Tutorial Arduino code for 4DOF and 1 DIRpin Hbridge board
Discussion in 'DIY Motion Simulator Projects' started by RacingMat, Aug 7, 2013.
  1. FrancescoRoberto
    FrancescoRoberto Member
    Italia
    92Coins
    Hi, Sorry but I don't unerstand if the file to install in Arduino is correct to motor monster shield
    Codice Arduino: 4DOF e 1 direzione pin Hbridge 3.2
    May I help me?
    Francesco
    153,914Coins
    +11,156 / 57 / -2
  3. franckk06
    franckk06 New Member
    france
    213Coins
    I did exactly as in image 1 to nicolasp in page 6, but I don't know how to recognize 2 Arduinos at the same time in simtools, thanks.
    153,914Coins
    +11,156 / 57 / -2
    I am not sure what version of SimTools you are using but the process is pretty much the same, please see page 33 of the manual:
    https://simtools.us/wp-content/uploads/2024/02/SimTools-v3.pdf
    Interface 1 is for the first two motors, with the correct port set, and designated
    Interface Output: <Axis1a><Axis2a>
    Use Interface 2 is for the the other two motors, again with the correct port set, and designated Interface Output: <Axis3a><Axis4a>
    The rest of the SMC3 settings for both interfaces are:
    Interface Type - Serial
    BitsPerSec - 500000
    Data Bits - 8
    Parity - None
    Stop Bit -1
    Output Bit Range - 10
    Output Type - Binary
  5. franckk06
    france
    213Coins
  6. franckk06
    france
    213Coins
    No only interface 1 is taken into account...
  7. franckk06
    france
    213Coins
    It's possible to change the Arduino code to put another motor ? I think we can connect 4 motors on one Arduino Uno : 2,3 and 10 for the first ; 4,5 and 11 for the second ; 6,7 and 12 for the third ; 8,9 and 13 for the fourth.
    153,914Coins
    +11,156 / 57 / -2
    I just realised you are not using SMC3, so the settings are as follows, but ignore Startup and Shutdown, just leave those blank, but update Interface to the new SimTools format: R<Axis1a>L<Axis2a>
  9. franckk06
    france
    213Coins
    Yes i use smc3 before simtools to configure my motors, and for bitspersec 500000 or 115200 ?
    153,914Coins
    +11,156 / 57 / -2
    500000 for SMC3, and no SMC3 can't do 4 motors.
  11. franckk06
    france
    213Coins
    Ok if i don't use smc3, which code i use for Arduino Uno ? Sorry i don't understand...
    I use only the example in your board ?
  12. franckk06
    france
    213Coins
    well I may have succeeded! before posting my results, I have a problem. When I configure each motor with smc3, once I have found the desired result per motor, I connect the potentiometer's gear wheel to the motor's gear wheel and it cuts, the motor turns off! I had a motor that was turning backwards when looking on simtools, but it worked fine! and as soon as I reversed the polarities so that it turns in the right direction, it cuts as I wrote on smc3! I don't understand why it does this to me...
  13. franckk06
    france
    213Coins
    IMG_20250920_201025.jpg IMG_20250920_201011.jpg I think I have solved my problem of motor which cuts out when I connect the potentiometer to the motor, you have to reverse the polarities of the motors.
    To make 2 Arduino work together I may also have found the right code in simtools 3, for now it works!
