SIMHUB MOTION FOR SMC3
Discussion in 'Commercial Simulators and Peripherie' started by Silyn, Jun 6, 2024.
  1. Misanthrop
    Misanthrop Active Member
    736Coins
    Apart from the Stewart platform, everything is possible with SimHub.
    In my opinion, it is currently the best software for simracers. It supports Motion (with different layouts of the vertical actuators), 2xTL and Surge. Additional screens and dashboards, Iflag, Wind, Bassshakers, Streamdeck etc
    In combination with Arduino much more.
    The cost of the software is really reasonable for the functionality and new features are added very frequently.
    Unfortunately, I have only made a direct comparison with SimRacingStudio, SimTools does not satisfy me in terms of the interface and handling.
  2. izolyator
    izolyator Member
    276Coins
    2DOF, 3DOF, Arduino
    is it possible to test effects in simhub like in simtools, roll for example?
  3. izolyator
    izolyator Member
    276Coins
    2DOF, 3DOF, Arduino
    I just purchased 2 licenses, now I need to figure out how to run everything
  4. Misanthrop
    736Coins
    Yes of course. You can test effects and your acuators individually.
    Simhub is clearly superior to SRS, for example, and I haven't yet found anything that Simhub doesn't have. The fact that you can set softlimits, filters and max speed separately and individually for each movement and actuator alone is a huge advantage.
  5. frenchfly
    frenchfly Member
    Mold Maker
    Winnipeg, Canada
    - 338Coins
    2DOF, JRK
    Can I use Simhub with a JRK driven set-up?
  6. Silyn
    Silyn Member
    44Coins
    3DOF, DC motor, AC motor, Arduino, 4DOF
    Generic serial, yup!
  7. Luc1gnol0
    Luc1gnol0 New Member
    Itala, Italy
    246Coins
    Can i use simhub with velleman k8055?
  8. Silyn
    Silyn Member
    44Coins
    Dunno, doubt it.
  9. frenchfly
    frenchfly Member
    Mold Maker
    Winnipeg, Canada
    - 338Coins
    2DOF, JRK
    I tried setting up on my JRK driven sim yesterday and I got it moving my motors but it was moving it to it's limit no matter how small I set the percentages. Wish there was a better guide, I'll just have to look play around with some settings till I can get it working.
  10. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, I switched to the simhub motion software too, it works very well, just a quick question, I can't find where to change the direction of the right-left effects. Thanks
  11. Silyn
    Silyn Member
    44Coins
    Screenshots help :) it's likely the bit rate being /18 when it should be /16
    When you assign the axis' just make sure they move the right direction, or reverse them. It's under the output settings
  12. bruno1210
    bruno1210 schumi06
    103Coins
    S'il vous plaît, aidez-moi dans simtools, nous pouvons changer la direction des moteurs par effet, mais dans simhub, le mouvement n'est pas trouvé
  13. Silyn
    Silyn Member
    44Coins
    I see motors are set in your screenshot with one reversed, it's the effect specifically you want to reverse? Which effect and why? Does it not move as it should?
  14. Silyn
    Silyn Member
    44Coins
    Make sure your axis resolution is set right here
  15. bruno1210
    bruno1210 schumi06
    103Coins
    I have two motors, braking and acceleration effect are perfect just right left which are reversed I changed the direction of the motors and there the braking and acceleration are reversed on simtools we can reverse each motor with its effect
  16. Silyn
    Silyn Member
    44Coins
    When you use Manual Control, does it move in the correct direction?
  17. bruno1210
    bruno1210 schumi06
    103Coins
    where is the manual control ? please
  18. Silyn
    Silyn Member
    44Coins
    Enable motion button, then the button on the right that says manual control
  19. bruno1210
    bruno1210 schumi06
    103Coins
    for roll effect my seat moves forward and backward and for pitch effect it goes right and left
  20. Silyn
    Silyn Member
    44Coins
    Sounds like you have them configured wrong in the output settings.
