  1. JaniK
    JaniK New Member
    Truck driver
    Finland
    69Coins
    This is pretty nice feature, I am just redoing my wiring from the fast jumper cables /temp test (allmost 1year temporary :rolleyes:) to actual wiring harness now that I have finally added a traction loss system.
    I think I will add the pot or maybe a 2-position toggle switch with a smaller, like a 4,7k resistor to have reduced motion mode.
  2. Ronan Design
    Toronto, Canada
    1,716Coins
    My motors are overheating, and I can feel them "buzzing" constantly even when the rig is sitting idle. They are quiet though, but still "buzzing".
    Any advice on how to calm the motors down when they are sitting at the proper position? Is my Kp too large? Or should I lower the PWMmax? I'm trying to use all the power I can get from the motors. I could also increase the deadzone, but it's already at 3, so maybe that's not a good idea...
    All advice welcome!
    My settings are like this:
    The motors are Yalu wheelchair motors 24V 250W 75RPM, 6 of them are running from 2 x 750W PSUs, 3 Arduinos, 6 x Cytron 13A DC Motor Drivers.
    154,526Coins
    +11,185 / 57 / -2
    First, I would suggest design Vs physics as the initial area of review. So, reduce the CTC on levers and please report the outcome.
    Your posted SMC3 setting would be more informative running the Sine test, particularly loaded.
  4. Ronan Design
    Toronto, Canada
    1,716Coins
    Reducing CTC will reduce the load on the motors, but the load is not a problem. The motors are heating up from the micro-"buzzing", even when the rig is empty and not moving. It's the constant tiny movements that are not even visible or audible that heat them up. Logically, when the motor should not be moving but just maintaining the position, a steady voltage should be applied (in the form of PWM obviously), instead of the constant micro-movements. So this is the source of the problem. Of course increasing the load exacerbates the problem and the motors heat up more, but if the "static" heat-up is reduced, the load won't be a problem. First thing I'm thinking of doing is reducing Fpwm from 25kHz to 20kHz, which is more common. I just say 25kHz on a similar rig, but most use 20, so maybe that would mean less pulses I guess (still more than enough for precision). Maybe that will help together with some other adjustments that I'm trying to figure out. There has to be a way - maybe reduce PWMmax and increase Kp instead, or something. I'm sure people did that already and know the relationship between the settings and the "buzzing". I wish I wouldn't have to guess.
    I should get the basic settings right, then if it's not enough, I could reduce the CTC distance too.
  5. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,344Coins
    From what I read online about your Cytron 13A DC Motor Drivers, 20KHz is the max that you should use for the PWM frequency.
  6. prophet.id
    prophet.id BOSeTAMPER's Rotary Servo 6dof Build
    316Coins
    Fellow builders... question how you get this 'chattering' gone or at least reduce as much. I assume this isn't good.
    The motion feels very solid already. It's just this chattering; I assume this is the positioning hunting.
    I am using this 100A High Power H-bridge dual channel DC Motor Drive.
    I am using this sensor AS5600 Magnetic Encoder 12bit for position feedback.
    Here is the video with sounds, hear the 'rrrr....rrrr....rrr...' and see the LED direction indicator keep jumping between Left and Right.
    https://www.youtube.com/shorts/WNmPN5LT3xU
    This is my SMC3Utils setting:
    Just FYI, I have 50% scaller (set the scale pot to 120'clk position) if you see the plot 'Target' line (green color).
  7. Gadget999
    12,331Coins
    Swap the encoder for a hall effect potentiometer, see if the problem improves
  8. Gadget999
    12,331Coins
    Reduce p and also see what happens
  9. prophet.id
    316Coins
    I suppose you mean Kp? I tried reduce down to 400, start to see a slightly less responsive. But the chatter remain the same. The only setting value that really effect is a combination of Kp = 500 and Deadzone = 10.
    But I heard Deadzone more than 2 is bad, is this true?
    Btw, the AS5600 I use is a half effect.
  10. Gadget999
    12,331Coins
    I would set the deadzone to zero whilst you are trying to sort this
    the AS5600 may not have a clean outout
  11. prophet.id
    316Coins
    I set the deadzone to 0 now, also tried using "Rotatable Hall Sensor, 0.088°0-360 Degrees Rotatable Hall Angle Sensor 0-5V Output Full Circle 12Bit DC 5V Supply Voltage DC 0-5V Output Voltage"
    https://amzn.to/4jGBeBY
    And giving me exactly the same 'rrr..r..r.....rr...' hunting issue. I wonder if this is caused by the Harmonic gear I am using, which does not have backlash or slack between the motor and the output shaft of the gear head where "potentiometer" attaches.
    What sensor are you using? and do you have no 'rrr.r..r..r...' issue?
  12. Gadget999
    12,331Coins
    is there movement at all when you hear the rrrr rrr rrrr
  13. prophet.id
    316Coins
    I can definitely feel vibration on the motor rear-shaft. I assume the position feedback system is hunting, the PWM and direction is working on a very small angular distance.
  14. Gadget999
    12,331Coins
    can you attach the encoder to the motor shaft - not the output shaft
  15. prophet.id
    316Coins
    I can but it should not work as the motor moves too fast.
  16. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,338Coins
    Me thinks you should start a thread in Q&A, and show specifically in pictures or drawings what you want to assemble, at the moment you are cluttering up the thread through which it is hard to dig anyway.
    To be clear with a typical arduino smc3 batch, such as is available on the forum you will not use a rotary potentiometer.
    Arduino only measures voltage in the range of 0-5V and that's it, there is nothing in the code to count RPM and you don't really need it with a Hall sensor it is super accurate.
  17. Josh Latka
    Josh Latka New Member
    102Coins
    This is a result of a noisy signal and/or smc reading the pot signal to precisely
    Adruino ide has an example sketch that allows you to print the pot data to monitor which shows how accurately the adruino is reading your pots signal. Load this sketch and watch the values fluctuate when the pot is in a stationary Poland you will see the signal will fluctuate between 1-4 binary numbers reporting the pot location. The noise you hear is the motor changing directions rapidly in very small increments from this fluctuations
    Adding a small capacitor (I used a 10uf) connected to the pots signal line and ground will filter out the noise. But this does not completely remove all fluctuations and will still see the pot print sketch show the signal report positions that will vary from e.x 512.5 to 513 not staying on a steady number indication the system is rapidly adjusting the sensor location.
    To fix this a software potentiometer filter is needed to be implemented into the code.
    Example can be used from this website to explain
    https://www.electroniclinic.com/arduino-analog-signal-filter-analog-sensor-value-fluctuates-a-lot/
    I used the more simple of the 2 codes since it was more simple and produced better results.
    After adding the capacitor and filter code my motors no longer sound like bacon sizzling with small jitters
    Honestly the code should be updated properly with this code implemented by someone who knows what they are doing.
    I managed to get it to work but I had to spend some time figuring out how to put it in and not sure if I put it in the best spot as it is a ‘inst’ command
  18. prophet.id
    316Coins
    This is very interesting. Would you be willing to share the update code, please?
  19. Josh Latka
    102Coins
    it wont allow me to upload the file. this is how the code looks with the modification
    open your code editor and find the lines for deadzone1 and paste in between to look like this
    const int FeedbackPin3 = A2; // Motor 3 feedback pin
    const int PotInputPin = A5; // User adjustable POT used to scale the motion (if enabled)
    //Pot Filter added by J Latka
    int PotData = 0;
    int filteredValue = 0; // Initialize filtered value
    float alpha = 0.05; // Filter coefficient (0 < alpha < 1)
    int DeadZone1 = 0; // feedback deadzone
    int DeadZone2 = 0; // feedback deadzone
    int DeadZone3 = 0; // feedback deadzone
    the lines that are between //Pot Filter added by J Latka are the code values
    i am no code expert and would like to see some one who actually knows what they are doing implement this filter into the code properly
    And to correct my self I used a 10nF cap
    Must mention the cap made huge difference but needed some help,of the filter
    The url link I posted explains the best
  20. prophet.id
    316Coins
    Awesome. But I believe you missed a few line of code, for the 'Feedback1' and 'Feedback2'
    Perhaps, you can copy paste the whole code instead?
