Yet another controller board
Discussion in 'DIY Motion Simulator Projects' started by Aerosmith, Aug 1, 2024.
  1. SpeedyBee
    SpeedyBee DIY 3DOF, AC Servo Ball Screw Drive
    engineer
    California
    55Coins
    Good idea, the requirements are different from a CNC machine where you prefer to have each axis homed individually so as not to distrubt each other when the end stop is tripped. In a motion rig you need to think about the person sitting in the chair whilst homing.
  2. Aerosmith
    Aerosmith Active Member
    self employed
    2,881Coins
    3DOF, AC motor
    Yes, under normal conditions you only have to execute the homing once per session when you switch the controller on for the first time. We have the main switch outside, at the control cabinet at the rear of the rig. So nobody sits in the cockpit. But if you have to recover from an emergency stop, power failure or any other type of error condition you should also be able to execute the homing while sitting in there.
  3. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    Yesterday, we installed the controller with the new 3D printed casing. The ratsnest of wires hasn't got much better but it looks a bit cleaner and is at least safe to operate.
    The improved homing procedure also works quite well. The controller currently has no online/offline switch but instead cross fades the position automatically from the parking position to the center position when FlyPT Mover connects. This folows the rule "make it as simple as possible". But probably a door switch would be even better. The rig would then go down to the parking position automatically when the door is opened without the need to flip a sepearte switch or to disconnect the Movoer output.
  4. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    @Motion4Sim I just saw this video. Can you explain a little more in detail what has changed in the new firmware and what you did to improve smoothness? I still have one of your controllers. (It's on the marketplace but nobody has bought it, yet) Maybe I'll use it for the heli project...
    BTW: I have AASD servos from @Klaus Schmidinger so no trouble to be expected, this time.
  5. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    Update: I've made a new PCB layout which has 6 instead of 5 outputs for servo axes. The boards have just arrived. I'll assemble at least two for my own 6DOF rig and Sven's next heli sim. But if anyone else is interested I could make up to 5.
  6. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    I've just assembled 3 boards.
    • Like Like x 5
  7. Thinqer77
    Thinqer77 New Member
    39Coins
    Sorry for resurrecting an old thread but I've only just found it and wish I had discovered it a few months ago!
    Long story short, I've been designing and coding my own (non-commercial) AASD controller board based on an ESP32 S3 using the MCPWM hardware units (basically hardware timers). I've learnt a lot doing it (which was my main driver for developing my own) and enjoyed the process but I've got a couple of questions I was hoping @Aerosmith and @Motion4Sim might be able to help me with.
    1. Do you just run the servos at full speed all the time? Doesn't this mean that the motion can get jerky if the travel distance is very short? I'm thinking that if the servo moves to position more quickly that the ~2ms frame time for position data then it could be in a stop position until the next frame comes in, i.e. constantly stopping and starting. Is it better to calculate the speed required for each move between frames (or some filtered value) and adjust the pulse train to the servos (i.e. the speed) to match? Or does this not make any difference in the real world?
    2. I am getting some significant but consistent overshoot when moving the servo at higher speeds. I think this is due to the feed forward and position deceleration settings on the AASD driver, however most people seem to have those enabled and don't suffer any issues. For my testing I'm sending (e.g.) 100,000 pulses to the motor and then stopping it dead (by turning off the pulses). It doesn't matter how many pulses I send (10,000 for 1 revolution or 100,000 for 10 revolution), the overshoot amount is always the same for a given speed. It's nearly zero at 100kHz but 5-10 degrees at 500kHz. How do you prevent this from happening or otherwise deal with it in code?
    3. I'm using FlyPT Mover as my source of position data. I've assumed that it takes care of filtering and motion smoothing (i.e. ramp up and down ) so I don't need to do any of that in the controller. Is that correct or do I need to do some smoothing and filtering in the code?
    Thanks in advance for any pointers you can give!
    Thinqer.
  8. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    @Thinqer77 You're welcome. Designing something on your own can be really challanging but also quite satisfying. You definitely learn a lot.
    You can in fact output all movements as a series of step pulses at constant (max) frequency.The command input low pass filter of the servo will smoothen this to some degree so that the motor will not accelerate to full speed and decelerate each 2ms interval. A stepper motor couldn't do that and would stall immediately or at least run very rough. So adjusting the step frequency for minimum velocity discontinuities is much better and results in a more smooth and quieter running of the motors.
    I made a presentation how my controller works in the Parallax Propeller Live Forum. Apart from the general theory of how a motion simulator works I talk about the motion algorithms that are used to calculate the output signal frequency for a given position command input. The basic ideas are:
    • Calculate the current velocity based on position difference divided by time difference for each 2ms interval and use that for the frequency of the step/dir signal (explanation around 22:50 in the video)
    • Let FlyPT Mover do the filtering so most of the time the servo just follows the command (that answers question 3)
    • Exception: The commanded velocity or acceleration exceeds the capabilities of the hardware. Then the controller limits velocity and/or acceleration by clipping. I explain that with the car race analogy at 34:13.
    Sorry for my bad English. I also apologize for my criticism of the Motion4Sim controller. We had some problems at that time which lead to me designing my own controller. But the M4S controller has also been improved since then and runs much smoother, today. So my criticism is probably no longer justified.
    I think that is caused by the tuning of the AASD controllers. The factory setting is set to a rather low gain so that there is no tendency for oscillations independent of the mechanical setup (load inertia ratio). This makes installation and operation easier for unexperienced users but has the drawback that the response of the servos is quite sloppy, I mean there is delay and overshoot especially for high accelerations.
    You have to tune the control parameters inside the AASD controllers to mach your mechanics and optimize them for increased stiffness and minimal delay and overshoot.
  9. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    I just read your question again... If you send a burst of pulses with a constant frequency and no ramp-up or down you get overshot, of course. The motor can't follow an infinite acceleration command, e.g. a sudden jump from zero velocity to max. velocity and back. It has inertia and only limited toque.
    To avoid overshoot you need to limit the acceleration by adding ramps. Say, instead of starting with 100kHz immediately you output 5, 10, 15, 20, 25... 95, 100kHz for the first 20 intervals.
    You don't have to care about that if the commands come from FlyPT Mover as the filtering is already done, there.
  10. Motion4Sim
    Motion4Sim Member
    Europe
    729Coins
    Hi everyone,
    I just got a notification that I was mentioned here, so greetings to all
    Very interesting topic, and I can definitely relate to it.
    I’ve also developed my own controller based on the ESP32, capable of driving AASD servo drives with up to 500 kHz pulse rates using hardware-based full-speed pulsing.
    Here is a short video from back then:
    Back at that time, the main limitation was that with a single ESP32 I could reliably drive only one, maybe two servos at full speed (500 kHz–1 MHz). More than that simply wasn’t feasible on one ESP. Because of this, I eventually abandoned the project.
    It worked reasonably well, but there were additional issues—especially synchronization and sharing USB Voltage over the boards, since I ended up using one ESP per servo. I don’t think I was using the hardware timers properly at that point; there were some issues I never fully resolved. One would have to look at the old code again to see why that approach failed.
    What actually worked best was misusing a hardware UART and sending the pulses through that.
    Ramps, filtering, and AASD behavior
    In principle, it is of course correct to use acceleration and deceleration ramps. However, it’s important to understand that AASD drives already do this internally when using position mode.
    That means:
    If you send a burst of pulses, the drive itself will internally generate a ramp. It will accelerate smoothly, run, and then decelerate again.
    This also explains an important side effect:
    If, within your 2 ms control frame, you only send a small number of pulses, the motor will start moving and then stop again. This is exactly why filtering on the command side is so important.
    If your hardware allows you to generate different pulse frequencies independently on all channels, then it absolutely makes sense to distribute the pulse count evenly over the frame time and continuously adapt the frequency. That results in much smoother motion.
    Overshoot issues
    If you are seeing overshoot, that is not caused by the pulses themselves.
    The pulses define where the servo should go. The actual motion behavior—including overshoot—is determined by the drive’s internal control loops and parameters.
    In most cases, overshoot means:
    • The Feed-Forward Gain is too aggressive
    • Or internal filtering/smoothing has been reduced or disabled
    Below are the AASD settings we currently use, and I would strongly recommend starting with these for developing and testing your own controller:
    • Pn109 = 1 → Smoothing enabled
      • 1 = Fixed smoothing
      • 2 = S-shaped smoothing
    • Pn110 = 30 → Smoothing filter time
    • Pn113 = 20 → Feed-Forward (%)
    • Pn114 = 10 → Feed-Forward filter time (ms)
    • Pn115 = 100 → Gain (%)
    Once your system runs cleanly and stable with these values, you can start experimenting and fine-tuning.
    Electronic Gear (important!)
    Also pay close attention to the Electronic Gear setting (Pn98).
    This parameter acts as a translator between your incoming pulses and the motor’s internal encoder positions.
    We typically use:
    • Pn98 = 2
    With this setting:
    • Each external pulse is multiplied by 2 internally
    • You get 5,000 positions per motor revolution
    If you set:
    • Pn98 = 1, you get 10,000 positions per revolution
    However, that also means you need double the pulse rate to reach full motor speed. Keep in mind that AASD drives support up to ~550 kHz maximum—above that, they will shut down.
    @Aerosmith:
    I noticed that you recently offered your rig for sale on Kleinanzeigen. Are you still running a motion rig, or have you built something new in the meantime?
  11. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    No, that's Sven, not me. He needs money for his (real) car projects so he's selling one of his sim rigs. I'm still designing my two-seat heli rig but I struggle with the support of the projector screens. I thought I could just add some carbon fiber tube structure but due to the limited ceiling height that's not as easy as I thought. If I just had a bigger barn or hangar instead of my tiny garage it would make things a lot less complicated.
    I also struggle with lack of spare time. Last year, my business has transformed from mass production of my CNC controllers to a one-man-show of electronics engineering which takes nearly all of my time.:(
  12. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    BTW (off topic), Denis @Motion4Sim,
    I heared roumors about a new motion controller you designed which supports EtherCat. I think that's a very interesting idea because more and more servo drives with EtherCat are available and that would solve many problems like the need for hardware timers generating the high step pulse frequencies. It would also mean you could do the parameter settings and tuning over the EtherCat wire so no seperate software would be needed for that.
    I also did some experiments with EtherCat but gave up because I had problems with the synchronization (distributed clock) and only got strange jerky motion and no meaningful error messages from the Chinese drives.
    Maybe you can share some details.
  13. Motion4Sim
    Motion4Sim Member
    Europe
    729Coins
    Yes, you heard that right
    I actually already made a YouTube video about this earlier.
    I spent most of the last year i worked on updating the motion controller. During that time, I also decided that I wanted to add a brake system to my rig. Recently, StepperOnline released very compact servos with integrated brakes and ethercat that are in the same price range as the AASD drives and, more importantly, fit directly into the MK3 without requiring any mechanical redesign.That was the point where I started implementing EtherCAT.
    And you’re absolutely right — distributed clocks can drive you crazy
    But at this point, everything is running very reliably and the results are very satisfying, but support is actually limited to the servos from stepperonline , maybe its working with other too but this need more time and testing.
    And yes, with EtherCAT it’s possible to tune all parameters live, which is a huge advantage compared to more traditional solutions.
  14. Thinqer77
    39Coins
    @Aerosmith and @Motion4Sim thanks both for your replies, very helpful!
    I've made a bit of progress since I last messaged but still have a three things I'm struggling with. If I'm honest, I've been using ChatGPT, Claude and Gemini to help with some of the coding (partly just to see what they're capable of producing and partly because I figured they'd have access to a wider range of code examples and would be able to research and summarise it more quickly than I could) and my experience has been... mixed. Each of them has very confidently told me how to solve the motion control problem, but when I challenge their approaches based on the approaches of the other AIs, they often admit they were wrong and have to correct the code they've generated. Anyway, I digress.
    For context, I'm using an ESP32-S3, which has enough GPIOs to drive up to 6 actuators (which is my ultimate goal, but I'm starting with a relatively simple 4 actuator setup to begin with) using either the MCPWM or RMT peripherals. I'm also using the two cores, one to process the incoming serial data and one to control the servos. On the AASDs I'm using Pn098 = 5 to keep the max frequency required to 100kHz or below which should help. Also that provides just enough resolution (o.0025mm per step) to match what I get from FlyPT (16-bit which is 0.0027mm per bit on my 180mm actuators) so I'm not losing anything there. I have the FF and smoothing settings broadly similar to the ones you suggested.
    1. The first big question is how do you handle jitter from FlyPT? In my testing I've found that whilst the average time between frames is about 2ms, the range is from about 70us to 4000us, with a standard deviation of 7-800, which is huge and I think is causing some problems with my motion. I note that Motion4Sim doesn't require FlyPT to send a timestamp from the PC, so how do you handle this jitter? Do you just assume that all frames were intended to be sent exactly 2ms apart and then process them at that rate (queuing them in the controller)? Or do you timestamp the frames when they arrive and process them as they turn up?
    2. Relatedly, are you running a fixed time control loop (e.g. 1kHz) in the controller that manages dividing up and sending pulses to the servos? If so, roughly what is the approach here? Do you do linear interpolation on the incoming positional data, then low pass filter, then speed, acceleration and jerk calculations and limiting, finally integrating back to speed and position, before passing on to the pulse generator? Or is that overkill because a lot of that is being done by both FlyPT and the AASD?
    3. How do you track (and correct for) the actual position of the servo in an open loop system like this? I can count steps sent to the servo using callbacks (although this gets unstable at higher frequencies and I've not tested with multiple servos attached yet but assume it will not be good) but ChatGPT said that they shouldn't be used in the motion control function and should only be used for accounting purposes and slowly corrected for over the long term. Gemini however suggests an approach using the fastAccelStepper library which does seem to take into account actual position (so each time a new frame arrives from the PC it calculates the distance between the actual position of the servo and the desired position, divides by the time delta and then sends the resulting speed and position target to the servos).
    4. Actually, I do have one more question! @Motion4Sim you said that the AASD works out ramp up in acceleration and also ramp down, but I don't fully understand how it does this without it knowing when the pulse train will stop. Are you saying that there's an implicit delay in processing the input pulses so it has a buffer it can use to predict this?
    I appreciate that some of this is the 'secret sauce' to how these controllers work but I'd greatly appreciate any pointers you can give.
    Separately EtherCat looks very interesting and the servos seem to be coming in at a very reasonable price (even ones located locally and not just on AliExpress) so I may have to look at them at some point, but for now I just want to get my 'simple' setup working!
    Thanks in advance for any help you can share,
    Thinqer.
  15. Motion4Sim
    Motion4Sim Member
    Europe
    729Coins
    It looks like you’re really diving deep into motion system programming now – and you’ve reached exactly the points where things become truly interesting… and where a lot of work is required before you end up with a system that actually runs well. Let me share a few practical observations from my own experience.
    First: below 200 kHz pulse frequency, the system will not run cleanly or smoothly. The servos will move and do something, but you should simply accept that anything under 200 kHz will never feel really good or ruck-free. Note 200khz is good for pn98 around 10-20
    Second: the jitter you measured from FlyPT is not correct. Yes, Windows does introduce some jitter, but not on the scale of the values you’re seeing. FlyPT is actually one of the systems that sends data with a very accurate 2 ms cycle, pretty much the best Windows can realistically achieve. My own dashboard does the same ,the art of not blocking a hole thread. I strongly suggest checking your measurement code again – something there is most likely off.
    Regarding Windows jitter in general: I handle it by processing pulses on a fixed 1 ms cycle and filtering the incoming data accordingly, just like you would do in any other control system.
    And now you’re hitting the core problem I was referring to earlier: how do you count the pulses?
    With callbacks, this simply won’t work. You need a hardware counter. There’s no way around it. Sorry, but that’s the reality.
    One small hint: look for ways to teach the hardware itself to send a predefined number of pulses, so that you don’t have to count them in software.
    Think in terms of DMA-driven peripherals rather than interrupts or software counters. On the ESP, things like DMA combined with U*RT or similar peripherals can sometimes be abused for this kind of task. Timers are not the right tool here. I don’t remember all the details anymore, but this is the general direction you should be looking in.
    This is also where the ESP reaches its limits. You cannot generate a pulse, trigger an interrupt for every single pulse, increment a counter, and continue – especially not at these frequencies. Pulse counting must happen in hardware. Otherwise it’s a dead end.
    Have fun experimenting – I’ve been working on this for five years now.
  16. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    Oops, long text and many questions... I fear I can't answer all of them at once. I'll try as soon as I have time.
    1. I also measured high variations of the UDP packets ariving from FlyPT Mover. IIRC, I got something around 1..3 ms for most of them and 4ms worst case. But I noticed that FlyPT Mover has already accounted for the jitter so every time I got a larger delta time I also got a larger delta position. So I calculate dp/dt and interpolate the position with my own, fixed cycle time of 1ms.
    I have explained that problem and my algorithm in the video linked in post #28.
  17. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    2. I don't do any low pass filtering because that would add delay. A low pass filter always lags behind. Instead I do run a "follower" algorithm like explained in the video with the "head to head car race" analogy. The (servo) driver always tries to keep up with the other car if possible exactly side-by-side (no delay). Only in the case there's not enough power (servo torque) then he will lag behind or overshoot a bit. Filtering is not necessary because this is aleary done by FlyPT Mover. This is only a safety feature avoiding a stall due to overload.
    The smoothing of the jitter (timing imprecision mainly due to Windows scheduling, not network transmission delay) is solely done by assigning timestamps to incoming packets and calculating current speed as delta position divided by delta time. This calculated speed is then added to the current position multiplied by elapsed time from the last exact known position (interpolation or extrapolation).
    Adding speed times elapsed time to the position is effectively an integration operation. If the speed valuue has only the slightest errors they will sum up over time causing drift. To cancel out this error a feedback loop is required that adds (commanded position - actual position) multiplied with a small feedback gain value to the current position.
    3. The same happens if your hardware counter for the step signal generation miscounts or you have noise on the electrical signals. In an open loop system there is no way to detect or correct such errors.(*) So make sure you carefully implement the signal generator and shield the electrical step signals.
    (*) The only solution would be to use feedback from the encoder and comparing actual and nominal position. But that's overkill and normally not required.
  18. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    I agree with @Motion4Sim that an ESP32 will come to its limits when you have to calculate motoion for 6DOF. But I see no reason why 100kHz and 0.0027mm resolution should be a problem. Yes, the bigger your steps are the more the system will behave like a stepper motor an make some noise at slow speeds where individual steps can be heared and felt. It may produce a little whining and grunting noises but it will make no difference for the overall motion.
  19. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    BTW, @Dirty has just pointed me to one of my older posts where I documented the timing jitter. I have recorded the timing with hardware timers and my software running on the bare metal and without any OS. So the jitter is definitely there. But if you do the calculations in the right way it's not harmful.
