$450 Mige Direct Drive Wheel using MMOS and AASD
Discussion in 'DIY peripherals' started by Peacemaker105, May 6, 2020.
  1. Asmith96
    Asmith96 New Member
    20Coins
    I'd just like to thank @Peacemaker105 and @Thanos for your contributions to this project. I took the plunge and ordered a 90ST-M03520 (3.5 Nm, 10.5 Nm peak) along with an AASD-15A driver and a few extra bits to complete the project.
    I joined the forum to share an alternative to the 3d printed wheel hub since I don't own a 3d printer. I don't have permission to post the links since I'm new around here so I've attached the screenshots of the listings instead. It should be easy enough to find if anyone wants to give it a go.
    The coupling flange has a 16mm hole with a key and should fit the 90ST motors nicely. The 6 bolt holes are on a circle with a 45mm diameter which is half a millimetre off the grant mounting pattern (1.75" diameter). The adapter hub should just then fit onto the flange without too much hassle.
    An added bonus is that I think it will be possible to make a quick-release system with these 2 parts. I'm thinking I will thread the 6 bolt holes on the flange and use them to index the hub adapter and then secure the adapter to the flange/motor driveshaft with a central wing bolt into the driveshaft.
  2. Prezes
    Prezes New Member
    29Coins
    Hey,
    I wanna thank you for this topic, is it possible to update the prices of the all items along with the Thanos plate ?
    So much information has accumulated in that topic sa it is not known what is needed and what is not?
  3. Gary S
    Gary S New Member
    23Coins
    Hello, I have this setup, and having some issues with settings, MMOS DD system wheel base, which includes @Thanos TDD board, E stop, 130st-m10015motor(25NM), AASD 30A servo driver, jsut wondering if anyone can share their settings both in iracing and in the mmos software to assist me in getting this running smooth.
    Gary
  4. bartez81
    bartez81 i like amps
    Kraków
    - 2Coins
    2DOF, 3DOF, DC motor, AC motor, SCN6, Arduino, JRK, Motion platform
    Hello.
    Has anyone tried to run it on the A1-SVD15 driver?
  5. bartez81
    Kraków
    - 2Coins
    ok its working :)
  6. bartez81
    Kraków
    - 2Coins
    Hello
    A strange thing after folding the steering wheel works with FF but loses its position. Every now and then the position changes to the left. Calibration works for a while.
  7. Gadget999
    12,035Coins
    Did anyone change the encoder on thier wheel from 2500 ppr to higher ?
    Was there much improvement in fidelity ?
    What type of encoder did you fit ?
  8. bartez81
    Kraków
    - 2Coins
    standard 2500cpr 10000ppr its good for me for now
  9. The7Reaper
    The7Reaper New Member
    28Coins
    Are any of yall using these in 2025? I’m wondering if it’s worth it to build today?
  10. Gadget999
    12,035Coins
    Yes, or look at vnm simulation
  11. The7Reaper
    28Coins
    Thank you for your response. I think I may meed to work my way up first but I’m going to keep it on my project list. Are there any projects you would recommend first to gain knowledge?
  12. Headache
    Headache New Member
    22Coins
    AC motor
    Hey guys! I need some help. I assenmbled my AASD+110ST-M06030 with a VNM firmware on STM32F407G long time ago and it worked amazing for a while and had no problems at all. Recently I had to disassemble it, and when I got it back together I encountered a very wierd issue which I cant defend for a few weeks now:
    I get FFB on one side of the wheel`s zero line - all fine, spring force works, stering lock works, all that. But as soon as the wheel crosses its zero line - the FFB works, BUT doesnt get reversed and I get sping force not towards the zero line, but towards the lock. Also the lock doesnt work on "bad" side - as soon as the wheel hits the point where it should engage lock force, it just spins out indefinetly. So it seems like a force isnt being revered when its supposed to.
    I checked everything, and I mean EVERYTHING: I read the AASD manual, rang all the wires with multimeter (all good), reflashed firmware, checked driver settings (reset with FN004 and used settings from the tutorial), calibrated Pn190, etc. Checked voltage on PE8 on STM32 - it works as intended: voltage changes from 0 to 3v and vice versa when the wheel is crossing the zero line. No luck unfortunately. By all means it must work but it doesnt. I'm so desparate I even considered buying Moza R9 lol. Pls halp
    I consider myself a begginer so I may have made some stupid mistake, thats totally possible.
  13. Headache
    Headache New Member
    22Coins
    AC motor
    Also sorry for my English lol. Defeat*
  14. truyentu
    truyentu New Member
    26Coins
    3DOF, Arduino
    hello,will i need to connect 0.1uF between vcc and gnd of TLP2366 like this ? thank you
  15. Psit
    Psit New Member
    46Coins
    Hey there everyone, i am runnig the mige 130st-m10010 but with a VSD-E and a disco board, after some years of not using it i tried to power it up again and as soon as some feedback is applied it start spinning non stop.
    I can see in this thread you are advising to adjust pn190 , but i am not using the same controller.
    Can someone help? i am going a little crazy over here because i have double checked EVERYTHING and i cant find the issue causing it.
