Accelid DS3 motion rig
Discussion in 'Commercial Simulators and Peripherie' started by yuyu, May 1, 2025.
  1. yobuddy
    51,551Coins
    Probably easier with a absolute imu that is already Arduino compatible thou. (if your going to do it this way)
    https://www.adafruit.com/product/2472
    Of course your going to need to edit the SMC3 Arduino sketch if you do it this way. So be prepared for that. Where if you use pot's, it will work with no changes. So ifs kind of a hardware change with the pot's and a software change with the IMU.
  2. yuyu
    yuyu New Member
    75Coins
    Many thanks for your helps.
    I think I prefer software modifications over hardware ones .
    I might put this project on hold for now, as I may have found a way to get a replacement main board, but it’s not certain yet.
    I’ll keep you updated.
  3. yuyu
    yuyu New Member
    75Coins
    Hello, here's a quick update: I finally replaced the mainboard with another one, and everything is working perfectly.
    Thanks again for your help.
  4. Nikolaj
    Nikolaj New Member
    Today
    16Coins
    Hey there, @yuyu great that you've put in the work and got the Accelid DS3 running. I also baught a used one and now want to connect it and have it running with Assetto Corsa Competizione and als with F1-25. I have the seat connected to the PC and it reacts through DS_GUI app. Now I would like to install the DS3 interface plugin in Simtools 3. Unfortunately I cannot figure out how. The provided DLL file seems not to be sufficient. Can you help with that?
