AMC-AASD15A servo controller
Discussion in 'SimTools compatible interfaces' started by Thanos, Nov 6, 2019.
  1. Thanos
    Electronics Engineer
    2,862Coins
    I'm not sure about the the DC input of this drive, but should be similar optocouplers like the AASD15A and thus probably will work fine with 5v.
    From what I gather this is using similar circuit for the drive part, but it needs external Brake resistor and possibly won't be able to set it to run on 110v if you need to. Also heard the power wiring is somewhat complicated as well, might have to search for instructions on how others did wire it.
    Thanos
