2 dof with ibt 2 and smc 3 problems
Discussion in 'DIY Motion Simulator Projects' started by dope-walker, Jul 14, 2021.
  1. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,332Coins
    At the 3:16 minute mark of the video, you can see the engine trying to start and immediately the potentiometer readings(green line) go out of range and shut down the engine ( Motor 1 OFF)
    The reasons could be two:
    1. you need to change the places of + and - in the IBT2 terovar at the output of the motor because the direction of rotation does not agree with the direction of rotation of the potentiometer
    2. the ratio between the pinion on the motor axis and the pinion on the potentiometer axis is too large . the safest is 1:1 some use 1:2 , how many teeth you have on the motor axis and how many on the potentiometer axis ,?
  2. titofe
    titofe Member
    640Coins
    2DOF, Arduino, SimforceGT, Motion platform
    hello received potentiometer teeth it is 20 teeth. The motor's street teeth are about 50 teeth. normally it is liquid which is made expressly for the 2dof simukit.thank you
  3. titofe
    titofe Member
    640Coins
    hello friends after changing the card with motor 1 I started motor 2 and it does this to me it gets too hot and the card gets too hot what could it be thank you
  4. titofe
    titofe Member
    640Coins
    151,991Coins
    +11,061 / 56 / -2
  6. titofe
    titofe Member
    640Coins
    yes you are right an error on my part I will correct that and I will come to you thank you very much well done
  7. titofe
    titofe Member
    640Coins
  8. titofe
    titofe Member
    640Coins
    hello I only have one motor connected the second is disconnected only one iBT 2 card thank you.
    151,991Coins
    +11,061 / 56 / -2
  10. titofe
    titofe Member
    640Coins
    hello yes the first engine was already adjusted it was the second when I wanted to adjust which screwed everything up I don't understand. I want to erase my PC so there are too many files that come together sometimes it stops when I make settings. besides I just got the sabarthoo 2×32. We'll see what happens, I'll keep you posted. Thank you
  11. titofe
    titofe Member
    640Coins
    hello friends after changing the two iBT 2 cards for a 2×32 sebartooth card, I followed the connections the settings I found a problem, can you help me please I will post a video thank you guys.
  12. titofe
    titofe Member
    640Coins
  13. noorbeast
    151,991Coins
    +11,061 / 56 / -2
    What happens when you increase Fpid, and set Step to 100, as per the instructions?
    Can you also please confirm the required DEscribe settings have been done.
  14. titofe
    titofe Member
    640Coins
    It doesn't matter fpid so when I turn on the engine it starts to run straight away it's not normal. describe it it was correctly the card was detected correctly. thank you
    151,991Coins
    +11,061 / 56 / -2
    Sounds like you have hardware and/or wiring issues.
  16. titofe
    titofe Member
    640Coins
    Hello. I used the first wiring. for you I should use which of the two thank you
