  1. Josh_Possa
    Josh_Possa Active Member
    Catalunya
    586Coins
    2DOF, 3DOF, DC motor, Motion platform
    No, my sensor's feedback aren't as bad as the Silyn sensors but I still think mi problem comes from the feedback. If I reduce the Kp value the noise effect reduces too and the yellow line is less noisy BUT some of little movements aren't noticeable coz the signal is not strong enough to move me upwards and that also makes the motors very hot (because the lack of movements while the motor is receiving energy, it acts as short). If I want plenty "fidelity" in the movements I need to increase the Kp but then the effect of noise is an horror. Aprox in one week I'll receive the new sensors and I'll see if there is an improvement. Other tests I want to do is try to configure Simtools/FlyPT to filter that noise and make the movements smother if it is possible.
  2. Gefahren
    Gefahren Member
    Electronics Engineer
    Central Mississippi, USA
    395Coins
    My system is in no way tuned out (I'm still building and adjusting the mechanical parts) but all I have is a Kp value. I set Ki and Kd to zero for the moment because that makes all three channels behave the same.
    Have you tried with Ki and Kd set to zero?
  3. Josh_Possa
    Catalunya
    586Coins
    I tried everything but Kd does not make any effect and Ki more than 1 makes the motor/controller run crazy so that values are set to zero.
  4. ashboss
    ashboss New Member
    - 4Coins
    i feel like a fool i got the wrong board got the leo and it looks like there is no work around :(:(
  5. Gefahren
    Gefahren Member
    395Coins
    You can rewrite the code to work on the Leonardo boards. I ported it to an Adafruit ATMega32U4 breakout board (same processor as the Leonardo) just to see how it preformed. It ran about the same, but all three timers are 16 bit instead of one of them being 8bit like on the Uno R3. It does seem that the speed varies more, probably because of the overhead of servicing the USB.
    But if you're looking for something already released for the Leo, then I don't know where you'd find that.
    Also, if you go out to get an Uno, make sure it's the R3 since the R4 uses a different and more capable chip but is not compatible with this SMC3 code.
  6. ashboss
    ashboss New Member
    - 4Coins
    it R3 btw not sure what to change
  7. ashboss
    ashboss New Member
    - 4Coins
    hey got it to work but motor 1 not changing directions motor two works fine any idea why
  8. Gefahren
    Gefahren Member
    395Coins
    I can take a look at your code if you want. I am no expert, but maybe I can spot something.
  9. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,348Coins
    Ashboss
    write exactly what you mean, it's hard to guess what you are writing about so briefly, answer the questions to begin with:
    1. you have an Arduino UNO R3 board yes/no ?
    2. in SMC3Utils after selecting Out mode "Sine" the arm moves up and down yes/no ?
  10. Silyn
    Silyn Member
    44Coins
    3DOF, DC motor, AC motor, Arduino, 4DOF
    Does anyone have SMC3 code that works off A/B encoder data?
  11. ashboss
    ashboss New Member
    - 4Coins
    1 no i got a leo
    2 yes they finally do after some miner agistments
  12. Attyla.pl
    Polska
    1,348Coins
    Ok, my advice buy a cheap arduino R3 clone and move on with your project, it's a waste of time figuring out the leo board whatever it is :)
  13. Denis Mowberry
    Denis Mowberry Member
    New Zealand
    99Coins
    Amps X volts =watts. 4 amp X 24 volts=96 watts per motor. I run 2 x 250 watt 24 volt motors off 1 600 watt power supply with no problems.
  14. ashboss
    ashboss New Member
    - 4Coins
    i finally stated work on my 2 dof rig. look at my control box:thumbs
  15. Nick Clements
    Nick Clements Member
    95Coins
    2DOF, 3DOF, DC motor, SCN5, Arduino, Motion platform
    I have just added another motor (24v wheelchair motor) to my rig for traction loss . I have loaded up SMC and my front two motors work as they did no issues. However my rear motor only works one way .I can move the blue cursor up and the rig responds and moves to the side . If I move back down it does not follow but just sits there!!! I’m sure this is an obvious solution. I have even replaced the IBT2 for a new one in case it was the cause . Any help much appreciated, it must be something simple …..
    could this be the behaviour of having an electric brake function on the motor.?
    I will try and put 24v across the small black wires as others have on this forum.
    update::: No electric brake on motor. Next I measured with DMM on the motor out of the ibt2 , when I move rig to the right -24v is read on DMM. Now if I move the other way past centre I do not get +24v.??? Yet in SMC I have the green line following the rig perfectly ??
    can it really be another duff IBT2???
  16. noorbeast
    152,195Coins
    +11,064 / 56 / -2
    Some have reported quality related issues when trying to run ibt2s at 24v, apparently around 20v is more robust.
    That said, are you using 2 Arduino's and can you please post pictures of your settings?
  17. Nick Clements
    95Coins
    I will post pictures of settings , but would it be better to get another arduino uni ?
  18. noorbeast
    152,195Coins
    +11,064 / 56 / -2
    SMC3 can do 3 motors but does not treat all 3 exactly the same way, so using an additional Arduino, given how relatively cheap they are, can be advantageous.
  19. Nick Clements
    95Coins
    once I have added the second Uno3 card I guess I just change the config file to match the new card com port. But what is the correct setting for the serial port setup in sim tools or flyptmover ?
    152,195Coins
    +11,064 / 56 / -2
    In SimTools you set it up as a separate controller in Interface Settings, specifying the correct port and axis designation.
