x60 to test with it and six resistors. If it does not work I'll return the sabertooth and will return or sell the motors. We will see. I I have enough time I'll try to disasemble the gearbox today and check how hard is to turn the motor and the gearbox
