SimTools v3 Public Beta
  1. yobuddy
    50,022Coins
    I'm confused, as your post is about FSX, but all of your pictures are for Prepar3D?
    I'm guessing you posted the wrong pictures?
    You were able to get motion with fsx according to this post.
    https://www.xsimulator.net/community/threads/fsx.18320/#post-245675
    Be aware that installing two version of fsx on the same machine, at the same time, will probably only cause problems.
    Take care,
  2. Roland Munz
    Roland Munz New Member Gold Contributor
    - 114Coins
    Hi Yobuddy,
    please find below my settings for F1 2024.
    As you can see, I don´t use any filter and I should have the right settings, cause I have identical ones at Le Mans Ultimate and there it works perfect!
    When I begin to drive from the box, the Traction Loss is spinning undefined to the left and to right side.
    All other forces are working proper.
    Thanks for your help in advance!
  3. yobuddy
    50,022Coins
    Sounds like you need to capture max/min for traction loss is all.
    As a quick test, you can change the traction loss max/min number to +-25 and see if it's better.
    I would also increase your roll and pitch max/min to +-25 or so, as right now they are limited to only +-5 deg.
    Anyway, please give this a try, and let me know how it goes.
    Chat soon,
  4. yobuddy
    50,022Coins
  5. Gerardo Rivera
    Gerardo Rivera New Member Gold Contributor
    114Coins
  6. Michael Pleym
    Michael Pleym Member
    258Coins
    Sry guys, I have not had the time to test this patch until now. But I can tell you.
    YES! YES! YES! YES! YES!
    IT WORKS! IT WORKS! IT WORKS! IT WORKS!
    I'm so grateful for this patch!
    THANK YOU! THANK YOU! THANK YOU!
    You took the time and put all your efforts in. I'm have been struggling to have DSC working with my chair for so long. And now it works!
    Thank you Rich. Thank you buddy. Thanks to all of you.
    Kind regards
    Michael Pleym
  7. Roland Munz
    - 114Coins
    now I‘ve tested both suggested settings with higher values of +/- 25, but unfortunately it makes no difference to my old settings. As I already wrote, I have the same settings at LMU, and in the past, it always worked with SimTools 2 and the older F1–Titels, too.
    So would be great, if you have a further idea!
    Thanks!
  8. dgiatr
    dgiatr Member
    247Coins
    OK it works. Thank you.
  9. Shoe
    Shoe Let's Go
    Consultant
    54Coins
    Arduino, Motion platform
    Hi all,
    I was running F1 '23 great on my S2 Symdeck platform; I am trying to setup the F1 '24 game and under the Dual JRK it is only picking up one of the actuators. My left side picks up and moves but I can't get my right side detected/working. Any help would be appreciated!
    Thanks,
  10. yobuddy
    50,022Coins
    What happens when you click the 'Test Settings' button, under Interface setup, for the dual interface setup?
    Do both actuators respond as they should.
  11. Shoe
    Shoe Let's Go
    Consultant
    54Coins
    No, it only picks up the left actuator. It doesn't find the right acuator number to to select and test. I'm doing this all under the Symdeck plug-in; should I use the Simtools pc plug-in?
  12. yobuddy
    50,022Coins
    With only one Jrk showing up in the interface settings to configure, it sounds like it may be a hardware issue? I think you should send Symdeck an email and explain the situation. I bet they know what to check right away and can help get you fixed up.
  13. Shoe
    Shoe Let's Go
    Consultant
    54Coins
    Thank you, I will connect with them. Any idea though on why I didn't have that issue with F1 23 just last week? Thank you
  14. yobuddy
    50,022Coins
    The Interface setup is independent of the game plugins.
    Do you currently have F1 23 working in v3?
  15. Shoe
    Shoe Let's Go
    Consultant
    54Coins
    I did have it working, but I wasn't using the symdeck interface.
  16. Roland Munz
    - 114Coins
    Hi Yobuddy,
    Z1 and Simhub have released an dash-support for F1 2024, but both are only working with the UDP-port 20777 but Simtools allows only the port 4123.
    So my question is, if there is a chance to change it from your side to get it work. Russell Hodgsen from Z1 means that you maybe can help.
    Thanks!!
  17. yobuddy
    50,022Coins
    Only one app can collect data from a UDP port at a time. So we actually don't want the plugin using the default 20777 port. What we want to do is get the plugin working in SimTools, and then setup a UDP Relay from SimTools, and send a copy of the data to port 20777. (like in the pic below, but for F1 2024)
  18. yobuddy
    50,022Coins
    I'm guessing you were using the jrk interface plugin for interface 1 and 2 before?
    Maybe re-setup what was working, as it should work for 2024 also.
    Take care!
  19. Roland Munz
    - 114Coins
    Sounds really good! Thanks for the great news
  20. dgiatr
    dgiatr Member
    247Coins
    How can I use min/max settings for il2 gb sturmovik one set for runway and one set for the air? I already have some min/max values for "runway" option but when i set some min/max values for " air" and press "save profile", simtools will not hold the current "air" values.
