FlyPT Mover
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,154Coins
    DC motor, 6DOF
    @pmvcda I discovered with horror that the planes in „flying circus“ (1stWW) in the il2 series are incompatible with those from previous series. I am trying to figure out the accel directions which seems different to those from previous releases. Those with gravity you set up back that unfortunately doesn’t work with the WW1 planes.
  2. pmvcda
    13,990Coins
    Coming from them, it's possible.
    Give me some feedback if you can please
  3. hexpod
    berlin
    7,154Coins
    DC motor, 6DOF
    Ok, after a quick analysis (I always can be wrong) I think the sway (lateral accel.) is inverted once we choose WW1 birds. You can see the overcome in the screenshot (minus sign in “sway” and “mix sway in roll) which shows how great and flexible mover is. You should guess why the accels with gravity are getting stuck. I it’s possible to fix directions in flying circus without breaking them in other series you can go for it.
    Cheers
  4. dureiken
    dureiken Active Member
    1,236Coins
    Hi
    can't wait the beta ;) thanks for the work
    Is it possible to communicate via bluetooth in actual version ? and in the next one ? for wind or led for example.
    THanks !
  5. Avee
    Avee Virtual Pilot
    1,082Coins
    The way I read the docs, when loading a plane there should be a FOCUS event over UDP with the name of the plane in it. That could theoretically be used to set a custom gain. But it would have to be coded in the source code, no way to do this as a generic UDP input.
  6. pmvcda
    13,990Coins
    That is done for the new release, the problem is that events are events, it's not info received with a good frequency to imediatelly update the setup...
  7. pmvcda
    13,990Coins
    No, but I'm looking at it for the new release. Not for day 20...
  8. Avee
    Avee Virtual Pilot
    1,082Coins
    True, the best fix for this would be in the source code of IL2, not yours.
