FlyPT Mover 3.5.3
  1. Map63Vette
    Map63Vette Active Member
    Mechanical Engineer
    Lawrence, KS
    709Coins
    I believe the COR is just that, the center of rotation. So it is the point about which the software is going to try to pivot the seat. It doesn't directly have anything to do with how the rig is built as much as how FlyPT runs the math to get movements. One good example of how it can be used is traction loss. If you leave the COR at the center of your rig, when the car starts spinning it would give you a pure yaw motion. Depending on the vehicle you're in, that might not be the most accurate feeling. The car is going to want to rotate around the front axle, so if you set the COR in front of you, that same spinning yaw input would give you an output that is a blend of sway and yaw. Nothing about your rig would have to change (though you might get a lot less range of motion depending on where the COR is because you'll get more blended motion out of rotations).
  2. Erik Green
    Erik Green Member
    409Coins
    This software is a dream. Only glitch I've had in 3 days is on loss of serial connection. Something with steam opening a ad window perhaps.
  3. Erik Green
    Erik Green Member
    409Coins
    And! OXRMC was a piece of cake to get running. I'm sim racing so not completely necessary but wanted to experiment. Overall the motion cues feel much better with it on. I'm running in high precision and 2ms intervals. There is perceptible lag in the compensation which give a motion sickness type sensation. Is there a way to sacrifice compensation quality for decreased lag?
  4. wingert
    wingert Active Member
    732Coins
    4DOF
    have a question about the rig module, what is the difference between gain and scale ?
    thanks !
  5. wingert
    732Coins
    4DOF
    I think i got it, scale affects the park position it seems to be like a offset.
    How works the auto gain ?
  6. Chipless
    Chipless Member
    146Coins
    Hey all, I'm in desperate need of some help.
    I noticed that my wind sim wasn't working for one of my titles (AMS2), so I tried deleting the module, and duplicating one that was working. However, when I tried to save everything as a local file, I received an error about hexadecimal X0.01 being an invalid character (I didn't save the exact error message). I've never seen that error message before, and I didn't change anything other than deleting a module. Anyway, I tried to continue, and got no further error messages, however now when I try to open the local file, I get a new error message (see photo) and if I continue, FlyPT just opens up a blank screen.
    I really hope I didn't just lose everything in my setup file! Please help!
  7. Chipless
    Chipless Member
    146Coins
    Here is the full error text underneath when I click details:
    System.Xml.XmlException: Unexpected end of file has occurred. The following elements are not closed: ddlValue, CONTROLS, DIRECT, FLYPT_MOVER. Line 513, position 17.
    at System.Xml.XmlTextReaderImpl.Throw(Exception e)
    at System.Xml.XmlTextReaderImpl.ThrowUnclosedElements()
    at System.Xml.XmlTextReaderImpl.ParseElementContent()
    at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r)
    at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r, LoadOptions o)
    at System.Xml.Linq.XDocument.Load(XmlReader reader, LoadOptions options)
    at System.Xml.Linq.XDocument.Load(String uri, LoadOptions options)
    at Mover.Setups.OpenMergeModules.OpenFile_Load(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at Mover.BaseForm.WndProc(Message& m)
  8. Chipless
    Chipless Member
    146Coins
    @pmvcda Please see above two posts for a critical error with FlyPT Mover that is preventing me from accessing my one and only saved Mover file :( Any help you can spare would be so greatly appreciated. It has been so long since I setup my rig, that I don't think I could do it properly from scratch again, so I am really hoping that I won't need to!
  9. ziasd
    ziasd New Member Gold Contributor
    vitoria
    - 390Coins
    3DOF, Arduino, 6DOF
    it won't open for me, it gets stuck
  10. Chipless
    Chipless Member
    146Coins
    Sorry to bombard this thread. Problem solved. I will update soon with the details.
  11. nzteddy2020
    nzteddy2020 New Member
    Retired software developer
    New Zealand
    22Coins
    Hi All
    Been using Mover 353 for a long time. For some unknown reason it will no longer open. It hangs before the main window is rendered properly.
    It has to be something that I changed or installed on my PC, but despite many days of investigation I cannot pinpoint it.
    3.7 runs Ok. I started to configure my rig with that but got stumped pretty quickly, so I am back to troubleshooting 353.
    Attached is a screenshot of the 353 window hanging without fully rendering.
    Also attached is the dot net versions installed, since I'm thinking this might be something todo with it.
    Any suggestions on how to troubleshoot much appreciated. Nothing in Event Viewer. Mover doesn't seem to have logging afaics.
  12. acans
    acans New Member
    16Coins
    Arduino, 4DOF, 6DOF
    My flypt 3.53 also doesn't work after win11 upgrade, the same as the feedback in the above post
  13. nzteddy2020
    New Zealand
    22Coins
    A subsequent Win11 update caused my FlyPT 353 to start working again. However in the meantime I had switched to Simhub Motion, and very happy that I did.
  14. wingert
    732Coins
    4DOF
    it would be a good idea to make system image from time to time.
  15. truyentu
    truyentu New Member
    26Coins
    3DOF, Arduino
    Hello everyone,
    Could anyone provide detailed documentation on Flypt? I'm trying to write Arduino code to receive output data from Flypt, but I don't fully understand how Flypt's output data works, so I'm still encountering errors. I need to understand Flypt's output to correctly parse it for Arduino. I've searched everywhere but haven't found any specific documentation.
  16. noorbeast
    153,728Coins
    The documentation link is in the FAQs: https://www.xsimulator.net/community/faq/flypt-mover-page-and-setup.382/
    And the Flypt documentation and output examples, including Arduino, are available online: https://www.flyptmover.com/outputs
  17. wingert
    732Coins
    4DOF
    you can also connect a second device with a twisted cable on your com port, to see what happens. (e.g. linux with cutecom) p1.jpg p3.jpg
  18. tadeusz
    tadeusz New Member
    34Coins
    I'm a fan of the FlyPt program.
    I have a stupid question.
    Can we use the amazing FlyPt to build an FFB joystick?
    Is it possible for an input parameter like Speed to cause the force on the motor to increase, not the position?
    Best regards,
    Tadek
  19. wingert
    732Coins
    4DOF
    normally it`s an position system, but if you a construction that converts a position to a force e.g. a lever arm or pneumatic tube filling a cushion, yes. Furthermore that offers a correct physical behavior mapping a acceleration value, as force is proportional to a. (F=m*a)
  20. Aerosmith
    Aerosmith Active Member
    self employed
    2,881Coins
    3DOF, AC motor
    FlyPtMover could do anything that you tell it with the calculation formulas. So you could theoretically use any variable that is available from the game/simulation software, do filtering and calculations with it and output the results to your hardware. If this is force or position depends on the hardware.
    So what you need is some sort of current mode amplifier because current is proportional to force or torque at the motor. Current control is quite difficult to implement with the commonly used Arduino and PWM power stage combinations (IBT2 and similar) because there is no way of measuring the current.
    However, as I already mentioned somwhere else in the forum, you could use an industrial servo driver. Nearly all of them have a torque control mode. Or if you'd like to build it DIY, there are stepper motor driver ICs that can control the motor current proportional to a voltage input.
