My finished 2DOF project (VideoTutorial)
Discussion in 'DIY Motion Simulator Projects' started by scruck, Jun 1, 2021.
  1. noorbeast
    153,728Coins
    The Hall Sensors I use are 4.5v to 5.5v: https://au.element14.com/bi-technol...fs/sensor-hall-0-2v-20v-to-10v-pin/dp/2319662
    What are the brand a actual published specs of the ones you use?
  2. Sale83
    Sale83 New Member Gold Contributor
    Croatia
    - 505Coins
    Hi man i have sensor on picture.
  3. Sale83
    Croatia
    - 505Coins
    153,728Coins
  5. Sale83
    Croatia
    - 505Coins
    Yes 0-5v. Half would be 2.5v approximately. To me, Out- gnd is 1.72V and VCC-Out 3.12V. So its total range is 4.84V. What does it mean to me that in half to me would be at 2.42V. I wonder how to grasp that when I start everything he is halfway through 2.42V. And if that is possible at all. I would like to get values as in the picture (on the first side) upload_2024-1-3_22-54-53.png
  6. tselehub
    tselehub New Member
    98Coins
    can i use steper instead these wiper motors?
  7. Antonio1986007
    Antonio1986007 New Member
    - 94Coins
    Hello, I'm thinking of changing the motors on my 2dof for those, do they have any clearance in the axles? thank you
    153,728Coins
    Yes most wormdrives have some backlash, as the clearance is for lubrication.
  9. Antonio1986007
    - 94Coins
    Yes, I understand that, but the clearance in my motors is too much, the question more than anything was to be able to compare, my motors have 4 gears and these seem to only have the pinion and one gear, thank you for your time
  10. Antonio1986007
    - 94Coins
    By the way, searching on AliExpress I found these motors for €119 for two units ordering from Spain
  11. Hyun Park
    Hyun Park New Member
    - 7Coins
    I'm going to start now.
    It was a lot of reference. thank you!:)
  12. Johann007
    Johann007 New Member
    51Coins
    Hey,
    I find your Project very Interesting, i made my Sim Rig myself and its Based of your instructions in YouTube.
    Thank You very much
  13. Brian Rezel
    Brian Rezel New Member
    6Coins
    Hi Scruck,
    In the .dmg file for the motor arm, there were no dimensions stated. Possible to provide it please.
  14. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
    These are ready-made files for CNC cutting, if you want dimensions you will have to size them yourself.
  15. Nash_NZ
    Nash_NZ New Member
    52Coins
    Love the compactness of your build and get job on the videos... Have just given me inspiration for my build, using the some motors.
  16. Nash_NZ
    Nash_NZ New Member
    52Coins
    Just for reference for anyone else reading the higher rpm version has less torque than the 75rpm version.
  17. Cold Pancake
    Cold Pancake New Member
    90Coins
    I have been following your YT build for a while now. I am wondering how much does the motor consume (current) on average with you playing?
  18. Sale83
    Croatia
    - 505Coins
    I haven't finished my 2dof simulator yet, lack of time. I'm about 80/85% now. As soon as I finish it I'll send more details (power consumption etc.) My motors are 24V 2x250W 75 rpm. I don't think the levers on this motor should be longer than 75mm/85mm. If anyone thinks differently I accept it. :)
  19. Tima_m3
    Tima_m3 New Member
    26Coins
    Motion platform
    Tell me which motor is better to take 24v250w 75. 24v250w 105 24v250w 120. 24v250w 180 24v350w 160. 24v350w180. ?????
  20. Sale83
    Croatia
    - 505Coins
    From my own experience, a 250 W, 24 V motor with an output speed of 50 RPM could be a good fit. I’m currently using motors with 75 RPM, but I had to add springs because they tend to give way under loads exceeding 60–70 kg on levers that are 85 mm long. A motor with a stronger gear reduction—meaning a higher gear ratio—would be better suited to reliably handle such loads without the need for additional mechanical support. I also believe that 50 RPM would be fast enough for a driving simulator: responsive enough for realistic feedback, while still stable under load.
