Motor driver
Discussion in 'New users start here - FAQ' started by Stahlwolle, Dec 1, 2024.
  1. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
    I use these, the motor can draw 21A at its peak
  2. Attyla.pl
    Polska
    1,336Coins
  3. Attyla.pl
    Polska
    1,336Coins
    One more thing, in smc3utils do not use square wave or fast shifting manually, you can easily damage power supplies or IBT2 drivers, for testing use sine wave.
  4. Stahlwolle
    Stahlwolle Member
    268Coins
    Thanks a lot for your help! I also think I overdid the testing a bit.
    I also tried to get Simtools to work, but it doesn't open after starting. When I press alt+tab, the open windows appear, but when I click on them they don't open
  5. Attyla.pl
    Polska
    1,336Coins
  6. Attyla.pl
    Polska
    1,336Coins
    Of course, the heatsink should be tightened to the diode.
    153,764Coins
    +11,149 / 57 / -2
    SimTools automatically minimises to the system tray once started.
  8. Stahlwolle
    Stahlwolle Member
    268Coins
    But how do i select a Game and setup configurations then?
  9. Stahlwolle
    Stahlwolle Member
    268Coins
    I cant show up a screen Like this, it only shows up as a preview when i press alt+Tab, and wont open if i click on the preview screen, it stays in Background.
  10. Stahlwolle
    Stahlwolle Member
    268Coins
    Forgot picture
      187.3 KB
      192
  11. Stahlwolle
    Stahlwolle Member
    268Coins
    ok, got it nowhug:
  12. Stahlwolle
    Stahlwolle Member
    268Coins
    I got the two new power supplies today, 600W this time...
    The bridge rectifiers are also there, I milled a couple of heat sinks, I hope everything works now.
    Thank you both for your help so far!!!
  13. Stahlwolle
    Stahlwolle Member
    268Coins
    I have now tested again with sine and motion in smc3. The left motor constantly stops when turning downwards, and then the motor is switched off by the program.
    This happens when the other motor leg turns upwards. As if the motors are only designed to rotate in one direction.
  14. Stahlwolle
    Stahlwolle Member
    268Coins
  15. Attyla.pl
    Polska
    1,336Coins
    I understand there is a left engine in the video ?
    The movement looks correct, you write that the motor is switched off by the program, do you mean SMC3Utils? and the fact that with the motor number the button changes from ‘ON’ to ‘OFF’?
    If it changes to ‘OFF’ it means that the range of the signal read from the potentiometer/hall sensor has gone beyond the safe limit, show the video from SMC3Utils.
  16. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    It looks to be exceeding its limits as a result of inadequate power, which could relate to settings, hardware chosen, and/or design factors.
    Please post pictures of all of your settings, including running the Sine test.
    Keep in mind a lever's most effective torque utilisation is at 90 degrees. and that degrades in a nonlinear manner, rapidly so after around 38-40 degrees up and down. What I mean is τ = r F sin(θ): https://www.omnicalculator.com/physics/torque
  17. Stahlwolle
    Stahlwolle Member
    268Coins
    I think I made it through the settings yesterday, the motors now have more power in both directions... I'll post my settings later though. Thank you!
  18. Stahlwolle
    Stahlwolle Member
    268Coins
    It's very Stränge... The motors (or the Arduino) stop at irregular intervals or simply start rotating at full speed. This can also happen when no power is required at all.
    For example, in the menu of Live for Speed...
    153,764Coins
    +11,149 / 57 / -2
    Please post pictures of all of your SMC3 settings, including running the Sine test.
  20. Stahlwolle
    Stahlwolle Member
    268Coins
