SimTools v3 Public Beta
  1. noorbeast
    151,979Coins
    +11,061 / 56 / -2
  2. pasquereau
    pasquereau New Member Gold Contributor
    6Coins
    Prosimu / Simtools
    I installed Simtools V3 normal with 4 SRT 80 and the fifth SNC6 cylinder in translation I use the same SCN interfaces and the same port as before and it does not work
    Obliged to keep Prosimu/Simtools so that it works? And is it possible to put my SRT 80 in this configuration?
    Thank you for your return
  3. pasquereau
    6Coins
    Scn6 for traction loss
  4. Tino.Sturlic
    Tino.Sturlic Member Gold Contributor
    209Coins
    Hello all,
    I am trying to switch to Simtools 3.
    Installed it on a laptop (windows 11) so I can copy all settings from my main rig and test before the transition.
    I have MDBOX interface. Installed the plugin, selected the right port. Windows is detecting interface as USB serial port.
    When I hit "Test Settings" I get error: "unable to start interface"
    Whatever I do, I cannot get it to move the actuators. Any help would be appreciated.
    151,979Coins
    +11,061 / 56 / -2
    Perhaps others have more up to date information but my understanding, based on the advice of @Thanos, is that unfortunately the Syntron MDBOX protocol is unknown, instead the recommended replacement is the AASD-15A servos with the AMC-AASD15A motion controller: https://www.xsimulator.net/community/threads/how-to-interface-an-sc-mbox-v3.17113/#post-228753
    You can check that alternative out in the FAQs:
    https://www.xsimulator.net/community/faq/amc-aasd15a-servo-controller.351/
  6. Tino.Sturlic
    209Coins
    I think something was misunderstood. I am not trying to connect to Syntron drive.
    I have Thanos interface in between. The setup was working but sometimes I would have to restart Simtools couple of times for it to start and occasionally the motion would just stop.
    I was having a problem with interface not wanting to start like from the first day I bought it. Sometimes I would have to restart Simtools 5 times or so for it to start. It was becoming worse and worse and now I cannot start motion at all. Note that I have second interface that is behaving exactly the same way, so I doubt it's a hardware issue with the interface itself.
    This is why I finally decided to move to windows 11, as I believe (hope) this is a software issue inside windows.
    151,979Coins
    +11,061 / 56 / -2
    As there are a number of them do you mean the @Thanos AMC1280USB Motion Simulator Controller: https://www.xsimulator.net/community/faq/amc1280usb-motion-simulator-controller.336/
  8. Tino.Sturlic
    209Coins
    Here is a picture of the one I have. I do not know the exact marking.
  9. Tino.Sturlic
    209Coins
    Can anybody help with my issue? :(
    151,979Coins
    +11,061 / 56 / -2
    Hopefully @Thanos will chime in when he has a spare moment.
