Reasonably Priced 100A Motor Controllers
Discussion in 'Motor actuators and drivers' started by Richard Ortengren, Jan 29, 2023.
Tags:
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,122Coins
    Did you update the code on your arduino ?
    The IBT-2 use MODE 2, but this board use MODE 1
    152,229Coins
    +11,066 / 56 / -2
    I don't use the controller so it is hard to follow your description without seeing the actual wiring.
    For example, is the Direction wiring as per the wiring diagram hooked up as depicted, Digital (PWM) 2-5?
  3. Nicki9knuckles
    Nicki9knuckles Active Member
    Web Developer
    740Coins
    3DOF, DC motor, Motion platform
    Oh I did not! I thought I read at the begining of this thread that the default mode worked for this controller. Awesome, I will give this a try @Wagnard thanks!
  4. Nicki9knuckles
    Web Developer
    740Coins
    @noorbeast It is except im only using half of the wiring becuase I am only connecting one motor. So 2-3 + 9. But I think its likly what @Wagnard mentioned
  5. Wagnard
    Wagnardsoft
    5,122Coins
    That's probably it. BTW default mode is 1, so you probably edited it when you used your IBT-2 at beginning.
  6. Nicki9knuckles
    Web Developer
    740Coins
    @Wagnard mode was exactly the problem, seems great now. thanks!!
