SimTools v3 Public Beta
  1. VFX Pro
    VFX Pro Member
    Los Angeles
    377Coins
    Motion platform, 6DOF
    Does anyone know if Assetto Corsa Evo will have a SimTool 3.x plugin soon?
  2. Joe Cortexian
    1,129Coins
    I came here to find out. I did some research and apparently it’s the same protocol as AC and ACC. But you can’t believe everything you read in the internet.
  3. yobuddy
    50,998Coins
    Question below...
    Could either of you give me the exe name, and the running process name for AC Evo (usually the same). Then I can put together a test plugin for the game.
    Chat soon!
    • Useful Useful x 2
  4. VFX Pro
    VFX Pro Member
    Los Angeles
    377Coins
    Hello @yobuddy
    As requested.
    Path => C:\Program Files (x86)\Steam\steamapps\common\Assetto Corsa EVO\AssettoCorsaEVO.exe
    Task Manager Process
  5. VFX Pro
    VFX Pro Member
    Los Angeles
    377Coins
    @yobuddy
    Here's something that might be helpful in creating a motion plugin based on telemetry. Simhub already did tap into it.
  6. Tino.Sturlic
    Tino.Sturlic Member Gold Contributor
    209Coins
    I am trying to transfer from Simtools V2 to V3 as it seems I need to reinstall my windows as I could not find a way to have a stable connection to the interface. before I reinstall it I need to check if everything works.
    Is there a way to transfer my setup and presets to V3?
    I have very extensive setups I was working on for months, do I need to input all manually again in the V3?
    I cant find any import option for presets or setup in the V3 version.
  7. VFX Pro
    VFX Pro Member
    Los Angeles
    377Coins
    I wish there was an easy way to export and import out of Simtools (for Windows Reinstalls, or just for backup)
  8. yobuddy
    50,998Coins
    Unfortunately, the files between the two versions are not compatible. So re-setting up will be required.
    You can do this with SimTools v3, go to the options page and in the lower right click export wizard. If your sim is all setup and working correctly, export a setup file (no extra settings are needed) simply name your setup file and export the file. Next, you can export any game plugins that are setup. Be sure to export them as custom game plugins (so all your profile settings get included)
    When you want to re-setup v3, simply launch SimTools v3 and then drag-drop your setup file into v3. (Then simply follow the on screen prompts) . After the setup file is installed, drag-drop your backed up game plugins into v3 and your all setup again with no settings being required by hand.
    Hope this makes sense buddy.
    Take care!
  9. yobuddy
    50,998Coins
    plugin posted to the server...
    NOTE: Not all of the telemetry data usually available for the Assetto Corsa games, is currently available for Assetto Corsa EVO. Because the current games Status is also not available, telemetry currently starts before your actually on the track. This plugin will be updated as soon as the rest of the telemetry is available.
  10. Moe Colontonio
    Moe Colontonio Member Gold Contributor
    New Jersey USA
    788Coins
    I also seem to have this issue a lot. I click save a hundred times, click capture and then save, etc. Only to find that next time I fire it up my settings were not saved. I'd also love to see a descriptive name in place of the cloud/runway as this really threw me for a loop when I first used V3.
  11. peter stolmeier
    peter stolmeier Member
    528Coins
    After you save you have to close simtools by right clicking and choosing exit for those settings to save. I'm sure they're working on it, but that's how you can do it for now.
    • Informative Informative x 3
  12. early_m
    early_m Active Member
    Chelmsford
    819Coins
    Yeah anytime I want to ensure settings are saved I do this.
  13. airpix
    airpix AA -Altitude n Attitude
    Northern NJ
    21Coins
    2DOF, AC motor
    I have a 2 DOF, GTR compact motion simulator. Two motors, left and right of the seat facing aft. I mainly fly MSFS 2020 and MSFS 2024. I am trying to setup pitch and roll. Pitch meeds to have one channel reversed. I have some washout and gain set for roll. When I’m on the runway and I start simtools v3 the motion simulator pitches aft as if already accelerating. Hardly any braking. I have set up surge but had no luck. It accelerated and braked fine on the deck but once airborne the pitch was reversed. I tried all combinations of reversing pitch and surge but no luck. Any help in setting this up correctly? Thank you
  14. JayMonkey
    JayMonkey New Member
    52Coins
    @yobuddy,
    Many thanks for ACE Sim Tools 3 plugin ....
    I was able to download and install the plugin via Sim Tools 3 UI and it works.
    Open question: Is anyone else finding the surge axis with ACE is super agressive compared to AC and ACC ?
    I suspect that the issue is more to do with the early access version of ACE and it's incomplete telemerity and that this will be resolved in a future ACE update, but was just curious to know if anyone finds the surge axis with ACE unusable in it's current/default state ?
    For sure I could create a custom profile for ACE and increase the amount of smoothing on the surge access via the filters but was hoping that I could use the same motion profile as I do for AC and ACC which both use the same (default) profile on my rig.
    Cheers
    Jay
  15. early_m
    Chelmsford
    819Coins
    I've tested it quite a bit and have no issues with surge - feels great to me and getting a nice little snap during gear change. Nice details in other DOF too.
  16. Joe Cortexian
    1,129Coins
    Just started using SimVibe. My rig is setup for Flight Simulator but I cannot get anything working.
    I bought a USB sound card (so cheap). For a test I set it to be the main sound card and I get vibration in the Buttkicker as expected.
    Next i moved on tho the vibe setup. Here is what I did to set it up (this is the first thing I have attempted with Vibe).
    1) Setup the interface
    2) Setup the volumes for MSFS
    3) Setup high low range
    I get nothing. What did I miss?
  17. dgiatr
    dgiatr Member
    253Coins
    Hi yobuddy, is there any chance that simtools could recognize each model that the simulator runs at that time? Thank you..
  18. early_m
    Chelmsford
    819Coins
    Do you get output when you test in the interface settings? Make sure the master volume for you is sound card is set to 100 (volume icon in system tray)
    FYI I have been using vibe for a while and can confirm it works.
  19. Joe Cortexian
    1,129Coins
    I verified that with my stereo USB sound card it does work in test mode. I just loaded MSFS 2024 so I will see if I can get that to work. Didn’t realize I could test there even though I looked for a test button vs Turn On.
  20. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    Hello everyone, someone has problems getting movement in dirt rally 2.
    I am using simtools v3 in all the games I have movement and it works very well, but not in dirtrally 2, any advice?
    win 11
    simtools v3 ( of course i use the plugin v3 )
    thanks
