SimTools v3 Public Beta
  1. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    Hopefully the SimHub port forwarding information in the FAQs can be helpful: https://xsimulator.net/community/faq/simhub-port-forwarding.356/
  2. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    thanks a lot for the help, but i try port forwarding the
    udp 20777 - 127.0.0.1 to
    forwarding ,on, udp 20778 127.0.0.1
    not work for me, i dont know if i made something wrong, i keep trying.
    for the moment I configure simhub, simtools stops working :sos
    153,764Coins
    +11,149 / 57 / -2
    Perhaps post pictures of all of the settings, so members who use both can comment.
    Basically 2 different apps can't access the same UDP at the same time, but can pass them on, so something sounds like it is amiss.
  4. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    well I share one of the configurations that I try, anyway I try 4 possible configurations including doing it manually in the xml files, but without results, when I get simhub to work, simtools stops working, if anyone has a clue to follow it would be of great help. i will keep trying
  5. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    another config
  6. Joe Cortexian
    1,537Coins
    Following up on SimVibe. I verified that the Buttkicker executes in test mode. I setup Live for Speed. Unfortunately, in game I have nothing at all. The test screen is extremely loud . I assume I just missed a button somewhere.
    NOTE: Motion is working just fine so its hooked up to the game.
    I have a video of setting up AC I could post but I am still hoping its a simple issue.
    Here are the screens from LFS:
  7. early_m
    early_m Active Member
    Chelmsford
    839Coins
    Have you set up the sounds for rpm, gear change, etc in vibration editor?
  8. Joe Cortexian
    1,537Coins
    The what now? No I assumed there were default values. I knew there was something missing. Thanks for the help. Works now.
    Would it be helpful if I made a video for newbies using the V3 menus?
  9. early_m
    Chelmsford
    839Coins
    Made a little video demoing how changes to the profile intensity slider affect the motion sensitivity:
  10. Jean Paul Andrade
    Jean Paul Andrade Member
    272Coins
    Hello Guys, I just installed F1 2024, I can`t make it work with simtools V3, I completed a race, the telemetry is set , udp port configured 4123, ip 127.0.0.1 but it still not activate the simtools when the game starts on steam, I even tried writing the settings in the launch options on steam -telemetry network -port 4121 -ip 127.0.0.1 any advice!¿?
  11. Joe Cortexian
    1,537Coins
    You need to start from simtools. For vr specify -vr -openxr in the startup switches in steam.
  12. Jean Paul Andrade
    272Coins
    thanks for the reply, but even if I drag the shortcut to the simtools it doesnt start from there, anyways I didn't had to do it in F1 2022 or any of the other games, this is the only one that isn't working, F1 22 is running with no issues
  13. Joe Cortexian
    1,537Coins
    That's the only one I own (F1 22 included) that won't hook up unless you start it from SimTools. Installed from Steam?
  14. Jean Paul Andrade
    272Coins
    I installed on steam, I drag the shortcut to the simtools but it won’t start when I hit the Play Button!
  15. yobuddy
    51,526Coins
    Please remove the UDP relay, as your rerouting all game packets back to itself. (The UDP relay is so you can send a second copy of the data to another application)
  16. yobuddy
    51,526Coins
    @Jean Paul Andrade,
    Could you tell me the process name for the game when it is running?
    (I will check the plugin source, and make sure the process name is listed in the plugin, as this is how it auto-detects a game is running)
    Thanks!
  17. Jean Paul Andrade
    272Coins
    Hi yobuddy! Thanks for hit me back, the process name is F1_24.exe if that what you mean… can you give me more details about the UDP relay you are telling me to remove please? My rig started to move twice already randomly when I started the game, but only twice of maybe 30 times I have tried with different settings, for now I keep the UDP addres IP 127.0.0.1 and port 4123
  18. yobuddy
    51,526Coins
    You have the UDP relay sending all game packets back to itself in a endless loop. The game packets are already aimed at 127.0.0.1 /4123, so there is no need to loop all packets back to 127.0.0.1 /4123. Or you just get every packet ever sent from the game looping endlessly.
  19. Jean Paul Andrade
    272Coins
    allright, so theres no need to specify in the launch options, theres only configured in the telemetry game options. that's all, and still not workyng, I spend a long time last night trying different things, as I said, is the only game that does.nt work, I just uninstalled F1 2022
  20. Joe Cortexian
    1,537Coins
    I decided to confirm the current status of F1 24. All I did when I installed it was to note that running from SteamVR didn't work and it worked as soon as I started it from SimTools. No drag and drop or any other adjustments.
    1) The executable is F1_24.exe. The process name is F1 24 and there are no child processes in Task Manager. Yes, that is a space in the process name.
    2) When I run from SteamVR there is no indication of any motion "hookup" and no movement in game.
    3) When I run from SimTools the rig moved when F1 24 initialized. This implies motion is hooked up.
    4) When I run the game there is no motion in the game.
    I know that the game had a significant update since I played it last. In that update all assistance setting were turned on which is not the way I left it. My theory is that the update also lost some important motion data. I will try uninstalling and reinstalling the plugin tomorrow. It definitely broke because I ran it every week from when it came out until the end of the season. Now it appears not to work (unless my motion system is coincidentally broken).
