SimTools v3 Public Beta
  1. yobuddy
    51,359Coins
    Know that clicking 'save as default' only saves the profile as the default profile for the currently selected game plugin. And this Default profile is the profile that will get used for any auto created profiles. (if the plugin supports it)
    However, saving the profile as the global profile, will make it so that it's the default profile for any newly installed game plugin. I seem to be able to save a profile to global, then switch game plugins and load it back here anyway. I will look this over closer next week thou.
    What plugin are you talking about? The only plugin I know that is having issues is IRacing after its last update. I believe its something with its new anti-cheat engine. We have test fixes already out to testers.
    Take care,
  2. Deups
    Deups New Member
    40Coins
    It for F1 23
  3. yobuddy
    51,359Coins
    @Deups,
    I'm guessing that "It works on other Simus" means that other game plugins work?
    If not, then I suggest you re-run the setup plugin for your NjMotion compact.
    If other game plugins do work, then could you maybe tell me anymore about your f1 23 problem, I just don't have a lot of info about the problem to help you is all. All of the codemaster games use an official API that should be non breaking with game updates. But I will gave the game a test when I get into the office Monday.
    Chat soon!
  4. Deups
    Deups New Member
    40Coins
    Thank you for the answer. it actually works on other Simus, but not on F1 23. To my knowledge I haven't changed anything on Simtools or F1 23. Simtools recognizes F1 23 when I start it but that's it, no movement
    153,001Coins
    +11,116 / 56 / -2
    Can you please post pictures of all of your settings for F1 23, including the Tuning Center while the came is running.
  6. dgiatr
    dgiatr Member
    243Coins
    53731417631_ac301548f4_k.jpg Hello to all!
    Just finished my pneumatic g-seat which has been added on my dof 3p motion platform exclusively for il2 gb sturmovik flight simulator. So I have Simtools v3 that controls an arduino board which controls six servos to add or to reduce air to seven air bags on my seat.
  7. dgiatr
    dgiatr Member
    243Coins
  8. dgiatr
    dgiatr Member
    243Coins
  9. dgiatr
    dgiatr Member
    243Coins
    Personally i want to thank yobuddy for Simtools v3 which is far more better than the older versions and easier for a newbie like me to handle!! I have also implemented Simtools vibe to Epic Roller Coaster and it works fine!
    So my only problem with Simtools settings and g-seat implementation in IL2 Sturmovik flight simulator is as follows:
    As you can see in the upper image each servo that controls my air bags is named as "Axis1a" , "Axis2a", e.t.c.
    So by the time i want to roll left or right on "Axis 1a" and "Axis 4a" servos, i put sway 100% and roll rate 100% forces. If i fly straight ahead (zero degrees roll angle) and decide to roll left from there my roll rate works fine and gives movement to servos "Axis 1a" or "Axis 4a". These are the servos that controls air bags placed left and right underneath me , so i feel g-forces from the low part of my seat ( where i sit not from the back of my seat i mean) every time i roll left or right. In case i delete "sway" forces from "Axis 1a" and "Axis 4a" then roll rate works fine every time i roll reft or right NO MATTER THE INITIAL DEGREES I START ROLLING. I mean if i am not completely level ( zero degrees roll angle i mean i am completely level) , and say start rolling from 40 degrees initial roll angle ( in comparison to horizontal level) either left or right then roll rate works fine and pushes my air bags. But in case i also have "sway" forces plus roll rate forces to "Axis 1a" and "Axis 4a" then roll rate WONT WORK as i would. In that case, say i start rolling fast again from initial roll angle of 40 degrees compared to horizontal level then ROLL RATE WILL NOT GIVE ME ANY REACTION UNTIL MY PLANE PASSES FROM THE POINT OF ZERO DEGREES ROLL ANGLE AND AFTER THEN IT STARTS TO REACT TO ROLL RATE. I mean while rolling : 40 , 30 , 20, 10, 0 ( only now and after that point my servo reacts to roll rate) , -10 ( servo reacts), -20( servo reacts), -30 (servo reacts), e.t.c. , the same to the other direction. No matter how many % percentage i set sway or roll rate i will face the same issue.
  10. dgiatr
    dgiatr Member
    243Coins
    I tried "anti rollover" to roll rate forces on axis assignment but nothing changed. I also checked telemetry data in min/max tuning of Simtools while flying and data from il2 seems ok , i mean every time i roll fast to the right i get positive values of roll rate and negative while on the other direction ( or the contrary i dont remember ) NO MATTER THE INITIAL ROLL ANGLE COMPARED TO HORIZONTAL LEVEL FROM WHERE I START ROLLING. I keep "sway" forces to Axis 1a and 4a because i want to fell sway g-forces on my body on the low left-right sides of my seat while turning with my plane.
    So do you have any ideas how to solve that issue?
    Thank you in advance!
    153,001Coins
    +11,116 / 56 / -2
    I will leave to @yobuddy to reply specifically.
    What I would note, and is evident in the V3 interface settings, is that when you allocate up to 300% of a 100% axis range you are likely to create problems in terms of refining a motion profile.
  12. Deups
    Deups New Member
    40Coins
  13. Gadget999
    12,072Coins
    can I test the new plugin / fix ?
  14. yobuddy
    51,359Coins
    The port should be 4123 buddy.
  15. Gadget999
    12,072Coins
    At the moment I can't get simtools v3 to install. It just hangs
  16. dgiatr
    dgiatr Member
    243Coins
    Axis1a and Axis4a will show the same problem even if I set total % to 100, I mean 50% roll rate and 50% sway (total 100%). If I set 100% roll rate and 100% sway (total 200% ) then it happens again. Only in one case roll rate acts as it should and thats the case to set only roll rate forces to axis1a and axis4a and not sway at the same time.
    What do you think is the problem?
  17. yobuddy
    51,359Coins
    Looks like you don't have any Max/Min values either.
    I would suggest removing the plugin (little trash can on the games banner).
    Then restart SimTools v3, and reinstall the plugin.
  18. yobuddy
    51,359Coins
    I'm getting contradictory results from testers.
    PM sent...
  19. spikedbat
    spikedbat New Member
    Automotive Test Engineer
    Ontario, Canada
    58Coins
    SCN6, 4DOF
    I'm having a problem with v3 that when it launches iracing from simtools, it tries to launch it through Stream.
    I don't run iracing from Steam, I didn't even know the two were connected. Is there a way to get simtools to launch iracing directly not through Steam?
    I can't figure out how to change any launch settings.
    If I load iRacing, then go back into v3 and click play on iracing the motion does come alive. So really this isn't a major problem for me, but just a small issue with launching iracing.
    Any help would be appreciated.
  20. dgiatr
    dgiatr Member
    243Coins
    Hello
    Can you give any help with the problem I have?
    Thank you.
