value1
Joystick plugin 2.0.0.1
SimTools plugin to read the joystick values
  1. Kaneda
    Kaneda New Member
    84Coins
    Hello !!!
    When we active joystick plugin and we have actuators moove , its possible to same for game dash ? For a wind box ?
    If i accelerate wind start and stop when i stop accelerate
    152,700Coins
    +11,092 / 56 / -2
    The joystick plugin does not currently support simulated wind, perhaps it is something @yobuddy can ponder at some point in the future.
  3. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Hello. I can't get it to work... I'm trying to capture joystick movements with "PROJECT WINGMAN" Any suggestions? thank you!
    152,700Coins
    +11,092 / 56 / -2
    The plugin does not rely on game telemetry, so the game is irrelevant to the issue.
    What would be helpful is context, to know what you have or have not done with respect to setting it up, for example have you completed all of the required setup steps and what hardware are you using it with: https://www.xsimulator.net/community/threads/joystick-plugin.6160/#post-77570
  5. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Hello. Yes, I follow all the steps ... but it is not clear to me which Joystick select, I get 3 with data and then a number of up to 15 units without any name. In the Tunning center values appear but static, the numbers do not move ... I use Simtools for my 2 DOF simulator and without problem, with tubuino and IBT2. And I know there is no specific plugin for the flight game, I just want to capture the movements of the Joystick and transfer them to the engines. Thanks for your help!
  6. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Okay. I have already succeeded! Now what I would like is to apply a force when I press a button. (I want to launch the missile and make an idiot) Maybe from "extra"?
  7. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Okay! Everything works for me now! And even what I wanted to do was throw the cockpit back when I launched a missile! it's luxury! Thank you!
  8. arp148
    arp148 New Member
    22Coins
    Hello, does the plugin work with simtool v3 and how can I get this file?
    152,700Coins
    +11,092 / 56 / -2
    SimTools v2 plugins are not compatible with SimTools v3, but you can install v2 and v3 on the same computer and use the same license key.
    Access to SimTools v2 plugins are covered in the FAQs, please see here: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    The SimTools v3 plugins are being expanded but don't yet cover everything just yet, this is what currently is available: https://simtools.us/plugin_library/
  10. Pastiijay
    Pastiijay New Member Gold Contributor
    - 375Coins
    Yes, you need to go to Plugin Manager>Repo:>Community Repositories SimTools>Console>Joystick
