Showroom ODrive Turnigy 190kv BLDC 6DOF - Here we go again
Discussion in 'DIY Motion Simulator Projects' started by SilentChill, Oct 12, 2019.
  1. Ari_Sväng
    Ari_Sväng New Member
    43Coins
    I have made my own 6dof Simulator with your instructions. I have the same motors, encoders and power supplies. I am able to drive with it about two corners before it cuts operating because of over current of the motor. My rig have sometimes problems to be even still. Sometimes it takes just a few amps, but sometimes about 30-40 amps and then the motor gets really hot.:mad:
    I am curious, how high is your current limit? I have 50A limit and it is not enough. I assume my rig is little bit heavier than yours because I have made it from steel and I have three 32" monitors. One of your post you mention that your setup can handle about 400kg. My rig isn't so much heavier :D. I am pretty sure that the weight isn't the problem. I just don't know what it is.
  2. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    3DOF, DC motor, Arduino, 6DOF
    You put your monitors on the rig. SeatTime has done something similar and destroyed one of his 4k monitor. Beware!
    Seattime's Sims
  3. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    what firmware do you use your own or
    what firmware do you use your own or SilentChill? if you use your own try to use from him, provided that you use the same motors and the same odrive
  4. SeatTime
    Yep, it was a 4K 40 inch TV to be fair, but others seem to have better luck with monitors. Recently fitted a 32 inch monitor to my rig for testing only, but for many reasons I see off rig big TVs (55 inch) in my future.
  5. Ari_Sväng
    43Coins
    Let´s see if I am ever going to get this rig work properly.
    My odrives are 3.6 56V, so I think I can´t use his FW? I tried ones, but I got all kind of errors so I didn´t look in to it after since. I made my own firmware to them with the instruction video below.
  6. Tehrawk
    Tehrawk New Member
    170Coins
    You will get errors if you have a different firmware version that the one that SilentChill used. Im pretty sure it should be 0.4.12
    You can install it to your Odrive using the following code
    pip install odrive==0.4.12
    That will replace whatever the version you have currently, with what I believe is the correct one.
  7. Ari_Sväng
    43Coins
    That command just downgraded odrivetool. I manage to flash the odrives with STM32 programmer to 0.4.12. Or should I say I think I mangage, because odrives show that fw version is 0.0.1 or something like that. It still look like it works properly. I didn´t have time yet to test the rig, but everything is calibrated.
    The answer to my original question, @SilentChill motor current limit is 50A.
  8. Mattia27c
    Mattia27c New Member
    37Coins
    Hi everyone,
    I’m a newbie in simulators; there is a link where can I find the FULL and UPDATED project? The only link I found is the gdrive folder of actuators….
    Thanks a lot for the support
  9. BDZ
    BDZ New Member
    166Coins
    Search the Facebook group on Facebook MotionSimBuilders. Some bloke on their has taken (stolen?) silentchills design and will be selling kits if that makes it easy
  10. Mattia27c
    37Coins
    Hi @SilentChill ! You may update the shopping list, because lot of components are signed as x1
    when in reality you need x6 (for example: UJ Bearing, Ballscrew etc...). Therefore, the total cost exceeds 2000.
    In addition, almost all ebay links are now not available.
    Thank you so much for the support!
  11. Mattia27c
    37Coins
    Are there stl files and sketchup for actuator V2 ?
  12. sandman7793
    sandman7793 New Member Gold Contributor
    IT Professional
    Naples, Florida
    104Coins
    It's the original link on page 7. He said in a few parts later he would update the same folder if everything held together.
  13. Mclain
    Mclain New Member
    Transmission Specalist
    Hulsberg NL
    59Coins
    Had to register to say im very impressed with this build. Wanted to go for a 3dof route, but looking at this, and seeing the low costs, i think i need to make more room and build this.. Its really really awesome.
  14. Rocketbase
    Rocketbase New Member
    Winnipeg, MB, Canada
    - 104Coins
    3DOF, 4DOF, 6DOF
    @SilentChill awesome work, and thanks for all this information and resources.
  15. Adova
    Adova New Member
    28Coins
    Hi all. Just beginning to get into the hobby (obsession?).
    I am very interested in basing a build from @SilentChill but I wanted to check to see if there was any new technology that I should consider as we get into 2025.
  16. Will974
    Will974 Active Member
    Industrial Ingeenering Teacher
    Reunion Island
    959Coins
    Hi adova,
    I would say yes. There s some new design and a new way to control easily your future bldc rig motion..... If you want to know more, i invite you to join odrive bldc users in this discord:
    https://discord.gg/UK3cjSSd
    See you soon
  17. anatachaikiet
    anatachaikiet New Member
    184Coins
    hello , when you have configued the Odrive , which port you connect to odrive ( pc usb to odrive usb ) ?
