FlyPT Mover 3.5.8
  1. mm982566
    mm982566 New Member
    US
    56Coins
    3DOF, 4DOF, 6DOF
    This is a small plugin I wrote for Flyptp that supports F1_23 and EA-WCR. Currently, there is only a Chinese explanation available. Sorry for the inconvenience,And then it's completely free
  2. TomKlash
    TomKlash Member
    FRANCE
    425Coins
    2DOF, 3DOF, DC motor, SCN5, Arduino
    I have a few questions about this software which seems super complete and which I am currently testing on my G-SEAT type SIMU.
    1/ How can we apply a different range between the positive and negative values of the acceleration forces longi (for example).
    Like what we do in SIMTOOLS in Game Limits - Min/Max.
    2/ I use the MULTI DIRECT modules to manage the 3 rotary motors of my SIMU. For 1 DIRECT I would like to use the same input value twice to apply different filters when we are on positive or negative ranges. I have the impression that this is not possible. I thought about using longi accel and longi accel with gravity but it's not exactly the same thing.
    Do you have an idea to get around this limitation?
    3/ I am tempted to use the SPIKE filter to attenuate certain peaks when changing gear but this being an active filter (calculated) this induces a small latency. Can you tell what order it is?
    4/ Can we do operations other than summing the values in MULTI DIRECT?
  3. Marco Annunziata
    919Coins
    Hello Pedro,
    what do you think of the idea to release a version without the all the numerous features, which we are aware, that you are working on? That's just to begin to try and test your new creature. Then, over time, it would be nice you would release various small updates with new functions.
    I'm sorry if I permit, it's just an idea
  4. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,338Coins
    Could I please, share a profile for 2DOF motion sim for the DCS game, I am trying to set up a profile using another profile from MSFS2020 but I can't deal with the situation when after the plane is shot down by an anti-aircraft missile the fuselage starts to buck violently, at such a moment sometimes one of the engines rotates the arm well beyond the normal operating range.
    I suspect that the values the DCS transmits when an aircraft is hit by a missile are too high, unfortunately I can't "cut" these values so that my 2DOF works properly.
    Please give me a hint.
  5. pmvcda
    15,781Coins
    Hi Marco,
    The problem is that everything is connected an some base problems persist making it risky to share right now.
    I'm sorry. Hope you understand.
  6. pmvcda
    15,781Coins
    Hi, sorry for the late reply,
    You can use the CROP filter to limit the values.
    CROP(VALUE;minimum value;maximum value)
    there's also CROPMIN and CROPMAX
    For now you have to use two multi directs.
    On next release you can do it:
    Also with vars and conditions you can use the same value multiple times.
    By the way, the simple direct is going to disapear.
    It's using exponential moving average. So you get some latency for strong filtering.
    But... the filter is in action only when "on spike" no while inside the allowed limits.
    In the next release I have some other solutions like :
    DELTAMAX to limit the variation ov value to a maximum
    DELTAFOLLOW to follow a value with a maximum variation allowed (while value not reached increase the specified maximum)
    Maybe I could add something to choose direction also (limit on growing, limit on reducing, limit on both directions)
    For now only subtraction by multiplying with a negative value.
    On the next release, you have variables and conditions.
    You can do filters on variables (instead of VALUE) and use IF THEN ELSE
    Not on the direct module, but on the filters.
    Operations include multiplication (MUL or GAIN) and subtraction (SUB)
    Division is a multiply to avoid problems with division by zero (hmmm, might do something here).
  7. pmvcda
    15,781Coins
    Can you show the rig module please.
    I don't have the Mover with me right now, only tomorrow.
    I say this, because you can limit the actuators movement in the rig module to avoid that problem
  8. Marco Annunziata
    919Coins
    Pedro of course I understand and your honesty and your safely concern is really noble.
    Thank you a lot
  9. Attyla.pl
    Polska
    1,338Coins
    Thank you pvmcda for the answer, no problem I can wait :).
    My motion sim is a standard 2DOF, I found a motion limiting function in the RIG module but for some unknown reason it fails when the plane is hit by a missile.
    During normal flight everything works normally, the range of motion changes according to the imposed restrictions.
  10. dureiken
    dureiken Active Member
    1,254Coins
    Hi
    servers seems down again :(
  11. pmvcda
    15,781Coins
    I will look at it this afternoon.
    But I have a new server for the next release. So this is just temporary.
  12. TomKlash
    TomKlash Member
    FRANCE
    425Coins
    Hello PMVCDA,
    Thanks for your response. Your software is really intressting and the update that you mention it's very promising... Well done !
    Sorry for my english
    So I have some precisions to ask you. There is something that I don't understand.
    For longi acceleration range you said me :
    But I don't be sure that is that I want to do.
    I want to increase the longi acceleration for positive values. It's like a apply a multiplicator coefficient on positive values.
    In SIMTOOLS in define a different game limit for positive and negative values.
    How to do that with FlyPTMover ?
    Cause braking values are more importants than acceleration values but I want to obtain the maximum stroke also on negative than positive actuations.
    If I change the range for non symetrical range the actuator will not stay at middle position (neutral).
    For the subject of SPIKE FILTER.
    You said me :
    I use this filter with this settings, what do you think about that ?
    40 of strenght of spike is it a too important level to avoid latency ?
    In my tests and experimentations I have the idea to use the gear informations gived by the game to limit longi actuations during the gear changing.
    I try to use the passage by gearbox zero value between to gears to decrease the value used to action the longi motor on my SIM RIG.
    Some pictures to explain that :
    Peaks to decrease
    Gearbox change processed
    Result (wrong for negative values)
    Settings
    The problem is to change the sign of Gear value depending on whether we are accelerating or braking.
    The futher LOGIC OPERATION FILTER could allow that.
    For the moment I don't find solution.
    Have you got an idea ?
    A last question/proposition :
    What do you use to realise this 3D graphic preview ? CAD file ?
    Do you want I send you a CAD file from G-SEAT Simulator type to add it or maybe you have also that and planned to do it.
    If I can give you a little help with this, don't hesitate to let me know.
  13. pmvcda
    15,781Coins
    @TomKlash ,
    Sorry, some crazy days. Had to travel. Saw the comment but...
    For the 3D graphics I use Sketchup Make 2017 (old free edition)
    Link here: https://download.cnet.com/sketchup-make-2017/3000-6677_4-10257337.html
    I planned to build a G-Seat and add it in Mover. But nothing is done yet.
    There's some variants to make it. If you want to make the 3D, I might use it. But can't promise (sorry, to much going on).
    Let me explain the spike filters: (there's 3)
    LDYNLP
    It's a linear dynamic exponential low pass filter
    Might have some lag
    LDYNLP (P1;P2;P3)
    • P1 is the value we want to filter
    • P2 is from the variation of value allowed before filtering
    • P3 is the strenght of the low pass (multiplier)
    In this filter the number of samples in the low pass is the variation of value (minus the allowed variation before filtering P2) multiplied by the strenght (P3)
    EDYNLP
    Same as the LDYNLP, but exponential instead of linear.
    Instead of using the variation of value (minus the allowed variation before filtering P2) it uses that variation squared, so the strenght of the filter increases exponentially with the variation (stronger than LDYNLP)
    SPIKE
    SPIKE (P1;P2;P3;P4)
    • P4 is the exponential to use (if 2 it's equal to EDYNLP)
    Same as EDYNLP, but instead of squared we specify the degree
    So for your filter SPIKE(VALUE;0;40;1):
    You are filetring all the values because you use 0 in the range without filtering.
    If you put 10 instead of zero, all the variation up to 10 (or -10) is not filtered.
    Using 40 is a strong multiplier. If the variation of value is 100, is uses 100*40 samples in the low pass.
    In the exponential degree you use 1, so it's the same as LDYNLP.
    If you use 3 the number of samples will be samples*samples*samples
    LDYNLP and EDYNLP exist just to make calculations faster (less parameters and operations).
    Hope I explained the insides of the spike flters in Mover. You can see that if you specify an allowed range, there's no lag because there's no low pass on that range. If the low pass is high, you get the lag, but that's what we want to avoid the spike.
    I think filters in the Thanos and Motion4Sim are different. I did not look at them on purpose to avoid idea contamination...
    An idea to increase the positive values and reduce the negative ones:
    ADD(GAIN(MINCROP(VALUE;0);1.5);GAIN(MAXCROP(VALUE;0);0.5))
    The value range to bit range in the direct module:
    The idea is to map a value to a bit value in the actuator.
    That default/home value is in reality the parking of the actuator.
    So if we map value from -50 to +100 we say that the actuator at bit 0 is for value -50 and maximum bit value is for value +100. It's just a remap.
    You should act on the filter of the direct and adjust the calculated value to your desired range.
    Just think of it this way:
    You have the actuator that can travel from 0 to 200mm (physically).
    You are calculating values that you send to the actuator.
    I can decide that I want position 80 in the actuator to correspond to the zero of the calculated value.
    For that you need to ADD(VALUE;80) to the filter. This means that if you calculate 0, the actuator is at 80mm.
    If you send -100 the actuator is at -20mm (it's out of the 0 to 200 range so it crops to zero)
    If you send 100 the actuator is at 180mm.
    You can also use gain to change the relation or the remap.
    The value range to bit range is just a remap to say that a calculated value is for a specific bit value. It has to do with the hardware and would be ignored if we sent just the position we want.
    In your case it's not a measure, more a empirical value you need to map to the actuator.
    I would say to put it from -100 to 100 or -1 to 1 and do all the math in filters to match those values.
    Actuators in the next release can be controlled by bit value, position (mm or º) or turns.
    In reality they are just remaps.
  14. pmvcda
    15,781Coins
    @TomKlash ,
    Changing the sign of gear change depending on acceleration or deceleration:
    Only thing that I remember right now is to use gear variation (-1 or +1), but there you don't have the acceleration.
    This is why vars and conditions are needed...
  15. Michael Lurie
    Michael Lurie New Member
    18Coins
    Motion platform, 6DOF
    Hi. I had recently some startup errors with flypt. It's a net error related to sound output.
    I traced it down to a conflict with voicemeeter banana.
    Has anyone else noticed such a problem?
    Is there a workaround or fix?
    Michael
  16. Attyla.pl
    Polska
    1,338Coins
    I have a question about the EMAHP filter.
    I am using the profile from Roman Design, the question is why when I tilt the aircraft in the roll axis to the left and leave it in such a position first the program generates the correct movement of the engine lever in accordance with the movement of the aircraft and then generates the movement in the opposite direction to zero and exceeds this value generating the movement of the lever contrary to the direction of rotation of the aircraft. Removing the EMAHP filter from the roll axis removes this error.
    Below is a screenshot and two short videos showing this situation.
    Roll with EMAHP
    Roll without EMAHP
  17. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,858Coins
    DC motor, 6DOF
    This is a good question that has already been answered many times in this topic. The HP filter (return to center) is part of the most popular "classic washout" algorithm - the best solution for the hexapod's limited "workspace". A slow return to the center (below the speed of vestibular perception) is the best way to fool the brain, which generally only perceives a change in angular velocity, ignoring the constant angular velocity. As has the fact that speed cannot be perceived, only its changes (acceleration).
    The aim of high-fidelity signal processing is not to translate all real-life forces within the limits of a simulation, which is intrinsically impossible, but to eliminate false forces as far as possible. In an aircraft simulation, keeping the platform tilted during constant roll would, I think, be a false cue. In most cases, you should only feel the roll in and out.
    Cheers - heXpod
  18. Attyla.pl
    Polska
    1,338Coins
    Thanks for the reply, but looking at the Graphics Viewer window in FlyPtmover, I noticed different behavior of the EMAHP filter depending on what is the signal source for the roll axis:
    1. if the source is "Roll position" then the use of the EMAHP filter is perfectly correct, and when the aircraft is tilted to the left, the platform tilts to the left and then slowly returns to the horizontal position
    2. if the source is "Roll speed" then the use of the EMAHP filter causes the platform to behave differently, and after tilting the aircraft to the left, the platform tilts to the left then quickly returns to neutral and crosses it to tilt to the right and only return to the horizontal position.
    Question what filter can I use to use as a source "Roll speed" to get a fast tilt according to the direction of "Roll speed" and then a slower return to the horizontal position ?
    Below are two screenshots showing the operation of the EMAHP filter depending on the source of the signal.
    Translated with DeepL.com (free version)
  19. hexpod
    berlin
    7,858Coins
    DC motor, 6DOF
    I'd advise sticking to "speeds" (angular velocities). I think you can experiment with LP and HP weights to get the right behavior. Try superimposing LP or HP filters one after the other LP-LP - HP-HP-HP (second or third order). This changes the abruptness of the behavior. The more you repeat the same filtering (two or three times), the more gradual the response will be. That way, you can decide on the amount and harshness of the inclination. Depending on scenario, the adverse kick when you stop rolling is not necessarily a false cue.
  20. Flymen
    Montreal, Canada
    2,479Coins
    DC motor, 6DOF
    Hello everyone ,
    I'm trying to create turbulence on DCS game , Anyone have idea to do this because the game doesnt give this algorithm .
    Thanks !!
