  1. noorbeast
    153,722Coins
    Yes SimTools can handle 2 Arduinos.
  2. Mistake
    Mistake New Member
    - 16Coins
    2DOF, 3DOF, Arduino, 4DOF
    Thank you very much for the reply, as soon as I get the parts I will start assembling, I will also share my experience on assembly
  3. Michail
    748Coins
    Is there a list where all compatible smc3 controller are?
    Only know, ibt2, vnhsp30, cytron md13s, sabatooth.
    I installed yesterday a rc filter = 1k ohm resistor with 1μF capacitor on each analog input. And after switch in on motor does not move. In smc3 the hall sensor reacts, but the motor does not move. So I suggest, that the ibt2 again broken. so is there another alternative for mode2, that I don’t have to change the wiring and smc3 script but is way more durable?
    Another question is, that why when I increase the Ki value the motor is jumping up and down like hell? On real pump with inverter does not reacts so in my PLC life.. I can increase ki to 90s and leave usually kp below 10. This behavior I mentioned above overshoot and return is only when add Kd. And with only KP the actual value usually will never reach the set point. It has to be an PI controller at least. So I am a bit confused.
    153,722Coins
    The SMC3 variants for various hardware are listed in the FAQs:
    https://www.xsimulator.net/community/faq/arduino-code-for-use-with-various-hardware-and-simtools.31/
    Many members have reported quality issues with IBT2s, some have suggested reducing the voltage may help.
    With respect to SMC3 settings please post a picture of those running the Sine test.
  5. Michail
    748Coins
    I not new in the game. The smc3 was very well targeted tracked with with kp400, ki 0, kd 80 and Ks 3, fPWM 15 KHz. But I have had jittering and strange movements in idle mode. So I installed the rc filter for the analog inputs of the arduino. Pam max is set to 200 and voltage 21,5V.
    I will look into the smc3 faq. Thank you
  6. Joe Cortexian
    1,537Coins
    SMC is a scaled integer solution. At the end of the calculation there is an “arbitrary” shift (divide) to get the output into -255 +255 range so it isn’t always clipping. So the values of say kp will not necessarily scale to numbers in other algorithms. I think that number was actually chosen carefully.
    Late in the faq there is a modification noted which is a fix for the PID algorithm. You should consider that update. It’s actually discussed in detail in this thread just back up a page or two to see it. The D term is just wrong. I don’t think that’s a direct effect on I but even though D is the derivative term you can think of it as the Damper term.
  7. Michail
    748Coins
    Ok I found the issue. A missing wire was off. I have installed for the two arduinos SMC3 Version 1.0.
    Do I have to update to Sebastian2’s ID zip?
    for safety reasons, that no overheat pwm max is set to 200 and fPWM to 15kHz of the max rated 25kHz
  8. Joe Cortexian
    1,537Coins
    I ran the unmodified stuff for years. The sebastian2 fix smooths out flight simulator. I think it’s better but I doubt that many people have updated.
  9. Michail
    748Coins
    How does it possible? The hall sensor is directly to motor shaft mounted in a ratio 1:1. How it can drive so often 360 degrees and do a wundefull sine curve in smc3ustils? I want this to implement for my surge axis in the future and not to use other controller. May someone explain me.
  10. Joe Cortexian
    1,537Coins
    SMC does not support multi-turn. Position input and output is 255-512+256. If you have a software knack you can change the software to keep track of turns (harder than it sounds). The somewhere in the software you scale the incoming and outgoing positions depending on how many turns you support (easier than it sounds).
    I have done this but the device I used (AS5600) didn’t transition smoothly from 0-1023 or 1023-0. So you get for example 1017-9. This is a bit random based on the noise so you start drifting.
    Consider what happens when the destination happens to be in that region. Or you have ringing that crosses back and forth and now you are loosing track of turns.
    I could make great demos but I never got it working very well. I was using an A5600 not this more expensive device.
  11. Michail
    748Coins
    But he is using smc3utils for the sine curve.
  12. Joe Cortexian
    1,537Coins
    He modified the code. I modified the code.
  13. Mistake
    Mistake New Member
    - 16Coins
    I’ve built a 2DOF setup. In SimTools GameEngine the motors work fine in Output Testing — they react to the sliders.
    But when I start GameManager, it shows “Connected”. I set up the IP, patched the game, and GameManager shows the game is running.
    The problem is: the motors don’t move at all in the game.
    Has anyone faced this issue? Any advice would be appreciated.
    153,722Coins
  15. Mistake
    Mistake New Member
    - 16Coins
  16. Joe Cortexian
    1,537Coins
    It should look like this. Also, you should probably use SimtTools 3 because thats where the latest games are supported plus it has additional features.
    153,722Coins
    You should not need to mess with the IP @Mistake.
    Live For Speed does need to run in first person mode before patching, so unpatch it run it as in the FAQs then repatch LFS: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
    @Joe Cortexian is right, if you are just starting out use SimTools v3 instead: https://www.xsimulator.net/community/faq/simtools-v3.401/
    In addition to the v3 Manual and Quick Start guide also see the motion profile tuning tips: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  18. Doomak
    Doomak New Member
    22Coins
    Hi all) I'm using SMC3_v2.1_SoftStart_Sebastian2, 2DOF UNO + BTS7960. SimHUB/ I have a problem when I quickly turn the steering wheel left right left right, one of the engines shuts off while simulating a car roll... and the second one continues to work. Where should I look for the error? in software configuration? in the firmware? or is there a bad contact in the wiring?
  19. Joe Cortexian
    1,537Coins
    Is it always the same motor? Does it come back on when you turn the. Or or power supply off and on?
    153,722Coins
    That could be a USB disconnect, a PSU tripping out, poor settings, or some combination. It would help if you start a thread of your own and detail your rig plus all harware, both in description and pictures, and post pictures of all of your settings.
