SimTools v3 Public Beta
  1. yobuddy
    51,001Coins
    Yes, v3 is faster than v2. But the game being run needs to deliver data faster than 10ms, and the interface needs to send faster than 10 ms to really take advantage of it.
    Since the last update to IRacing, the game itself has a memory mapped file bug. The problem happens whenever you use more than one app to collect data from the game. But if you only use SimTools and IRacing alone, then you won't see any problem. We believe it has something to do with their new anti-cheat implementation, but it's hard to say for sure. Currently we are waiting on a email from the IRacing team to see if they can find the problem.
  2. Brett
    Brett Member
    Engineer
    Carrum Downs Victoria Australia
    150Coins
    2DOF, 3DOF, JRK
    I have that issue too where I can't start any game from within Simtools. Does it need to be run with Administrator privileges?
  3. dgiatr
    dgiatr Member
    253Coins
    Two days ago an update of il2 sturmovik flight simulator probably broke my connection to simtools v3 . What to do to make them work again?
    Probably my configuration file has been replaced?
    Thank you!
  4. yobuddy
    51,001Coins
    Know that the play buttons require a double click to launch the game in v3.
  5. richdelta9
    8,860Coins
    You can try uninstalling the game plugin and then restart SimTools and reinstall the game plugin. You want to make sure to fly around in the game before you patch it.
  6. dgiatr
    dgiatr Member
    253Coins
    OK I did that but the game inside simtools tries to start only in steam library and it says i don't have the license because I don't have the game from steam but directly from the developer. So how can I start the game from simtools directly from the developer not steam?
    Thank you !
  7. yobuddy
    51,001Coins
    To update a launch path for a game plugin, simply drag and drop the games exe or shortcut on the banner for the given game plugin.
    Take care!
  8. richdelta9
    8,860Coins
    @Andrew M, @Grand Strate, @Michael Pleym
    We were able to reproduce the region issue and create a fix that was pushed out. After updating the plugin, DCS should work with SimTools in your Windows local region settings.
  9. richdelta9
    8,860Coins
    @Gerardo Rivera, @admarper
    We created separate Prepar3D plugins for the different versions of the game. This keeps the profiles separate per game and makes it so you can launch each version of the game from SimTools if you have more than one version installed. Please uninstall the older PrePar3D plugin and restart SimTools. Then install the version you are using, and you should get movement.
  10. dgiatr
    dgiatr Member
    253Coins
    Thank you yobuddy I have forgotten that...
  11. Gerardo Rivera
    Gerardo Rivera New Member Gold Contributor
    114Coins
    yobuddy thanks for the update for prepard3dv5 now my msfs and prepard3d working fine the final one to fix is FSX tried all the workaround and still no motion like before preprard3dvs5 now that has be broken in segments working fine. i got the license for both stream and box fsx. i got the plugin then dropped the exe for fsx but no joy. hope we can fix it. thanks again for the help with prepard3d.
  12. Michael Pleym
    Michael Pleym Member
    258Coins
    Wow, that sounds great!
    Will test it a.s.a.p.
    Michael
  13. dgiatr
    dgiatr Member
    253Coins
    OK the shortcut feature works just fine but when il2 sturmovik starts through simtools I don't hear that characteristic "bip" sound...could that cause any problem or is it better to hear that? Simtools seems to work fine thought..
  14. yobuddy
    51,001Coins
    w00t!
    The only "bip" sound I know of in v3 is the "BEEP beep" when launching game, it means that one of your interfaces was unable to startup. Should you hear this sound when launching a game with SimTools, you should check the error log to see which interface is unable to startup.
    Hope that helps buddy!
  15. littleghostthirteen
    littleghostthirteen New Member
    142Coins
    2DOF, SCN6
    Same. It’s such a weird problem, one day it works fine and the next, nope
  16. yobuddy
    51,001Coins
    Since the last update to IRacing, the game itself has a memory mapped file bug. The problem can happen whenever you use more than one app to collect data from the game. But if you only use SimTools and IRacing alone, you won't see the problem.
  17. Roland Munz
    Roland Munz New Member Gold Contributor
    - 114Coins
    first of all many thanks to Yobuddy and all the guys where have had supported him the years!
    Now I have SimTools V3 too and I have only two Games installed Right now (F1 2024 and Le Mans Ultimate). Here I have the identical settings, but the Traction Loss at F1 2024 has an issue and doesn‘t work wrong. When I get into a Race or off the Track, my Hyperaxis-Motor goes into one Direction (left side) but afterwards there is no further motion. Means that my seat isnt‘t central in the middle. In LMU it works perfectly.
    So has anybody an idea what can be wrong?
    Thanks very much!
  18. dgiatr
    dgiatr Member
    253Coins
    Hello yobuddy,
    How can I set different min/max tuning values in il2 sturmovik game from those I set in the beginning for heave, surge, swa?, I set different values i add a new profile I push "save" but it always returns to initial values.
  19. yobuddy
    51,001Coins
    Could you post pics of your axis and max/min settings for the game?
    Are you using washout? or maybe your using the advanced axis plugin and the axis is not set to normal output?
    I can help more with some pics.
    Chat soon!
    Please try copying a profile, then edit the profile to your liking, and then click save.
    Let me know how it goes.
    Take care!
  20. Gerardo Rivera
    114Coins
    Anybody able to get motion with FSX, tried all still no motion.Installed FSX Steam edition FSX dropped Box FSX and no motion motion on test mod only.
