Showroom Budget Compact 6DOF Universal VR Flight / Racing rig - MSFS, SMC3, FlyPT, Transducers, Controls
Discussion in 'Commercial Simulators and Peripherie' started by Ronan Design, Oct 11, 2024.
  1. OrtiMai
    OrtiMai Member
    145Coins
    I didn't fly long enough to see any changes in temperature of the motors. I'm heavy, so they must have some work to do, even if I used 3 gas struts to balance the weight. Right now, temperature / inefficiency is not a problem, but I'll keep that in mind.
  2. Ronan Design
    Toronto, Canada
    1,716Coins
    Things are on hiatus for a while because my mother has been in the hospital for 4 months now, with a lot of things I need to take care of. But generally, yes, I'm working on a racing configuration including custom pedals and a joystick/HOTAS configuration. I will create FlyPT presets for the racing/rally games as well as Euto Truck Simulator / ATS.
    I have a single strut, which always pushes a depowered rig to one side. I use the 3D-printed stops included in the package, rotating them in a way that the motor arms stop past the usable motion range but before the red cut-off point. That way, when powered, the rig centers itself. Occasionally, it sits beyond a cut-off point, but then I can see that one of the 3 Arduino's light doesn't come on (it's by design, it's only on when in the usable range), and then I slightly move the offending arm and reset the rig before powering up. Once powered, it takes care of itself.
    Makes sense, I only use 45 degrees as the maximum usable range that SMC3 should allow, beyond which the signal needs to be clipped, and then the emergency stop cut-off implemented. It might be a good idea to limit the actual motion to a narrower angle, but it's done with software.
  3. OrtiMai
    OrtiMai Member
    145Coins
    Well, family goes first! That's for sure.
    I went VR flying for the first time. Flew >1h and got max. 36°C on one motor. I think I don't have to worry.
    What would you do to reduce the ground behavior a bit. I tried to decrease the longitudinal value of the road noise, but I'd like to get it generally a bit more calm, without decreasing the behavior in the air, which you figured our really nicely.
    And one more question.
    I just set up OVRMC and edited the config to FlyPT. Anything else I need to do, except binding the keys and keeping the window of OVRMC in FlyPT open?
    Thanks so far for all the support. It was a joyful experience so far. And I learned a lot.
  4. Ronan Design
    Toronto, Canada
    1,716Coins
    I'm glad the motors are not heating up for you.
    Ground can be controlled by a separate formula in FlyPT Mover. Try to disable "Road Noise" pose completely. If it eliminates what you want to reduce, you can just enable it back and change the gain inside the formula from 1 to 0.3 or whatever works for you. If it's something else, you can decouple air and ground and use a totally separate formulas for them.
    I think you got the OVRMC basics, do fast rolls with it disabled and enabled and look at the spot inside the cockpit close to your head. Note the movement of the head relative to the cockpit. There should be a huge difference between on and off. It's never perfect, partly because your head really bobs from the actual chair movements, but the difference should be unmistakable.
    Can you please share a video of your build? It would be nice to see your completed project in action. Also, I'd appreciate it if you leave a review on the website.
  5. OrtiMai
    OrtiMai Member
    145Coins
    Alright, I'll try it out. Yes, I can do a video for you and pictures for the community. It's functional in terms of 6DOF, but I still have to think about a suspension for Honeycomb Alpha and Bravo. I commented on Google maps already and will leave a comment on your website as well.
  6. OrtiMai
    OrtiMai Member
    145Coins
    Hi all,
    here are two pictures of the working rig. One at a development stage without Yoke and the other is a picture from yesterday's with Honeycomb Alpha and Bravo on a little self built desk.
    Let me know, it there are any questions. I flew my home airstrip yesterday in VR and reducing GAIN to 0.3 (Ground Nois) feels so much better. OVRMC is working now as well.
    Next project: The china 24V 1500W power supply is loud as hell. I'll see, if I can upgrade the fans.
  7. OrtiMai
    OrtiMai Member
    145Coins
    Little update. I did some more extensive flying now, with me loaded on the rig and I managed to reach 52°C, which crosses the 50°C theshold, that Roman set up. That means, that I'm facing the same challenges, as all the others. I repositioned the gas struts now and will do a test agin.
    Edit:
    PWMmax and PWMrev working against each other. High values, e.g. both on 200 lead to hogh temperatures >50°C.
    These are my values now:
    Motor1_PWMmax=180
    Motor1_PWMrev=5
  8. OrtiMai
    OrtiMai Member
    145Coins
    Little tutorial on how to calibrate the analogue "hall sensors" in SMC3:
    (Please review and let me know, if I got something wrong or can improve)
    We need to calibrate the analogue hall sensors, befor SMC3 can work with is properly. This is essential to mitigate harmful overshooting of the motor arms.
    1. Setup:
      • Motor and Sensor are build according to the instructions
      • Sensor is connected to the Arduino
      • Arduino IDE is started with SMC2.ino loaded
      • Under "Tools" in the menu, open the Serial Monitor
      • Set the BAUD rate to e.g. 9600 (you can choose the one you like, but it must match the SMC3-code in approx. line 226 "#define BAUD_RATE 9600" - with low BAUD rates, you have to bit of lag with regard to the value update)
    2. Activate the monitor for the sensor of motor 1:
      • Go to "int GetFeedback(MotorData &m)" and delete the commenting (//) "//Serial.println("Motor 1");"
      • Do the same for "//Serial.println(Feedback);"
      • Compile & Falsh it to the Arduino
    3. Acquire the Min. and Max. values of your sensor of motor 1
      • Move your motor arm of motor 1 by hand around the Min. and Max. Positions.
      • In the monitor, stop the movement of the values by klicking on the 2 arrows facing down >>.
      • Then scroll through the values to find the Min. and Max.
      • Now the serial monitor should show you values. Dependig to the direction it's either going down in the direction of 200 or up in the direction of 700
      • Firgue out the Min.-value and write it down in reference to motor 1 (Min.-value is the smallest number you can get, befor it starts increasing again)
      • Do the same for the Max.-value (Find the biggest number, befor it starts decreasing again)
      • Reset the output of the monitor, not to mix up values
    4. Acquire the Min. and Max. values of your sensor of motor 2
      • Go to step 2 and comment the lines for motor 1 out again
      • Go a vew lines below and un-comment the print-out lines for motor 2
      • Compile and flash
      • Do the steps no. 3 for motor 2 again
      • Document your Min. and Max. values for motor 2 as well
    5. The Min. and Max. values from motor 1 and motor 2 are not the same! What to do?
      • That's normal with analogue sensors and due to the way you places the magnets and soldered the hall sensor or even to the mass produced hall sensor itself
      • If you'd want to max. out each sensor, you's need an adruino board for each motor
      • In our setting, we've 1 arduino taking care of 2 motors. Thus, we need to find a compromise.
      • Due to our aiming for safety, we take the Min and Max. values of the "weakest sensor".
      • One example:
        • Sensor Motor 1: Min 258 Max 758 (weakest sensor with the smallest range)
        • Sensor Motor 2: Min 230 Max 768
        • We take: Min 260 Max 750 (rounded to the safe side)
    6. Finalize it!
      • Go to "#define SENSOR_SCALE_MIN" & "#define SENSOR_SCALE_MAX"
      • Insert your values and safe
      • Go to the print-out lines of step 4 and un-comment them again
      • Go to the BAUD_RATE and set it back to 500000
      • Compile and falsh
      • Do all these steps of every pair of motors. (You should have three pairs of motors.)
      • Save all SMC3-sets (for each pair of motors) in one .ino-configuration each
    @Ronan Design : If it's correct in terms of procedure, you can add this to your instructions if you find it helpful.
  9. OrtiMai
    OrtiMai Member
    145Coins
    Recommendation with regard to the noisy PSU (power supply unit):
    If you used the PSU, that Roman had in his list, due to being a perfect meanwell copy. Be aware, that it's really loud.
    To reduce the noisy PSU, you can easyly exchange the fans:
    Fan: 12V DC 1,56W 60x60x25mm 45,9m³/h 5200U/Min 45,9m³/h Sunon MF60251VX1000UA99
    It's not quiet afterwards, but way better and the fan is about 4$ (3,50€) each - you'll need 2 of them. It's an affordable upgrade.
    P.S.: Be aware, that you'll need 2x XH 2-PIN to crimp the new fans according to the PSUs adapter.
  10. OrtiMai
    OrtiMai Member
    145Coins
    @Ronan Design: I have a technical question.
    I saw it in your video (the one with the white printet test-arms) and I still have the same problem. If the motor goes into the clip range, the PWMrev will get activated. So far so good.
    Now the problem:
    In one direction (e.g. the lower clip) the break just holdes the motor arm securely in the clip theshold position. In the oposite direction (e.g. the upper clip) I get a controller fight. The motor tries to cross the clip threshold and the reverser throws it in the inverse direction. The outcome are heavy forth-back movements.
    My observation:
    When I move slowly into the clip threshold, the reverse brake is able to just break the movement and keep it there. In both directions. If I move fast into the clip threshold, then, it overshoots a bit, the reverse overshoots into the inverse direction, the PWMmax goes against it and I have this heavy stutters. Why only in one direction?
    I havn't changed any Kp = 120, Ki = 1, Kd = 10, Ks = 5 values of the controller.
    Any idea?
  11. Martwana
    Martwana New Member
    41Coins
    Hey @Ronan Design
    Yeah so I had to resort to using the struts. The motors just get too hot without them.
    So I have 2 300n struts installed, left and right side. They help keep the motors much cooler, however they dont help with pitch. The rear motors still get quite hot, but not hot enough to stop me flying for around 60-90 mins.
    I was having serious issues with the hall sensor alignment and could not figure out why I couldnt get them to align properly, so resorted to potentiometers and some different end caps for the motors to directly connect it. Works fine and might swap out to rotary hall sensors later, but for 10x pots on Amazon for £10, I'm fine with replacing them whenever they wear.
    Since then its been behaving beautifully. I moved the config over to the latest FlyPTMover Beta so I had support for some other games. I've got decent crash protection now built into the filters for driving too.
    We're mostly using FS2024 and AMS2. For driving (last video in the album), the gearbox play becomes VERY apparent as its making lots of heave movements. I need to work out how to calm that down because 90% of the rigs noise now comes from that.
    For flying, it is beautiful. I just got a Pimax Crystal Light and it's clarity, plus the motion cues makes it so fun.
    Here's my build photo album if anyone is interested.
    https://photos.google.com/share/AF1...?key=VndLRjhsNkYxVkFqRkxseFVnaG9KWDZKSTJsYlV3
    I'm getting close to the point of wanting to sell this rig now (minus the chair and peripherals) and build another and make some further changes to optimize the design. It's been a great build but I'd do a bunch of things different if I do it again.
    If anyone in the UK would like to buy it, please reach out to me!
  12. OrtiMai
    OrtiMai Member
    145Coins
    SMC3 w/o overshoot and now threshold dance at clip limit
    I had to turn the PWMrev down to 15, to minimze the shaking, when I cross the Clip in one direction.
    Ki=0, due to cogging
    Here are my values:
    SMC3_Version=220
    Motor1_Kp=230
    Motor1_Ki=0
    Motor1_Kd=10
    Motor1_Ks=5
    Motor1_PWMmin=0
    Motor1_PWMmax=180
    Motor1_PWMrev=15
    Motor1_Limit=20
    Motor1_Clip=190
    Motor1_Deadzone=1
    Motor2_Kp=230
    Motor2_Ki=0
    Motor2_Kd=10
    Motor2_Ks=5
    Motor2_PWMmin=0
    Motor2_PWMmax=180
    Motor2_PWMrev=15
    Motor2_Limit=20
    Motor2_Clip=190
    Motor2_Deadzone=1
    [Motor3 it not relevant as it's not used. You can have here whatever values you want.]
    PID_Divider=4
    Motor1and2PWMFreqkHz=25
    Motor3PWMFreqkHz=31 [not relevant]
    These values were evaluated with SMC3 utility. Befor you transfer them to the Arduino firmare, make sure that every motor was tested with the SINE and MANUAL mode in SMC3.
  13. OrtiMai
    OrtiMai Member
    145Coins
    Next update:
    I implemented @Sebastian2 fix for the integrating and daming term of the controllers behaviour.
    I'll get back to you guys with the full .ino file, if I get Romans okay.
  14. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
  15. OrtiMai
    OrtiMai Member
    145Coins
    Yes, @Sebastian2 gave me many more improvements as well. He posted his most actual code in the SMC3 thread.
    What I now did is a full adaption of his improvements to @Ronan Design s code.
    I'll ask Roman, if I'm allowed to post my full .ino now. I'll get back to you.
    Update: First test went very positive. Never had such a smooth sim rig before.
  16. OrtiMai
    OrtiMai Member
    145Coins
    Todays lessons learned: A hall sensor that is not 100% in place will lead to an overshooting arm, in reference to the clipping limit.
    My tip: Take a hot air pistol. Warm the arm a bit and hold it in place, till it's cooled down. This way, you get rid of inner tensions. All armes really need to stay snug in position - in all angles of the motor arm. Make sure about that.
    I now switched from Romans code to Sebi2's code, adapted it to our geometry and implemented Romans safety changes. I'll post my code soon here, if Sebi's fine with that.
    In my earlier post my integration went this way:
    Sebi2 --> Roman (good but still some problems with overshooting, as I-component is now working and in some occasions it's getting out of control)
    Now it's this
    Aspacts of Roman --> Sebi2 (best results - it's really good)
    https://www.xsimulator.net/communit...or-driver-and-windows-utilities.4957/page-137
  17. OrtiMai
    OrtiMai Member
    145Coins
    Okay guys, whoever is building Romans version for the 6DOF rig might be interestet in my adaption of @Sebastian2 's code.
    Feel free to review and get back with feedback to us. We'd be interested to see, if that's working for you guys as well.
    Cheers and have a good time in the virtual world.
  18. OrtiMai
    OrtiMai Member
    145Coins
    New lessons learned:
    If your PID values are optimized and the motors still get too hot - it's due to the inbalanced rig. Now I have in the front two 534N gas struts (right & left) and one 200N in the back. The one in the back is centered in the bottom triangle, the two in the front are exactly positioned, where the front edge of the top triange crosses the bottom triangle vertically.
    Don't use the assembly holders, that come with the gas struts, they are too weak. Use the same steel as for the motors.
    I now run all motors in the range of 25°C - 30°C and can do that for hours. It's great.
  19. Ivan85
    Ivan85 New Member
    16Coins
    Ronan hi,
    I want to construct this project for my son 10 yo.
    Can you give me project files and soft?
    We will be grateful to you.
  20. OrtiMai
    OrtiMai Member
    145Coins
    I got it from his website (Roman Design 6DOF). You can google it. The project description is not for free, but a fair deal respecting the work he did, to write everything together. For optimization, please read this forum thread before building it. It will avoid a lot of mistakes. Feel free to ask questions here. Most problems I had already.
