FlyPT Mover 3.5.3
  1. pmvcda
    15,384Coins
    Sorry for the delay. Was travelling.
    So I join a setup for the latest Mover.
    Ignore some items above. It's development fields for 3.7.0.10 that show on the main window.
    I think it has exactlly what you have in 3.5.3 in the rig and outputs.
    You have to choose the correct ports.
    On the rig, angles changed in the new Mover -180 to 180 (it was 0 to 360)
    I also made an oscilating loop to have an effect on the rig (pitch/roll/sway/surge)
    I also think you should test other positions for the actuators. Not sure this is the one that gives you more range.
  2. Ronan Design
    Toronto, Canada
    1,696Coins
    Thanks a million! I answered in the other topic as appropriate for this new version.
  3. OHersent
    OHersent New Member
    45Coins
    Hi everyone,
    I have spent some time documenting a rational use of filters and a tuning procedure for a given plane (characterized by its maximum accelerations & roll speeds). You will find attached both the .doc introducing the concepts and corresponding screenshots. A tuning tool is also used to adjust filter constants and visualize the corresponding platform motion on a given axis in order to not exceed maximum displacement. Example tuning provided for Cessna.
    This procedure is aiming to reproduce actual accelerations as accurately as possible as felt in a real plane. A simple test failed by all "gaming" simulators developed for cars is to push one pedal while keeping the plane level: you should feel a strong side acceleration (seat tilted to the side). It fails because these simulators don't properly model the accelerations felt by the pilot. PTMover allows to do this properly and therefore can be used for a pilot school.
    I hope it helps!
  4. pmvcda
    15,384Coins
    Wow, thanks for this. Just gave it a peek, but I already saw it looks great and detailled.
    I will be in Stockholm the next days, but I promise I will read and test it after new year.
    We have to talk! Need you to help me with Mover. :D
    152,045Coins
    +11,063 / 56 / -2
    Thanks so much for sharing your awesome work :thumbs
    I have added it to the FlyPT section of the FAQs, with credit to yourself: https://www.xsimulator.net/community/faq/flypt-tuning-tool.410/
  6. Ronan Design
    Toronto, Canada
    1,696Coins
    I have trouble with the park pose. My new 6DOF rig is semi-functional and I'm setting it up. How can I make the park pose stick, it doesn't work for me. The trick is that I have a gas strut in the middle of the rig, so without me on the rig there is too much stress in anything but the top heave position. So I defined it as a park pose. But it doesn't really seem to work. I can see motors struggling a bit then it just goes to the middle position. I would like it to slowly go from whatever position the rig is when powered to the park pose (all actuators near the top) and stay there until it gets real telemetry data. Alternatively, maybe there is a way for me to command the middle position manually, when I'm ready? Maybe I'm not understanding well what the park pose does.
  7. pmvcda
    15,384Coins
    The park pose is where the rig goes when you disconnect the output.
    You also have the drive pose and that is where the rig stays when there's no data and the output is connected. Movement is made around the drive pose.
  8. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    Hello. Does or will Assetto Corsa Evo work with Mover 3.5.3 or is it only 3.7 that will eventually work with it?
  9. pmvcda
    15,384Coins
    Works with 3.5.3
    Will be in 3.7 for next release
  10. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    Thank you!:)
  11. Ronan Design
    Toronto, Canada
    1,696Coins
    What's the proper way to filter out and dampen a sudden movement - like a crash? While tuning my new 6DOF build I was getting happy with the accelerations and motion cues, but then I ran out of runway and crashed into a building. It sent a rig violently crashing forward, disabling the motors. So I need a filter that only limits (damps but not completely removes) violent large movements while keeping all the precision of the smaller fast ones, or the amplitude of slow large movements.
  12. J-1775
    J-1775 Aviator
    1,576Coins
    I'm not the expert here, but you could try SPIKES. But it depends on your input. If you use an acceleration value, then a simple limiter would probably do what you wish (as a crash is a violent deceleration). I often take LOGISTICS as a limiter. It's not a cutoff, but a curve that you can manipulate to your likings.
  13. Ronan Design
    Toronto, Canada
    1,696Coins
    Yes, I used spike for now, seems to be working... I'm not exactly sure of the parameters Does 5;3;2 make sense? Here's what I have in Surge now, for example:
    In gain -1 | SPIKE(EMALP(EMALP(EMAHP(VALUE;110);150);400);5;3;2) | Out Gain 110
    The whole rig has a scale of 0.7 to match motor arm movements to reality.
  14. J-1775
    J-1775 Aviator
    1,576Coins
    There may be disciplines where my skills match or even supersede those of Pedro, but certainly not math or physics! ;) Therefore my approach is often trial & error. With the visual rendition of the filter chain and virtual projection of the rig, all in real time, as well as the integrated recording and playback tools, FlyPT Mover makes this approach quite viable. And when you finally mount your chair, you have to make only slight ajustments and don't end up thrown off the chair.
    My suggestion: repeat your maneuvre and record it: a) brake hard, b) accelerate quickest and c) crash into a wall. Then play back and note the max. acceleration/deceleration values of a) and b). That gives you the envelope you want to work with. And you may cut off all input values beyond.
  15. Tarak Makwana
    Tarak Makwana aimbug
    1Coins
    I am on the version 3.5.3, adding the source forza horizon 4, but not game not connecting, please guide how to connect, i have turn on the telemetry data from the games and added IP and port number but not connecting please help
  16. Zhang
    Zhang New Member
    2Coins
    Hey I am attempting to create a game that inherently has the function to send data to a port using UDP. Previously, I successfully sent Roll, Pitch, Yaw, Sway, Heave and Surge data to SimTools. Now, I want to use this function on FlyPT to send data to the Custom UDP source. Currently, the Custom UDP source is indeed receiving data, but it cannot extract the corresponding data. Is it possible that FlyPT requires a unique data format?
  17. Ray phillip Orchard
    Ray phillip Orchard New Member
    32Coins
    hi all,
    anyone share any settings for flypt mover - cant seem to even find correct rig type
    thanks
  18. Erik Green
    Erik Green Member
    339Coins
    The COR for the rig is to define the seat position relative to the actuators so the motion software can correctly calculate motions correct? Does the source COR need to be set or does the default telemetry (AMS2 in my case) already account for driver position in the vehicle?
  19. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    214Coins
    From memory, the COR is used for the center of gravity, and is mainly used for aircraft simulations. Basically, if you're in a Cessna, a small aircraft, the center of gravity is close to zero, but if you're in a Boeing, the pilots are far from the aircraft's center of gravity, several dozen meters away!
    This makes the simulator's reactions more realistic.
    So for cars or small aircraft, the COR is useless... for me!
  20. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    214Coins
    What type of simulator are you looking for? Aircraft or car?
    And what type of simulator do you have? 2 DOF, 3 DOF, or 6 DOF?
