SimTools v3 Public Beta
  1. yobuddy
    51,353Coins
    Hi @GregJam,
    Xplane requires some in game settings, did you check the 'Network via UDP' boxes, in 'Data to Output' for these indexes: 3, 17, 37, 66, 135? (if there is a wrong one selected, or one is missing, you may get strange output is why I ask.)
    https://simtools.us/plugin/?varname=588&color=0e97dd
    Hi @Racer54098,
    We will give AMS2 a test tomorrow when we get to the PC. (All of what you describe above could be caused by an update to the game, we will know shortly.)
    Chat soon guys!
  2. Petrus_SM
    Petrus_SM New Member
    Hotel Night Manager
    Melbourne, Australia
    276Coins
    Hi, can anyone help me setting up Simtools 3.0 for my old DOFReality P3? I recently upgraded my PC and I have to re install Simtools again. The original setup guide was with the old Simtools and DOFReality is now using SRS which I can't use because my P3 still use the old version of control box. I can't find the setup guide for the new Simtools 3.0 anywhere. Thanks in advance
  3. yobuddy
    51,353Coins
    @Petrus_SM,
    v3 is not a ton different than v2, so we should be able to use your v2 setup guide to setup v3. What are you getting stuck on with the setup?
    Chat soon,
  4. Petrus_SM
    Hotel Night Manager
    276Coins
    The simulator moves fine when I do the Axis assignments test but it won't move during the game.
  5. Petrus_SM
    Hotel Night Manager
    276Coins
    Hi, it's working now. For some reasons it doesn't work when I run from Steam and it works when I run from Simtools app. Thanks
  6. yobuddy
    51,353Coins
    Hi @Racer54098,
    I just pushed a SimTools update that should resolve your errors buddy.
    Please let SimTools update the next time you launch it, and your errors with AMS2 should be resolved.
    Thanks for reporting the error, and please let me know how it goes.
    Take care,
  7. yobuddy
    51,353Coins
    Hi @Petrus_SM,
    So glad you got it working! :thumbs
    There is a setting on the options page for v2 style 'auto detect games running' if you would rather use v3 that way. Otherwise by default, it's setup to launch games with a double click of a plugins play button.
    Take care,
  8. dgiatr
    dgiatr Member
    243Coins
    Hello yobuddy,
    currently i face an issue and i would like your help.
    i cannot start (boot) my pc or cannot shut it down while the servos that are connected to an Arduino board to control a pneumatic g seat with simtools are on power. If i turn off the ac to dc power supply which is connected to my servos then i can boot or shut down my pc.
    Thank you.
    152,971Coins
    +11,115 / 56 / -2
    Can you please post pictures of all of your settings and specify what code your are running on the Arduino.
  10. yobuddy
    51,353Coins
    This sounds like a grounding problem, where you could be back-feeding power to the usb port. Maybe check all your wiring and see if you find any errors. Do you have a wiring diagram of your setup?
  11. Racer54098
    Racer54098 New Member
    105Coins
    Motion platform, 4DOF
    Thank you very much! I got this tested moment ago.
    I did it like this:
    1. AMS2 game open from Steam, monitor only (My Play shortcut is configured to launch VR, this time I did not want VR)
    2. Double-clicked SimTools "Play" to connect to AMS2
    3. Default profile selection on.
    4. On the first attempt, I took the same car (MB GT4) to the track. Profile changed to MB GT4 and data came to all DOFs. So far so good.
    5. I kept SimTools connected to AMS.
    6. I tried to manually change the profile to default.
    7. I went to the main menu and back to the test drive MB GT4. The default profile will NOT change automatically anymore.
    8. When I exit and re-launch SimTools and don't touch the profile, it works again.
    9. Second test: Again, if I change the profile to default or any other car profile, SimTool doesn't change back to a correct car profile, when I go driving from AMS2 main menu.
    10. It doesn't help even if I stop the plugin connection and reconnect.
    DOF min/max values seem to flow ok, though.
    So maybe not totally ok? I hope this helps.
    PS:My forum alias looks pretty boring...default random name&number...I should do something about ito_O
  12. dgiatr
    dgiatr Member
    243Coins
    Is it related that i didnt let simtools to make the new update?
  13. yobuddy
    51,353Coins
    No, It sounds like a wiring problem to me. Maybe the motors are not ground isolated, and they are connected to the frame of the sim?
  14. yobuddy
    51,353Coins
    Hi @Racer54098,
    SimTools only changes profiles when the vehicle changes in the game. So after you do these steps.
    After step 6, please change vehicles in the game again, and the profile should auto switch for you as needed. SimTools only tries to switch profiles when the vehicle changes in the game. Since the vehicle has not changed at this point, the user can manually select a different profile to compare then with each other. But if auto is on, and the vehicle changes in the game, then so should the profile.
    We could lock the profile drop box when auto is on, and it would keep users from changing the profile, but its nice to be able to compare profiles when tuning in a new vehicle in the game I think.
    Anyway, maybe run one more test and see what you find.
    Take care,
  15. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    report this error that happens to me on 2 different PCs when I start simtool 3 and launch the rf2 game my play button works correctly but if during the game I have to stop the data and movements to do some calibrations to the axes the button no longer responds I have to restart simtool v3
    https://photos.app.goo.gl/iR7Qm4GAkjM5wjAJ7
  16. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    Code:
  17. yobuddy
    51,353Coins
    Are you double clicking the play button?
  18. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    yes
  19. yobuddy
    51,353Coins
    Hi @spyderwash,
    Please make sure you have installed the latest SimTools update. (As it has a profiling fix in it)
    I just did a quick test with LFS (as I don't have rf2 handy) but with LFS anyway, I can stop and restart the game plugin just fine. one click to stop, two clicks to restart.
    But I will have one of the guys (with this game installed) give it a shot later, and see what we find.
    Chat soon,
  20. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    now i understand my double click was not fast enough
    thanks for your quick reply
