AMC-AASD15A servo controller
Discussion in 'SimTools compatible interfaces' started by Thanos, Nov 6, 2019.
  1. Thanos
    Electronics Engineer
    2,925Coins
    PA: Don't drink and drive!!! Unless you just finished building your sim rig and celebrating!!!
  2. Thinqer77
    Thinqer77 New Member
    39Coins
  3. Thinqer77
    39Coins
  4. Thinqer77
    39Coins
  5. Sleepy
    Sleepy New Member
    16Coins
    I just updated my AMC AASD15a to the latest firmware (fix8), as i was interested in the pullback adjustments and the ability to turn off the motors/power when in the park position. I have a 3DOF eRacing-Labs with 4 x 150mm actuators (RS Mega+) with 4 AASD15A servo drivers (80ST-M02430). For software I use SRS on Win11.
    1. I don't understand the pullback options I think. My understanding is that it can finetune the bottom position of the rig, so that the motors are not constantly applying torque to hold the rig a few mm above absolute bottom, or pressing down against the hardstop. I have understood that dn002 on the servo drivers will show the applied live torque of each motor. So, based on the video I saw of this feature from @Thanos, I set all axis to 75mm pullback, as it looked like he had the same actuators in his video.
    That produced these torque numbers:
    FL 17, FR 18, RL -10, RR -4.
    Ok, not bad i guess, but I could hear the motors engaging constantly so changed values to see if that helped. Adjusted all axis individually (did not us the copy to all axis function as I saw a post in the GitHub claiming that function did not sett the pullback for all axis properly, so sticking to setting each axis.) to 100 and got the following numbers:
    FL 13, FR 17, RL, -7, RR, -3.
    The i tried 200 as that was the default prior this feature being adjustable, and that produced these numbers:
    FL9, FR 17, RL, -7, RR -3.
    I found these numbers changing with the settings, but not in a consistent manner I was expecting. Also, the rig does not seem to alter the park position relative to the bottom hardstop no matter shat setting I use for pullback. It always seams to have the front a few mm above the hardstop like it always has had (one of the main reasons I wanted to adjust this was to get rid of the front falling a few mm when i cut power.)
    Am I missing something here? Can somebody explain the pullback feature better? For example, increasing the pullback number should "lift" the rig, correct? And increase torque (or lessen a negative torque number)? But I increased from 75->100->200 and got decreasing positive numbers for the FR and FL actuators...
    2. Turning of power in park position. I tired this, and it does cut power, but something weird happens afterwards. If the rig has been in the parking position for more than the defined timeout minutes (tried both 10 and 2 min), it does cut power. But when I then actuated the rig again, either via the buttons on the AMC or entering a game or test in SRS, it lifts to the STBY position (50%). But when it then goes to the parking position again it does not seem to stop, the actuators continue to try and drive the rig down against the hardstops! The first time it happened I could hear the actuators creaking and cracking, and my heart almost stopped! But luckily, it was probably just parts settling against the pressures, as the next time it happened there was significantly less noise. Both times all the servo drivers gave the AL-06 code, which I have not been able to find, but assume is a safety feature to prevent damage, or similar.
    Is almost looks like the AMC does not know the actuator position after a power down using this new feature, and somehow thinks that the park position is much lower than it is.
    For now I have turned off this feature, but hoping for a solution, as turning of the power and getting rid of some of the motor noise when the rig is in the park position would be nice...
  6. Alexandre Martel
    Alexandre Martel New Member
    10Coins
    Hi Folks!
    I'm having an issue with the AMC-AASD15 I've just setup on my 6dof rig. I'm pretty sure I've nailed everything except for calibration, which is totally out of whack and I think I know why, maybe you guys could help me out. I'm assuming that the controller expects to find the inductive switches at the bottom end of the rig, when it's at its minimum travel. However mine is the opposite! I've based my design on @knaufinator's.
    That being said there are all sorts of issues pertaining to my switches location. I've made my way around by reversing motors direction within the software, however the AMC still operates in reverse from the switches position. This messes up my calibration and haven't been able to match the position and range with that of FlyPT.
    On another hand, when it calibrates upon initialization, the swing arms are all going in the opposite directions so they make a full turn going down, then up to the switches, almost 270deg. I hope you guys understand...
    Is there any way to instruct the AMC about the switches being up top? Biggest issue right now is that I'm not even close to match the ranges from software to hardware.
    Best regards!
    Alex
  7. Thanos
    2,925Coins
    Been busy, so just a quick video for now.. must have a break for fun right?
  8. Thanos
    2,925Coins
    No need to use limit switches etc. just create a hard stop to the bottom side of the travel:
    https://youtube.com/shorts/T-_AlPX6hz8?si=q4vq8rnNs9hX2Ud8
  9. Thanos
    2,925Coins
    Just a quick update on my rig:
  10. Menix
    Menix Member Gold Contributor
    104Coins
  11. Menix
    104Coins
    Heres the Manual with Wiring
    dont know if this driver is compatible with AMC Controller
    • t3d.pdf
      1.2 MB
      295
  12. Thanos
    2,925Coins
    I'm sorry, but you have to return the servo drives you bought. Obviously they are NOT AASD-15A. All AASD servo drives have same 25 pin for the interface with the Thanos controllers... please buy from reputable sources next time.
  13. Thanos
    2,925Coins
    Took a while, but I finished adding Surge stage on my rig:
  14. Thanos
    2,925Coins
  15. saiRyu
    saiRyu Member
    japan
    271Coins
    2DOF, SCN6
    Hello. I was enjoying the simulator with simtools3 and Thanos. I changed my computer and now the simulator doesn't work with simtools. The simulator works with simhub. I have uninstalled SIMtools3 several times but it still didn't work.I have uninstalled SIMtools3 several times but it still didn't work.The OS is Windows 11 24h2, the CPU is u7 265k and the motherboard is Intel Z 890.
  16. saiRyu
    saiRyu Member
    japan
    271Coins
    2DOF, SCN6
    Photos.
  17. Thanos
    2,925Coins
    Probably missing FTDI driver?
    Does it move using the manual motion test tool?
    https://github.com/tronicgr/AMC-AAS...ster/Thanos-utility/Thanos-motion-test-simple
  18. carbonius
    carbonius New Member
    40Coins
    I acquired a previously unassembled Sector X Simulations 6DOF system which uses PT Actuators and
    AMC-AASD15A servo controllers. However, there are limited setup instructions and the owner of Sector X stopped communicating. So, I'm wondering if there is someone in the Los Angeles area I can pay to help complete the the buildout.
  19. saiRyu
    saiRyu Member
    japan
    271Coins
    2DOF, SCN6
  20. RaaR
    RaaR New Member
    - 17Coins
    Hi Thanos,
    I was looking through this thread and you mentioned the AMC controller works on some other servo drives. Unfortunately with the tariff stuff going on the AASD15a ones are pretty expensive right now. I did find a motor with a similar spec to the 80ST-M02430's, but the driver is a S2-SVD15A.
    It looks like the pins match up with the diagrams you have for the other drives compatibility. It also has similar functions. Is the compatibility between drivers pretty straight forward and just setting the correct parameters on the drives, or would i be going down a rough road? The difference from my estimating on shipping/tariffs is ~$1200. I was able to get the manual and pinout for the S2-SVD15a if you're curious.
    I did have another question about the diagrams on github showing compatibility between other drives. You have pin9 showing DC5V. The AASD15a manual has it listed as DC12-24V, same as this S2-SVD15A. Is it supposed to be DC5V or does it not matter?
    Thank you
