Showroom BOSeTAMPER 's Compact Steward Rotary Servo 6DOF SMC3 base for Go Kart (Complete)
Discussion in 'DIY Motion Simulator Projects' started by prophet.id, Mar 19, 2025.
  1. Misanthrop
    Misanthrop Active Member
    1,012Coins
    I never wanted to build an 6DOF, till now :eek:
  2. prophet.id
    prophet.id BOSeTAMPER's Rotary Servo 6dof Build
    343Coins
    I had built 2-dof rigs (different configuration)... and went to this 6-dof which has traction lost and sway motion... it just awesome!
  3. Misanthrop
    1,012Coins
    Have already an 3DOF with Surge and 2xTL
    But also i have an complete Fanatec SetUp laying around without any use and a second Gaming PC, i will have a look on your files and will think about the costs :)
    I saw that you safed it as sldprt, i think it would be easier for everyone else when you safe it as step, 3mf or something, so every programm will accept it.
  4. afrobbizz
    afrobbizz Member
    110Coins
    3DOF, 6DOF
    Very impressive ! One of the best 6 dof I’ve ever seen! Only one question: checking your axis assignment I just want to understand if exemple you want more pitch, you just decrease the % of other axis and increase that one? How you calculate the total % ? It should not be less or equal to 100%? Thanks
  5. prophet.id
    343Coins
    Thank you!
    Yes you are correct, just increase the % number up to 100% max. You just adjust it to your liking. No specific reasoning, but more your own preference.
    Btw, I end up more focused on the 'Sensitivity', which gives me the most simulation feeling.
  6. afrobbizz
    afrobbizz Member
    110Coins
    3DOF, 6DOF
    Perfect! But 100% per axis or the sum of total axis? I see your configuration total axis is more than 100%. Thanks
  7. prophet.id
    343Coins
    Per axis.
  8. afrobbizz
    afrobbizz Member
    110Coins
    3DOF, 6DOF
    thanks
  9. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    Hi @prophet.id a question about your harmonic drives .Are they plug and play or did you need to grease them?
    Regards Ad
  10. nagy herkules
    nagy herkules New Member
    - 4Coins
    Hello can you tell me how to setup the as5600?
    I2c communication or analog 5v?
  11. sam poole
    sam poole Active Member
    midlands
    32Coins
    Hi I thing your surge axis needs to be reversed as the surge looks like it's going backwards when you accelerate
    Also worth checking sway (same direction steering) as I made the same mistake when first tuning mine
    I might be wrong it's hard to tell but just thought I'd mention it nice rig though
  12. prophet.id
    343Coins
    I use the analog 5v.
  13. prophet.id
    343Coins
    I believe you are correct. I have been playing with the tuning, and the current video is mostly out of date.
  14. Geoff M
    Geoff M New Member
    Australia
    23Coins
    Hi. Firstly awesome build! The CNC parts really set it off.
    I got pointed in the direction of your build as I am currently building a 6DoF rig with similar configuration (3X Arduino Uno's, 6X AS5600's and the same motor drivers.
    I was wondering if you have a wiring diagram of your setup as I am trying to bench test 1 channel and am not getting very far. I have got the sketch into the Uno, but am not sure I have wired it up correctly. I have done the AS5600 R1 and R2 removal. A wiring diagram would just make sure I'm not going to let the magic smoke out.
    Cheers!
  15. Dr_B
    Dr_B New Member
    Mechanical engineer
    69Coins
    So very generous of you to share this and a great work! I built a 2DOF system and a pretty accurate F/A18C cockpit for DCS and I love it. This is going to be my next build. I already ordered some parts. Would you mind sharing the details of your interface setup in Simtools for 6 axes (mine is posted below) and how you handled SMC3 with 3 different arduinos? Thanks again
  16. prophet.id
    343Coins
    Hello!
    I follow this thread. https://www.xsimulator.net/communit...driver-and-windows-utilities.4957/#post-48121
    And make sure you follow the MODE 1.
    As in the AS5600, see it as a regular analog rotary potensiometer.
    Good luck.
  17. prophet.id
    343Coins
    Hi Dr_B,
    I just add the setup on the post. Please check them on the first page of this thread. Hope this help!
  18. Dr_B
    Dr_B New Member
    Mechanical engineer
    69Coins
    Started the project. I’m using heavy duty jazzy wheel chair motors since those are infinitely less expensive:). I buy them from eBay for $40 each and they are good for 22N.m output torque at 24V supply. I believe their gear ratio is about 1/36x. One question on the AS5600 encoders, I used 180deg hall effect rotary pot type sensors before but now they are impossible to find. So I will use these little cheap magnetic encoders on this build. But these guys output 0-360deg sweep. Do you find that as an issue since you will never get to a full 0-5V sweep for a motion sim setup where your motor crank rotates at most 150deg or so?
  19. prophet.id
    343Coins
    I love AS5600 as a contactless solution (almost failure-less compared to a potentiometer).
    I believe you can scale up the voltage range to get 'full scale 0-5V sweep'.
    My rotational arm moves about less than 180 degrees, and I don't see any issue so far or lower performance.
    Also, check this YT:
  20. Gadget999
    12,353Coins
    you can adjust the value in the code to convert it from a 360 degree sensor to a 180 degree sensor
    a simple solution is to read the pot value and double it
