Accelid DS3 motion rig
Discussion in 'Commercial Simulators and Peripherie' started by yuyu, May 1, 2025.
  1. yobuddy
    51,739Coins
    Probably easier with a absolute imu that is already Arduino compatible thou. (if your going to do it this way)
    https://www.adafruit.com/product/2472
    Of course your going to need to edit the SMC3 Arduino sketch if you do it this way. So be prepared for that. Where if you use pot's, it will work with no changes. So ifs kind of a hardware change with the pot's and a software change with the IMU.
  2. yuyu
    yuyu New Member
    93Coins
    Many thanks for your helps.
    I think I prefer software modifications over hardware ones .
    I might put this project on hold for now, as I may have found a way to get a replacement main board, but it’s not certain yet.
    I’ll keep you updated.
  3. yuyu
    yuyu New Member
    93Coins
    Hello, here's a quick update: I finally replaced the mainboard with another one, and everything is working perfectly.
    Thanks again for your help.
  4. Nikolaj
    Nikolaj New Member
    28Coins
    Hey there, @yuyu great that you've put in the work and got the Accelid DS3 running. I also baught a used one and now want to connect it and have it running with Assetto Corsa Competizione and als with F1-25. I have the seat connected to the PC and it reacts through DS_GUI app. Now I would like to install the DS3 interface plugin in Simtools 3. Unfortunately I cannot figure out how. The provided DLL file seems not to be sufficient. Can you help with that?
  5. Nikolaj
    Nikolaj New Member
    28Coins
    could you also share your axis configuration? I have set up the configuration with your radar proxy and it works. However I cannot find the correct axis configuration so that when I break the seat goes down and so on... Thanks y lot in advance
  6. yuyu
    yuyu New Member
    93Coins
    Hi, sorry I didn’t see your message earlier. You’ll see, it’s a great simulato. Are you happy with it so far?
    For the DLL, you just need to drag and drop it into the SimTools application. Then, in the interface settings, make sure to use the same parameters as in the picture: set the IP address to 127.0.0.1, the port to 21777, and select both axes in each of the dropdown menus. Capture d’écran 2026-04-11 191854.png
  7. yuyu
    yuyu New Member
    93Coins
    Here are my settings for Assetto Corsa Competizione:
    Don’t forget to also set up the min/max settings.
    Hope it helps you :)
  8. Nikolaj
    Nikolaj New Member
    28Coins
    @yuyu amazing thanks. I'll try the settings today. Could you also send me screenshot of min/max Settings, so that I can set it up correctly. I did not play the rig so far and will let you know once set up everything :)
  9. yuyu
    yuyu New Member
    93Coins
    Hi @Nikolaj, for min/max you can use the capture button, and after you’ve recorded a few laps, you can save the actual min/max values for your game.
