SimTools v3 Public Beta
  1. yobuddy
    51,225Coins
    PC and Console Plugin posted to the repo :thumbs
  2. Pietbrok85
    Pietbrok85 New Member
    Venlo
    35Coins
    Thanks a lot Yobuddy! I think i keep the centre of gravity in the centre, sitting a little behind the centre but the feet rest (peddals) are compensating for it. I have added a photo now. Kind regards, Piet (Netherlands) vooraanzicht met race stoel leuning.JPG
  3. lysa elec
    lysa elec LYSA ELEC
    - 26Coins
    I whan to use SimTool V3. I'm using the XPID_sabertooth2x32 code with the current version, V2.2
    . Is there a guide to entering the parameters in V3 for the code to adjust the 3 axes ?
  4. yobuddy
    51,225Coins
    I'm not quite sure what your asking buddy. Do you have a pic of your v2 settings?
    I'm sure I can help get you going in v3 if that's what your asking?
  5. Joe Cortexian
    1,339Coins
    Thanks. The F1 25 plugin shows up in the plugin manager. Once I saw that I bought the game. Note that google search for xsimulator: F1 25 should find this post now.
  6. ucreate
    ucreate New Member
    28Coins
    4DOF, 6DOF
    It was working fine before. I installed a custom game plug-in and restarted simtools3 as prompted. Then it could not be started again.
    I went to the gameplugin directory and deleted the plug-in I just installed. I still cannot start the program. What should I do?
    In addition, if I reinstall the simtools3 program, will the license still exist?
    152,615Coins
    +11,087 / 56 / -2
    There are a limited number of re-installs possible.
    Notwithstanding, what was the plugin that created the issue?
  8. ucreate
    ucreate New Member
    28Coins
    4DOF, 6DOF
    I made a game plug-in for a drone. During the analysis process, even if the plug-in is installed, it is not started, which will not affect the startup and operation of the simtools program. What should I do now? I look forward to your suggestions!
  9. DZSchneider
    DZSchneider New Member
    Toronto
    64Coins
    Any chance of a Simtools V3 plugin for BMS? With 4.38 now out, seems like a great time for it.
  10. Joe Cortexian
    1,339Coins
    Is there any way in SimTools to configure it to send every time you get a telemetry packet from the game? I currently have to estimate telemetry rate and remove repeated points in order to do feed forward velocity and acceleration. In theory this makes things much smoother specifically for flight simulation.
    It’s not easy to find telemetry frequency information for many games like MSFS. The games I have found are sometimes 66.66ms or 33.33ms. Is the telemetry rate displayed somewhere and I am not seeing it?
  11. yobuddy
    51,225Coins
    The telemetry rate is different from game to game. Some games can even have different telemetry rate options too. I'm not too sure what "feed forward velocity and acceleration" is thou? But sending an interface the position its already targeted for, causes the interface to essentially ignores the input. The lower right intensity slider in v3's GUI should give you the smoothing your looking for thou?
    Take care!
  12. yobuddy
    51,225Coins
    I will take a look next week.
  13. Caleb Chamberlain
    Caleb Chamberlain New Member
    28Coins
    Hey all, I was asked by a moderator to post here instead of in a different thread on the subject. I'm unsure of a good way to search all 114 pages of history, but I'm adding here in case it's helpful. :)
    I was having a hard time getting MSFS 2025 telemetry working in SimTools V3. I tinkered for literally hours, but it wasn't showing up. I have it working now. A couple things changed:
    1) I rebooted my machine
    2) I switched the Motion Settings to use "Generic 2D Standard" instead of "Generic 3D Rotating"
    I don't know if either or neither of those things fixed telemetry for the game, but figured I'd report here in case it helps anyone. Cheers!
  14. yobuddy
    51,225Coins
    It would have to be because you rebooted, as changing the axis plugin would not make any difference. Also, know that the Generic 3D Rotating axis plugin is for a stewart type simulator.
    Glad you got it working buddy!
  15. FLORIN ROMANIA
    FLORIN ROMANIA Member
    România
    810Coins
    Hello, I purchased vibe and set it up according to the examples, I attached an amplifier and a subwoofer (just for testing), but I can't get it to work properly, I'm also attaching screenshots, pls help,Where am I wrong?
  16. yobuddy
    51,225Coins
    Hi @FLORIN ROMANIA,
    The chassis vibe was created for 3d (4 speaker) feedback. So it could be that since you have it only playing on the front speakers could be the cause (Should the speaker you have setup be considered a back one). But most likely it's that the max/min values are to high. Maybe give a Max/Min of 30/-30 a try. Did you tested the output settings in the Vibration Editor section? (The Test Settings button)
    I would suggest starting with a easier vibe to setup thou, like RPM. For RPM, set min value of 300 or so, and a high value of 8000 or so. And then test the output settings in the Vibration Editor section and see if it works well while moving the slider back and forth.
    Chat soon!
  17. FLORIN ROMANIA
    România
    810Coins
    Ok I also tried the rpm with the given values, I hear a continuous sound, not the rpm sound at all, the sound only changes when I turn the steering wheel
  18. FLORIN ROMANIA
    România
    810Coins
  19. FLORIN ROMANIA
    România
    810Coins
  20. yobuddy
    51,225Coins
    Are you using a second sound card, not that same one used for the game audio?
    (As I have no idea how a steering wheel could override the rpm output from a game is all)
    Just a tip, you will probably find that the sin or saw wave will give a better rpm vibration.
    Anyway, please turn the volume for chassis off so we can isolate just RPM, and get it working before moving on to another vibe.
    I will take a look at this plugin on Monday, and make sure the data coming in for vibe is correct. As it looks like the rpm incoming number is way to high.
