SimTools v3 Public Beta
  1. Michael Pleym
    Michael Pleym Member
    258Coins
    Yes. Ofc I have. In one of the lines, in the Export.lua file in that dictionary it says: "
    Look into Saved Games\DCS\Logs\dcs.log for this script errors, please."
    Don't have any "Saved Games" dictionary on my computer. Only "Sparade Spel" (swedish for Saved Games). And it remains with that name although how many times I try to rename the map.
    And about SimHub. No I don't have SimHub installed on my computer. Why should I?
    I have tried it all you know. It doesn't work, Ok.
    In over a year I have tried everything to make it work, No avail. Ok.
    Funny thing is that it works fine with all my racing simulations that I have installed via Steam.
    Only DCS it does not work with.
    And yes, I have paid for my copy of SimTools. When I paid for the motion platform, SimTools was included. Right?
    But no support obviously.
    Michael
  2. yobuddy
    51,526Coins
    Please verify that the lua file looks like this below, as our lua file for the plugin does not have that text in it.
    There is no need to rename anything, just select the "...Sparade Spel\DCS" folder and after patching, you should have a "...Sparade Spel\DCS\Scripts\Export.lua" file, and it should look like the above pic when opened.
  3. Michael Pleym
    258Coins
    Thank you for your clarification on the name issue. I was almost thinking of taking the step to buy and install a new Windows version with english language. Now I now that wont help.
    I will check the content in my Export lua a.s.a.p.
    Kind regards
    Michael
  4. richdelta9
    8,850Coins
    Please make sure you have Car Dash selected for Data Out Packet Format as seen in the configuration image on the game plugin data page otherwise you will not get correct data output.
  5. Trent Robinson
    Trent Robinson Member
    Systems Engineer
    360Coins
    Yup. I do.
  6. Michael Pleym
    258Coins
    Sorry, that line were from the Script folder in the game itself. You talked about the "dcs" folder so that's where I took the example from. I just wrote it to make an example of the game using the word "Saved Games" and not "Sparade Spel" by it self. Thought it maybe had something to do with my problems. Now you have explained it don't so I leave that hypotes behind.
    And yes, I have the exactly same lines in my folder "Sparade Spel"_DCS_Scripts_ export.lua
    Kind regards
    Michael
  7. yobuddy
    51,526Coins
    Now lets see if DCS is loading and running the script correctly.
    (Please make sure SimTools is not running)
    Run the test app I linked below, set the port to 41230, and then click "Open Port".
    Now run DCS, and see if you get any data in the window of the test app.
    Please let me know how it goes.
  8. Michael Pleym
    258Coins
    Yes, I did run that app. Lots of numbers going on and changing all the time. I did need to turn off my windows virus defender to make the app UDPRecieve to run though, so I thought maybe that was the problem for me and turned down my virus defender system all tougether. Firewall I have already told to make exeptions for SimTools and for DCS (installed on my second harddrive).
    So in that mode I did the usual drill rutine once again.
    1.Uninstalling current DCS plugin from SimTools,
    2. shutting down SimTools,
    3. running DCS from outside SimTools (Viggen and F16 are my testing planes),
    4 starting SimTools,
    5. installing latest DCS plugin from PC SimTools repo site (the one you download from the Plugin Libary) by dragging it to the main menu in SimTools,
    6. making the launch direction by dragging my "bin" dcs exe file over the DCS plugin and drop it there,
    7. testing it in motion menu in all the relevant directions (roll, pitch, heave, roll rate, pitch rate; all is functioning well in the SimTool app; that means I have motion so far),
    8. saving it as both default and global and then
    9 dubble click on the arrow on the DCS icon.
    Like I have done a couple of hundred times now.
    And guess what? NO motion AT ALL in DCS! Alt+Tab to the SimTools windows when flying in DCS shows only zeros in the Input line in Max/Min tuning screen.
    As I said, I've done this rutine for over a year now. With every little change in every little notch you could imagine. What I'm I doing wrong, since you say it's working fine on your side?
    Win 11 here btw. And NJMotion Compact Evo.
    Kind regards
    Michael
  9. yobuddy
    51,526Coins
    Excellent, so we know the script works, and the game is sending the data we need.
    Will you please post a screenshot of the test app showing the changing data, so I can compare it to what I get?
    No need to do a bunch of extra stuff, were just testing one step at a time.
    We now know the plugin is patching correctly for you, and the script is working for you, as the game is sending data. So the next step is to to take a look at what you are receiving from the game, vs what I am receiving, a screen shot of the test app will tell me that.
    Take care,
  10. Michael Pleym
    258Coins
    This was after I closed down DCS and the strings therefore not changing anymore.
    I'm extremly grateful for your efforts to help me out.
    Kind regards
  11. dryas123
    dryas123 New Member
    - 130Coins
    I've done some more investigation: Whenever I have other tools running which access the shared memory of iRacing (e.g. CrewChief, TradingPaints etc.) Simtools3 is not able to access the data from iRacing.
    Workaround: Close all additional software that access the shared memory of iRacing, start Simtools3, start iRacing. Then go in to the race session and then start additional software like CrewChief.
    It's working that way but is a little bit annoying TBH and I guess there is some kind of a bug somewhere in the Simtools3 implementation on accessing the shared memory.
    Best,
    Ben
  12. yobuddy
    51,526Coins
    Hi Ben,
    This sounds like one of the 'additional software' is blocking SimTools from the data to me. SimTools can connect if the 'additional software' has not been started. But SimTools cannot connect if the 'additional software' has been started. Maybe by starting one 'additional software' at a time before SimTools, you can find which one it is?
  13. yobuddy
    51,526Coins
    Hi Michael,
    Your output looks just like mine here. With the same amount of data (13 groups), same period as decimal point and so on. So I see no reason 'yet' as to why you don't have incoming data.
  14. Michael Pleym
    258Coins
    Hmm, could it be same sort of problem that Ben describes? But only software I use in addition with DCS is the drivers for my TM flight stick and throttle. Maybe I should try to start them after I have started DCS?
    Kind regards
    Michael
  15. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    Hi @yobuddy is any way to change this one?
    When u set axis to rise or decrease work only this axis on stand by position is in the middle position. When game start is goes to start position max or min position. When game stops it's Goin in the middle position but it's little wired on belt tensioner. When U tied up and start game belt is Goin to loose so U tied up more and when game stops Belts squeeze you more. So if is any possible for axis set like this to be always max or always min it will be cool. Live your work
  16. yobuddy
    51,526Coins
    Hi Buddy,
    You can set the parking location of the axis, to the same starting position of the axis (max or min), and you will be golden.
    Take care!
  17. Krzysztof Dej
    Poland
    1,100Coins
    Even with staring location when game start axis go to middle then max or min :) but it's better now for sure
  18. yobuddy
    51,526Coins
    I will take a look...
  19. Thierry59191
    Thierry59191 Member
    - 76Coins
    4DOF
    Hi everyone,
    I have recently been using simtools 3 which I find user-friendly compared to 2. On Assetto and Dirt 2 it is really good. I wanted to try roller coasters in VR for fun and I encountered a problem on Epic Roller Coasters demo version, I am not receiving telemetry, although I have activated it in the game (127.0.0.1 port 4123) and in the launcher steam ( -telemetry network -port 4123), I did a test with simtools 2 and the same, so I wonder if the evaluation version sends telemetry or if it's just on the full version? I'm wondering this because I tried No Limit Roller Coaster steam demo version and at launch it is clearly written that telemetry is not active on the demo version.
    If you have any suggestions or ideas, I'm interested :)
  20. apcb
    apcb New Member
    10Coins
    I have problem when installing SimTools V3.
    The program always not responding.
    Firewall and windows defender allready off.
    Can someone teach me how to fix this problem?
