2 dof with ibt 2 and smc 3 problems
Discussion in 'DIY Motion Simulator Projects' started by dope-walker, Jul 14, 2021.
  1. titofe
    titofe Member
    652Coins
    2DOF, Arduino, SimforceGT, Motion platform
    hello Thank you for your response I am sorry again for the translation thank you I will be careful next time I will follow your advice simtools V3 thank you.:thumbs
  2. Fotomarco
    Fotomarco New Member
    - 37Coins
    2DOF, DC motor, AC motor, Arduino
    Hollo i have the same problem you have resolvé the problem ? With SimTools v3 ?
  3. DANIEL ST-PIERRE
    DANIEL ST-PIERRE New Member Gold Contributor
    17Coins
    2DOF, DC motor, SimAxe, Arduino, Motion platform
    hello
    i have a same problem, run test motor good, but lfs does'nt no motion outpout , please help me
  4. DANIEL ST-PIERRE
    17Coins
    My PC is french, also for live for speed , language french , simtools v3, is it it's the language the problem ????
    153,770Coins
    +11,150 / 57 / -2
  6. Fotomarco
    - 37Coins
    I have tried and the program not work , i must have another program
  7. titofe
    titofe Member
    652Coins
    Hello yes yes I managed to adjust the engine. You should uninstall simtools and install V3 thank you
  8. Fotomarco
    - 37Coins
    I'm going to try Simtools 3, after moving the engine with Simtools Users, the engine vibrates slightly can be solved
  9. titofe
    titofe Member
    652Coins
    hello that's it first the engine adjust it reacts well with the LFS commands. thank you
  10. titofe
    titofe Member
    652Coins
    new problems with the 2nd engine adjustment. as soon as I start the green line and go up it goes down quickly it cuts off the values they are lower than the first motor thank you
  11. titofe
    titofe Member
    652Coins
    in the picture you can see motor 1 completely disconnected.
  12. titofe
    titofe Member
    652Coins
    Do you have any ideas on how to adjust the 2nd motor? Thank you
  13. noorbeast
    153,770Coins
    +11,150 / 57 / -2
    Are you using a 180 degree hall sensor, if so it could positioned 180 degrees out.
    Also try swapping the control boards around and see if the problem follows.
  14. titofe
    titofe Member
    652Coins
    thank you for the answer hall sensor no I don't use is there a photo where to put it. on the other hand the card for the second engine is the second one because the first one had burned out, it is brand new.
    153,770Coins
    +11,150 / 57 / -2
    Being brand new is not a guarantee there is no fault, and swapping cards is an easy check.
  16. titofe
    titofe Member
    652Coins
    ok I'm going to try a new card on the other hand the hall sensor do you have any photos? on the other hand, 1 motor is well adjusted but the second one has interference everywhere.
    153,770Coins
    +11,150 / 57 / -2
    Whith electrical interference carefully check cable management, use shielded wire, and Ferrite magnets can all help.
  18. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
    swap the plus and minus wires on the motor output of the IBT2 controller by place.
    Run the “Sine” control on the first engine and then compare with the second engine you will see the difference
  19. titofe
    titofe Member
    652Coins
    :acclamations
  20. titofe
    titofe Member
    652Coins
    hello big disappointment today I managed to get new iBT 2 cards to be able to adjust the second motor I lost everything even the adjustment of the first motor it's incredible I can't even adjust the first motor, I'm a little disappointed for the 1 motor it was well adjusted it reacted well. if you have any idea thank you friends.thank you:(
