SimTools v3 Public Beta
  1. yobuddy
    51,524Coins
    The plugin has been updated for the new API :thumbs
    (Please make sure your game is fully up to date)
    • Winner Winner x 3
  2. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Motion platform, 6DOF
    A HUGE Thank you!!! Were you also able to fix the issue and disable the motion during replay? (I'm at work at the moment)
  3. yobuddy
    51,524Coins
    What's the issue? You want to block movement when the lap plays back or something? A lot of games like live for speed allows you to ride the replay is all.
  4. Josemanuelrm
    Josemanuelrm New Member
    valencia
    65Coins
    Hi, yes, I do have it in the settings. It turns out that it moves, but poorly, and the movements don't match the car's movement.
    However, in F1 and Aseto, it works fine.
    153,740Coins
    Please post pictures of all of your settings, including the tuning center while the game is running.
  6. Josemanuelrm
    valencia
    65Coins
    Hello, I think I have it now... the problem was that the 2 DOF that I have when I activate the axes (Roll,Pitch,YAw,Heave,Surge,Sway ) in the end I only left ( Roll,Surge,Sway) and it makes the swings, acceleration...
    since I didn't understand, I activated everything and in the end I activated them one by one and saw what each one does.
    thanks for the help...
  7. Arianus One
    Arianus One Tony Rom
    empleado
    16Coins
    Simtools v2 works for me, but Simtools v3 doesn't. Is it because I have to pay for the plugins? Simtools gives them to me for free, but my simulator doesn't work. Only with the paid plugins and in Simtools v2.
  8. Arianus One
    empleado
    16Coins
    I correct the comment that simtool v3 was not working for me, now in f1 2022 it started working, I think it was because I downloaded the plugin myself and did not use the automatic method from v3 but rather I downloaded it from the page and took it and dropped it in simtools v3, I will try the same method in f 1 2025 and in dirt 2.0 to see what happens
  9. Josemanuelrm
    valencia
    65Coins
    Hello, in v3 the plugins are free. You install them directly from the repository. Remember to do a race and finish it before installing the plugin on the F1s.
    Yes, enter the port and IP address too.
  10. coyote1168
    coyote1168 New Member Gold Contributor
    - 53Coins
    Hi, can you explain the process for updating?
  11. yobuddy
    51,524Coins
    By default, it will update the game plugin the next time you start-up simtools. If you have set game plugin updates to manual on the options page, then you will get a little up arrow on the banner for the game, where you can click it to update the plugin.
  12. coyote1168
    - 53Coins
    Thank for the reply.. i update the plugin, my game is update, but all the input are 0.. i don't know what i missed..?
  13. yobuddy
    51,524Coins
    Please try uninstalling the plugin (the little trash can icon on the game plugin). The restart SimTools and reinstall the plugin. (This will re-patch the game for motion in-case anything accidentally got changed) Afterwords you should be good to go! :thumbs
  14. coyote1168
    - 53Coins
    no better.. I'll try deleting the game and reinstalling :(
  15. coyote1168
    - 53Coins
    I retry today.. uninstalling plugin, restart simtools, install plugin... and it's ok!..
    Thanks a lot yobuddy :o:
  16. yobuddy
    51,524Coins
    Plugin is now available for SimTools v3.
    Special thanks @value1 for all your work on the plugin!
  17. FLORIN ROMANIA
    FLORIN ROMANIA Member
    România
    810Coins
    Hello, I'm back with the game vibe problem for F1 22 and 20, since I gave up using game vibe from simtools V3, I used Simhub for a while, but because I have simtools pro I want to use game vibe from simtools. I still haven't managed to figure out the settings for road vibrations and chassis, please guide me, it would be a shame to have a game vibe and not be able to use it. Please help me step by step
  18. xFFBx Tearier
    xFFBx Tearier ffb Tearier Gold Contributor
    232Coins
    I’m getting great motion for every game. But nothing in Iracing. I see others have had issues before. Is there any fix?
  19. yobuddy
    51,524Coins
    A new IRacing plugin is in the testing phase, and should be available next week.
    For now thou, please try starting the game first, and get on the track. Then launch SimTools with the option to "auto detect a running game" checked, and it work as expected. This is usually only a problem when other apps that collect the games data are used at the same time as SimTools.
  20. lysa elec
    lysa elec LYSA ELEC
    16Coins
    The Ultimate Le Mans NR plugin doesn't work with SimTool v3. My other games work, but my simulator reacts and resets to zero when I open Ultimate Le Mans, but none of the axes work with the game. What's happening?
