AASD15 Alternative - Thanos
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by azm, Aug 30, 2024.
  1. Aerosmith
    Aerosmith Active Member
    self employed
    2,881Coins
    3DOF, AC motor
    If you need ABZ encoder output check Lichuan drives. Slightly more expensive than the P100S but offers all the bells and whistles.
  2. Joe Cortexian
    1,537Coins
    Now that I have been introduced to a new concept it’s all good. Reviewed the capabilities of a Teensy and it seems it has all the capabilities required to do four axis if not six using the pulse system.
    Although I have ABZ linear encoder on my drill table I am not sold on the idea because it is such a CPU hog.
    Thanks for your help I am set to go.
  3. silver66fb
    silver66fb New Member
    24Coins
    I'm building a 3DOF system with these now.
  4. Joe Cortexian
    1,537Coins
    So I bought one of these:
    https://www.aliexpress.com/item/1005004837245384.html
    mostly because it has a “manual”. It also has accessible quadrature encoder outputs which I think will be useful for debugging/verifying software.
    This product features 5V differential inputs for pulse and direction. Do you provide a true differential signal, or is it simulated using standard 5V TTL?
    EDIT: I can get this to work just using 5V and GND for the differential inputs.
