  1. spyrates
    spyrates New Member
    77Coins
    Let's see if someone can give me a hand. The problem is the following and I compared 2 line actuators with 4-wire hall effect, two power cables, but I can't do it with Arduino. help please thank you
  2. Michail
    Michail Member Gold Contributor
    742Coins
    For the moment I am using SMC3 with rotational wheelchair motors in Mode 2. Is it possible to use linear actuator in mode 2 as well? I am searching for linear actuator for Surge axis for a full motion system.
  3. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,350Coins
    Where can I look for the reason that the "target receive" signal level is lower than the "target sent" signal level ?
    On the same components several times I had the correct signal level ie target recive coincided with the signal target sent.
    The question is "where" does the arduino get the value of the "target receive" signal ?
    Problem solved :)
    Load code smc3.ino version 0.6 and load again version 1.0 , arduino working OK :)
  4. Michail
    742Coins
    Short question guys. If I am not anymore remember the pid smc3 settings from current system. And I want the same settings to add to my second arduino with different port, are smc3utils software able to read from the current system? I mean not load from file.
  5. TomServo
    TomServo New Member
    17Coins
    SMC3 question here. I have a 3DOF hydraulic simulator driven by PLCs. I need the arduino to output 50% PWM at middle of ram travel, 0% "down" 100% "up". There is no feedback to the arduino, the sim handles it's own positioning and feedback. Has anyone modified SMC3 arduino sketch for this use? If not, any advice? I would like the responsiveness pot to work also. Ad/Thanks/vance!
  6. TomServo
    TomServo New Member
    17Coins
    I wish I could edit the prior message for clarity. Anyhow to clarify, I need the arduino to pass the position data to the sim via PWM straight. No servo feedback from sim to arduino. Just desired position data straight from pc out through arduino via PWM pins. Ideas/comments/advise/(hopeful look) pre-modified SMC3 arduino sketch? Anything appreciated.
  7. tselehub
    tselehub New Member
    98Coins
    Can I use this code for 1DOF only for traction loss?
    152,736Coins
    +11,096 / 56 / -2
    Yes you can.
  9. JaniK
    JaniK New Member
    Finland
    51Coins
    I have a "problem or feature" in my rig.
    When I have pwmMIN at 40-50 the motor CTC lever can be slightly rotated with hand or by "swinging your body in the seat on the rig"
    If I raise pwmMIN to make the lets say "rubberband deadzone" go away, the motor starts to make whining noise.
    What other settings should I try to play with to get the rig "standing still silently" ?
    Or is it just a feature of the IBT2 and my setup and motor choice..?
    (Edit: misclicked post button halfway )
    152,736Coins
    +11,096 / 56 / -2
    It could be interference, these related threads may be of interest:
    https://www.xsimulator.net/community/threads/smc3-noise-new-computer.15980/
    https://www.xsimulator.net/community/threads/motor-en-smc3-noise-after-switching-psu.17144/
  11. JaniK
    JaniK New Member
    Finland
    51Coins
    My noise is quite similar as the link #2 video about changing power supply and getting noise.
    I changed my SMC3 settings to:
    I just played for about 30 minutes and it just Works.
    The sound is not so bad anymore, it only bothers when not gaming. Yes I got my first 30minutes of gaming (setting axes the correct way for about 20min) and then when the rig does what is expected and not too little or much, I drive it hard for about 10minutes without any errors :cheers
    This thing is awesome !
  12. Gefahren
    Gefahren Member
    Electronics Engineer
    Central Mississippi, USA
    395Coins
    I am having an issue with SMC3. I recently hooked up all three of my motors to check my wiring polarity and such. One of the motors (Motor3) ran silky smooth while the other two (Motor1, Motor2) were very jerky in their movements. I switched the connections on the Arduino board between Motor1 and Motor3 and the jerky motion moved with it. I verified that I had my settings between all the motors the same except the Fpwm being 5kHz on Motor1&2 and 4kHz on Motor3. Only other changes from the default initial settings were the Kp and PWMmax values. I did not change any wire routing or switch the feedback sensor from motor to motor, I only swapped the wires at the Arduino for the feedback and the motor control. Here is two pictures from the SMC utilities screen, you can see that it is driving the PWM signal differently between the two.
    Smooth Motor3 output.
    Can anyone explain what's up with this. At first, I thought I had a noisy sensor, but since whatever is plugged into motor3 is smooth I have ruled that out.
    For reference, this is the base of my platform during a power check before I started wiring the sensors and motor control wires.
  13. noorbeast
    152,736Coins
    +11,096 / 56 / -2
    Can you please post a picture that shows all of your SMC3 settings.
    If 2 of the motors are totally powered off, including unplugging power to the PSUs, does the problem continue, as that should reveal if it were interference?
  14. Gefahren
    Gefahren Member
    395Coins
    Certainly.
    Here are screenshots from it running a square wave output.
    The second is on Motor2, but Motor1 looks the same. upload_2024-3-9_20-28-22.png
    These were taken while driving the same motor/gearbox/sensor, I just switched the connection on the Arduino. I did have to turn the Deadzone up if I was using Motor1 or Motor2. The Sensor inputs for whichever two motor outputs I wasn't using were connected, but the motor controls for those were not hooked up. I had repeated this on all three motors, one at a time while I was trying to figure it out. Also, using an oscilloscope and looking at the analog inputs, they didn't appear to have any extra noise on them. Unfortunately, I managed to kill the IBT_2 drivers I was using, so at the moment I only have one 18V25 G2 driver to use.
    While typing this I did have a thought. Motor1 and Motor2 outputs are run from Timer1 in the Arduino while Motor3 is run from Timer2. Are the PWM calculations different since Timer1 is 16bit and Timer2 is 8bit? Could those default settings it started with just be very wrong for those outputs? I was just trying to verify my center positions and wiring and didn't think to try tuning the PID settings when I saw this since the first one I hooked up was motor3 and everything ran smooth.
    I don't think it will help, but I have some short video clips of the motor running in both conditions, what format should they be in? .mp4 doesn't seem to work.
  15. Michail
    742Coins
    I would like to ask how to find out which fpwm and fpid to choose? How to know which is the right khz frequency?
    Will the ks value influence the all the pid parameter or just the kd value?
  16. Gefahren
    Gefahren Member
    395Coins
    I did figure out why with the same settings in SMC3 gave different behaviors between Motor1, Motor2 and Motor3. In the Arduino code the Integral and Derivative values are calculated differently for Motor3. I don't know if that was intentional or not. You can see from the comments in the code that they used to match.
    For Motor1 & Motor2
    iTerm_x100 = (Ki1_x100 * (long)CumError); // was >>6
    dTerm_x100 = (Kd1_x100 * (long)DeltaPosition); // was <<5
    For Motor3
    iTerm_x100 = (Ki3_x100 * (long)CumError) >> 6;
    dTerm_x100 = (Kd3_x100 * (long)DeltaPosition)<<5;
  17. jarena
    jarena Member Gold Contributor
    126Coins
    hi guys ,
    On the diagram using 2 ITB-2 and Adruino, it shows one power supply to run 2 motors. my question is .. one power supply enough to run 2 24v motors that pull about 4amps each?
  18. Silyn
    Silyn Member
    44Coins
    3DOF, DC motor, AC motor, Arduino, 4DOF
    I'm using a string potentiometer, but the output is pretty fuzzy, any ideas how to clean it up? upload_2024-4-4_15-58-18.png
  19. Josh_Possa
    Josh_Possa Active Member
    Catalunya
    598Coins
    2DOF, 3DOF, DC motor, Motion platform
    Hey, Did you solve your problem?
    I'm building a 3DOF rig too (paused now due the work) and I also have that noisy problem but with all three motors. I tried everything, connecting ferrite cores, using shielded cables, connecting a capacitor between the two motor cables as close to the motor as possible (in fact I opened a motor and installed it inside), connecting two more capacitors between each cable and the motor chasis, connecting a electrolytic capacitor across the hall sensor supply, I tuned all the parameters in SMC to see if the problem gone....it never being solved, the noise is always there and the motors run with a lot of jitter, it is totally unplayable.
    I think the problem are the sensors. The arduino (and also the Sabertooth) amplify the noisy sensors coz I noticed that the yellow line reacts to the little green (feedback) pulses/movements/noise.
    Now I'm waiting for others hall effect sensors apparently better (at least bigge, with cable incorporated and twice the price) than the "cheap" ones I'm using now (around 30€ green sensors).
    We will see, If it does not work probably I'll abandon the project and I'll sell all the components separately.
  20. Gefahren
    Gefahren Member
    395Coins
    I can't say that I 'Solved' the problem, but it's not a problem anymore.
    For me it was that with the same PID settings each motor would act different if they were attached to channel 3 than if they were attached to channels 1 or 2. The 'noise' I was seeing on the was really it just doing the calculations different for the integral and derivative values.
    For position sensors, I'm just using some cheap AS5600 based magnetic encoder boards from Amazon (5 for $17) with a 3d printed housing. All I'm using to hook them up is some cheap three conductor RC servo wiring I had laying around. I've looked at getting some shielded wire, but the feedback that the Arduino is reading has been very clean so far.
    Does your feedback from the sensors look as bad as the picture that Silyn posted before you?
