SimTools v3 Public Beta
  1. Jean Paul Andrade
    Jean Paul Andrade Member
    272Coins
    so, it isn't working for you either! the difference is that I can't get it to work from the play button in Simtools, I dont get movement in any way, youbuddy is working in a solution
  2. Joe Cortexian
    1,537Coins
    The process name is <F1 24>. Yep that's a space.
  3. yobuddy
    51,524Coins
    The codemaster games have 2 config files that it patches for telemetry, so if the game was not played in vr before the game plugin was installed, or the update overwrote it, the vr side of thing may not send telemetry.
    To fix this simply remove the plugin from simtools (little trash can on the games banner) and then close simtools. Launch the game in vr and race a lap. then close the game. and relaunch simtools and reinstall the game plugin. (where it can now patch the vr file also for telemetry)\
    I will take a closer look at the process name tomorrow, as a wrong/changed process name would keep the "Auto detect games running option" from working.
    Take care!
  4. Joe Cortexian
    1,537Coins
    I will reinstall today and see if I can get it working.
    MSFS literally broke my rig (2dof) and I kinda need to fix it first. Is there any way to enable a log of incoming game data? It seems to me that everything is fine and you get a spike on both motors. It’s quite violent and doesn’t go down much with 100% smoothing and 30% overall profile.
    I may do the SMCUtils on another PC in the middle to provide a visual of the motor inputs. Or I will just stay in Richard Burns Rally because that it much less violent than MSFS. Seriously.
  5. Joe Cortexian
    1,537Coins
    I did the following and ONLY the following:
    1) Confirmed it wasn't working at all.
    2) Uninstalled the plugin.
    3) Ran a complete race.
    4) Reinstalled the plugin.
    5) Ran from SimTools - worked correctly.
    6) Ran from Steam - did not hook up.
    I loaded the plugin at about 2:00PM EST.
  6. Jean Paul Andrade
    272Coins
    in order to launch from simtools you only have to drag the steam F1 shortcut to the banner of the plugin or is it something else I should know? none of my games launch from the PLAY button, I excute them from steam app or the desktop shortcut and the simtools automatically detect them
  7. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    Going back to the topic, about simhub and simtools to run dirt rally 2, I tried everything, udp forwarding and I had no luck, I read 10 threads and configured everything correctly, well there is no way, I don't know which one works without compatibility, the truth is that It would be great if the simtools plugin worked as before, but I understand it is not a priority.
    If someone gives me a hand I would be super grateful.
  8. yobuddy
    51,524Coins
    Are you 'Double Clicking' the play button?
    Since the game uses UDP to send data from the game, only one application can collect and use the data. (it's just the nature of UDP) So once you get the game working with SimTools, hover over the wifi icon on the game banner to open the UDP Relay options for the game, and enter 127.0.0.1 for the IP, and the port SimHub uses to collect data from the game (I believe its the default port 20777). Now every packet that comes into simtools for the game, a copy gets sent to SimHub. Hope this helps!
  9. yobuddy
    51,524Coins
    I believe this may have something to do with their new anti cheat client, but we are still investigating. The game does work with motion when the game is started thru SimTools itself.
    Chat soon...
  10. Jean Paul Andrade
    272Coins
    can you believe I was not!? is tnat something new? I think I jad started games before with just one click, this is embarassing, well is working now, I can launch the game from the Simtools but in order to play VR mode I have to make two shortcuts? one with the commands -vr -opernxr and other without it? is it gonna be possible to fix the autodetect for this game!?
  11. yobuddy
    51,524Coins
    Yes, It took me a bit to figure out why i could not detect the game launch, but I was able to fix the problem about 30 minutes ago, w00t! I need to do some more testing, but I should be able to push an update tomorrow to fix this problem.
    Take care!
  12. peter stolmeier
    peter stolmeier Member
    558Coins
    I've finally gotten my Yaw motor to work with the Thanos AMC and SimTools! (The motor was quite broken.) I'm now able to fly around space with full three-degree movement.
    My system is "special" in that it can rotate indefinitely—it uses a giant gear and slipring, so it never needs to return to it's starting position on the mechanical level. I spoke to Thanos himself about this, and he said his system can't do the math for infinite rotation, so it must always return to the start position.
    Don't get me wrong, this works great! I'm having an amazing time with the insane amount of rotation I have. However, I’d love to end a gaming session facing a completely different direction than when I started, since every turn adds up. I've considered controlling the yaw directly and sending those commands to the game in tandem, but much like joystick mode, it wouldn’t be truly 1:1 anymore.
    Before I even start planning that, I realized I never asked the specific question to you guys—so let’s make sure: Is there any setting in SimTools that would zero out the yaw after a telemetry instruction instead of forcing it to return to its starting position?
  13. yobuddy
    51,524Coins
    You could use yaw rate if available. The "potentiometer" would not be connected to the sim at all, so the "potentiometer" always stays centered. Then yaw rate is basically spinning the sim in one direction or the other when needed. Feel free to PM me if you want to chat about it more.
  14. peter stolmeier
    558Coins
    Hell yes I'm going to PM you, that sounds awesome!
  15. Roland Munz
    Roland Munz New Member Gold Contributor
    - 114Coins
    unfortunately Gamevibe doesn‘t work anymore in the Games. When I press the Test button in the Game, Simtools crashes immediately (see below).
    But the whole equipment (Soundcard, Buttkickers, Amp) works definitively and everything was fine over months but now I have this problem.
    Do you have an idea?
  16. yobuddy
    51,524Coins
    Please go to your sound card settings and un-select the sound card for SoundCard #1. Restart SimTools and then re-select the sound card for SoundCard #1 and hit save. Then please give it another shot and let me know how it goes buddy.
  17. Roland Munz
    - 114Coins
    Yes, that‘s it!!!
    Many thanks to you yobuddy
  18. Cold Pancake
    Cold Pancake New Member
    90Coins
    Try to lower down the fpwm to 25kHz. Happened to me once, if not try to check the min max of the potentiometers
  19. prophet.id
    prophet.id BOSeTAMPER's Rotary Servo 6dof Build
    313Coins
    What causes 'out of range' in the virtual output?
    I am playing Assetto Corza
    My DIY rig is 6dof rotational using SMC3.
    When an axis 'out of range', my rig stop moving and then resume moving when no longer out of range, which is make sense.
    But how to prevent this out of range? What are the factors?
  20. BrassEm
    BrassEm G-Seat + SFX100 Builder Gold Contributor
    NE of YMML
    1,102Coins
    DC motor, AC motor, 4DOF
    WARNING!!!!!!
    I fired up my SFX-100 rig for a quick fly around the new afghanistan map.
    Turned on the Thanos controllers and homed the rig as normal.
    Fired up Simtools V3 and it asked if I wanted to update? I clicked okay without thinking and....
    After the update finished the sfx-100 rose to its normal zero start point as if I had started DCS???
    DAMN! How do I lower the rig back down? If I start testing in Simtools to "energise the drives to zero point" and they already are at zero point - will they drive even further up and crash at the top end. If I don't have control at the top end the whole rig will crash at full extended height! Not prudent!
    I bit the bullet and shutdown Simtools. The Rig stayed at the "zero" point and didn't lower under any motion control. I had not choice but to hit the E-stop and watch the rig crash down. (It appears my rig is a little nose heavy if any good is to come out of this!)
    I turned everything off for a minute and started the usual start up routine, hoping that any glitch would be flushed out.
    Turned on the thanos controllers and the rig homed.
    The front right didn't home right and read -92 while the others homed okay.
    I turned everything off for a minute and started the usual start up routine.
    Turned on the thanos controllers and energised the drives...
    The rig went wild, bucking as different motors went from limit to limit at full speed. I hit the E-stop and rig crashed to the ground.
    @yobuddy Would you please put a prominent warning on the update dialog to DO NOT HAVE YOUR MOTION RIG TURNED ON BEFORE UPDATING so that others may avoid whatever predicament I am now in.
    Thanks.
