6Dof Linear Hexapod Build
Discussion in 'DIY Motion Simulator Projects' started by Pinballcat, Mar 24, 2021.
  1. Nuno lo
    Nuno lo New Member Gold Contributor
    195Coins
    Thanks mate. I went 10mm. Hope that its enough lol
  2. Bastiuscha
    Bastiuscha Active Member
    750Coins
    Would like to see a video with driving action. :)
  3. Nuno lo
    195Coins
    Here you go mate. Cant upload video for some reason
    153,926Coins
    +11,156 / 57 / -2
  5. Wiley
    Wiley New Member
    22Coins
    Motion platform, 6DOF
    I just bought a THANOS controller and six 80ST 750W motors yesterday. I really like your design and had a question about a design decision of the motor being in-line to your actuator instead of flipping the motor 180 with a belt and two gears?
    Robert
    153,926Coins
    +11,156 / 57 / -2
    Just observing that both are legitimate options, basically simplicity Vs a bit more compact design.
  7. Wiley
    Wiley New Member
    22Coins
    Wouldn’t flipping the motor make it more compact because the overall length of the actuator would be shorter ?
    153,926Coins
    +11,156 / 57 / -2
    Yes it would, but with the additional coupling and mounting complexity that goes with that, so as I mentioned earlier it is a tradeoff between simplicity Vs a bit more compact design.
  9. Wiley
    Wiley New Member
    22Coins
    Thanks for your opinion and expertise it is really a big help.
  10. Thanos
    Electronics Engineer
    2,907Coins
    Basically this...
    https://departedreality.com/products/dr-diy-ps
